John Michl
John Michl
Keokuk, Ia
200 registered members (68 royalstar tony), 1,981 guests, and 525 spiders.
Mark Masa, Jody Camak, analyse, Drifter, john harrison
10041 Registered Users
Lannis 149
kommando 117
Stuart 60
479,420 mail-order LSR
Topics65,754
Posts635,650
Members10,041
Do you run without intake balance pipe? #557067
08/06/14 5:08 pm
08/06/14 5:08 pm
Tampa, Florida
bonneville15 Offline OP
Tampa, Florida
I just removed the choke cables, lever and the choke slide from the carburators and was messing with the balance pipe. Removed the pipe and plug the intake manifold niples. Fire the bike and she was not happy at all. Misfired, pucking, coughing. Place the balance pipe back on and now is normal.
What is that balance pipe for and, how much that affect the caburators? Does is go rich or lean without it?
This is done on a 77 T140.
William
ASE Automotive Master Tech.
Never regret anything in your life because at one point, that was what you wished for.
Always tell the truth, even if your voice shakes.
1977 T140V
Re: Do you run without intake balance pipe? [Re: bonneville15] #557070
08/06/14 5:23 pm
08/06/14 5:23 pm
It usually has little effect.
It makes the bike less sensitive to out of balance carburettors.
Re: Do you run without intake balance pipe? [Re: bonneville15] #557095
08/06/14 7:01 pm
08/06/14 7:01 pm
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
It suggests that your carbs are not well synchronized.
Re: Do you run without intake balance pipe? [Re: bonneville15] #557115
08/06/14 8:55 pm
08/06/14 8:55 pm
Tridentman Online content
Tridentman  Online Content
have you plugged the holes at the top of the carbs where the choke cable used to enter?
If not then recommend that you do so.
Re: Do you run without intake balance pipe? [Re: Tridentman] #557166
08/07/14 7:38 am
08/07/14 7:38 am
OZ
Old Cafe Racer Offline
OZ
Put the choke slides back in or else you have a very large volume of air void space above the venturi's which drastically reduces vacuum signal above the jets, especially when cracking the throttles at lower openings.
If you don't need chokes then tap the slides M4 and fit screws down through the tops with small O rings to seal/self align the slides and loctite the threads to ensure the slides don't eventually work down the slots.
Removing the slides is like fitting slides with much bigger cut-aways but it also affects the mixture all through the whole range in my experience.
davy
Re: Do you run without intake balance pipe? [Re: Old Cafe Racer] #557169
08/07/14 7:52 am
08/07/14 7:52 am
davy
Not in my experience.
Re: Do you run without intake balance pipe? [Re: bonneville15] #557210
08/07/14 12:22 pm
08/07/14 12:22 pm
Reading UK
twinspin Offline
twinspin  Offline
Reading UK
I would imagine that if the carbs are tuned using the balance pipe then if the balance pipe is removed and the holes plugged then the carburation will be upset. However, if the carbs are tuned without the balance pipes I cannot see any reason why they cannot achieve a good level of balance on tickover and have not heard any sound theory why a balance pipe would improve things. On the contrary, it complicates the issue as each carb depends to a degree on the tuning of the other carb as well.
As far as I can tell, the balance pipe on the inlet manifold has about as much value as the one on the exhaust pipe except that the exhaust pipe has the advantage of a little extra mutual mechanical support.
1971 T100R
1970 T120
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557212
08/07/14 12:22 pm
08/07/14 12:22 pm
Upstate NY
Snakeoil Offline
Snakeoil  Offline
Upstate NY
What Davy says makes sense since it is that very same issue that gives the Monobloc a slower throttle response than a Concentric. I suspect this is why Keihin put a gate type of choke in their roundslide carbs to remove the void in the slide.
But my guess is you did not plug those balance nipple holes very well and you have a serious air leak. Your symptoms are what I would expect if you simply left the balance tube off and did not plug the nipples.
regards,
Rob
Re: Do you run without intake balance pipe? [Re: Snakeoil] #557214
08/07/14 12:26 pm
08/07/14 12:26 pm
regards,
Rob
I'm not saying it doesn't make sense. I'm saying I doubt that it is apparent.
I also seriously doubt that you, Rob, can discern a difference in throttle response, between Monobloc and Concentric on the same bike.
Re: Do you run without intake balance pipe? [Re: bonneville15] #557281
08/07/14 7:23 pm
08/07/14 7:23 pm
John Healy Online content
John Healy  Online Content
Triton have you ever ridden a bike with a flat side carburetor?
Re: Do you run without intake balance pipe? [Re: bonneville15] #557284
08/07/14 7:47 pm
08/07/14 7:47 pm
Out There!
Nick Offline
Nick  Offline
Out There!
Davy is right about the extra volume. One of the tricks I learned from the Japanese gamble racers was to fill the void left by the choke slide with epoxy or JB weld in order to increase responsiveness. Note that the slides used in the Mikuni round-slide carbs have a flush bottom.....
Re: Do you run without intake balance pipe? [Re: bonneville15] #557290
08/07/14 8:04 pm
08/07/14 8:04 pm
Not exactly. There is no cut-out for a slide, yes in that sense they are flat, but they have the same recess as a Concentric MKI and MKII.
These make the bottom of the slide, well sort of flat in an effort to improve throttle response. And yes, you certainly have to play around with the jetting as they do increase the signal on the needle and main jet:
http://www.thunderproducts.com/u_f_o.htm
Re: Do you run without intake balance pipe? [Re: bonneville15] #557319
08/07/14 9:58 pm
08/07/14 9:58 pm
Tampa, Florida
Tampa, Florida
John Healy:
Have you ever used those ufo discs?? It looks interesting enough to try a set.
Does anybody knows if removing the pipe will make it go rich or lean ??
1977 T140V
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557388
08/08/14 9:03 am
08/08/14 9:03 am
OZ
OZ
Well TT, after messing with mine without chokes slides and the tops sealed for 12 months I had an epiphany and fitted the chokes and all the bad flat spots went away, especially off idle when cold.
Your experience might be different from mine but if it was then some other factor was at play.
In my experience the difference was night and day and was like fitting accelerator pumps.
davy
Re: Do you run without intake balance pipe? [Re: Old Cafe Racer] #557395
08/08/14 9:49 am
08/08/14 9:49 am
Running from demons in WNY
Hillbilly bike Online content
Ok,time for an experiment...I'm looking at this guy's bike with a flat spot at low speed. No choke .Newer Concentric single carb with a number 3 slide and the engine is tuned properly....I just filled the choke hole in the slide with epoxy and leveled it off,did not fill the whole depression. When it's cured tomorrow,see if it makes a difference.
Re: Do you run without intake balance pipe? [Re: John Healy] #557533
08/09/14 8:39 am
08/09/14 8:39 am
I don't think so.
I have filled the air slide hole on throttle slides and used Mk1.5 throttle slides with the base of the hole blanked off, as well as normal throttle slides with and without air slides fitted.
Here's a thing though- when the throttle slide is near closed and the air slide is fully up, there is a large open volume under the air slide. That's what makes Old Cafe Racer's recommendation to leave the slides in seem strange.
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557541
08/09/14 11:16 am
08/09/14 11:16 am
I reassembled the Concentric with the choke hole in the slide neatly filled with epoxy. Just the choke hole,the "teacup" was left as is.
I would say there's a slight improvement in engine response better at low RPM. This is a good running but high mileage 1965 6T engine.The modification might be more noticeable on a higher tuned engine....Or for those using E10 gasoline...I use non ethanol gas...
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557678
08/10/14 11:04 am
08/10/14 11:04 am
That has been my experience. I have never tried riding my bike without the intake balance tube, but I do use those connections for carb synchronization. I made up a Y connector for use with a vacuum gauge. When I pinch off one side, perhaps the RPM drops just a little, but it really has only a very slight effect.
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557710
08/10/14 5:51 pm
08/10/14 5:51 pm
Allan Gill Online happy
Allan Gill  Online Happy
regards,
Rob
which bit doesn't make sense?
As for the balance pipe, removing that and not plugging the holes is as bad or worse than having an air leak at the flange, I swear you could pipe those balance spigots to a 3rd carb or fuel injector! Sounds silly but there is one hell of a suction from those balance spigots. After using cylinder heads with and without them, I much prefer not to have them, darn things are a pest to seal.
As for the Monobloc/Concentric comments, and the concentrics do give a better throttle response than the Monobloc, when the throttle is opened it takes less time for the pressure to equalise in the tea cup of the slide on the Concentric than the Monobloc, the result is an improved throttle response. Things that also do this are smaller ports and snappier valve durations.
I'd love to try a set of flat slides as John mentions, at some point I probably will but for now, personally I find the concentrics work quite well and not too difficult to set up.
2c
Re: Do you run without intake balance pipe? [Re: Allan Gill] #557714
08/10/14 6:20 pm
08/10/14 6:20 pm
regards,
Rob
2c
We're very much at cross purposes.
Nobody said anything doesn't make sense. Nobody said you don't have to block the manifold spigots if you, for some strange reason, remove the balance tube.
I'll try to clarify in the next post.
Re: Do you run without intake balance pipe? [Re: Old Cafe Racer] #557715
08/10/14 6:23 pm
08/10/14 6:23 pm
davy
I disagree that removing the choke slides causes a problem. Thousands of them have been thrown away!
I do agree that the holes for the choke cables should be plugged if you remove the chokes.
Re: Do you run without intake balance pipe? [Re: triton thrasher] #557719
08/10/14 6:49 pm
08/10/14 6:49 pm
Well, I disagree based on my back to back test one day apart on the same single carb engine two days ago. A slight increase in throttle response off idle like when the carb circuits go from pilot jet to slide cutaway. Perhaps an increase in vacuum signal...
Your results may vary ...
Re: Do you run without intake balance pipe? [Re: bonneville15] #557764
08/11/14 12:38 am
08/11/14 12:38 am
Tampa, Florida
Tampa, Florida
Compadres:
I did removed the choke slides and the bike still feels pretty much the same. Maybe need a little tweak. The balance pipe I will leave alone because will take to much adjusting with no reasonable gain. I would like to try those UFO discs but looking at the prices I might pass.
William
1977 T140V
Re: Do you run without intake balance pipe? [Re: bonneville15] #557776
08/11/14 2:18 am
08/11/14 2:18 am
If your carbs are set right, removing the balance pipe and plugging the holes should make little-no difference. Providing the carbs are in fine fettle, slides and jetting balanced, no air leaks anywhere.
If you have any of the above, your fighting a loosing battle.
The UFO's won't work on a mk1 Concentric, the slides when fully down surround an area in the port floor, the UFO... Even if it did fit would stop the slide seating all the way.
Re: Do you run without intake balance pipe? [Re: bonneville15] #557807
08/11/14 9:46 am
08/11/14 9:46 am
Tampa, Florida
Tampa, Florida
Allan Gill:
Thank you for the clarification. You just saved somebody and me $70.00 plus shipping. I preciated it. This forum is the best.
William
1977 T140V
