Prospect
Prospect
London UK
39 registered members (Adam M.), 250 guests, and 380 spiders.
Duckster, IDG1, pemdoc65, creativecroc, gregneal
10171 Registered Users
Lannis 96
Stuart 84
reverb 81
NickL 69
koan58 56
550,114 mail-order LSR
Topics66,555
Posts645,181
Members10,171
Rating: 3
Page 7 of 8 1 2 3 4 5 6 7 8
Re: A65 caf [Re: lilo] #551836
07/08/14 9:49 am
07/08/14 9:49 am
Surrey UK
Mattsta Offline
Mattsta  Offline
Surrey UK
Rorty McSnorty!!!!
That is an animal!!!!
Who makes those control levers. They look very nicely made
1952 Triumph T100 in a BSA A7 Frame
Re: A65 caf [Re: lilo] #551841
07/08/14 10:54 am
07/08/14 10:54 am
Mississauga, Ontario.
Adam M. Online content
Adam M.  Online Content
Lilo, what about a movie to see it in action ?
Looks awesome.
Re: A65 caf [Re: lilo] #551900
07/08/14 4:34 pm
07/08/14 4:34 pm
Westminster, MD, USA
J. Charles Smith Offline
A fabulous machine beautifully executed. Very clean lines with nothing overdone or out of place. Great job.
Re: A65 caf [Re: lilo] #551990
07/09/14 5:54 am
07/09/14 5:54 am
manchester England
jim hodges Offline
One time poster
jim hodges  Offline
One time poster
manchester England
Looks great,,
Does it go as well as it should.
Jim hodges
Re: A65 caf [Re: lilo] #552077
07/09/14 5:16 pm
07/09/14 5:16 pm
england
lilo Offline OP
lilo  Offline OP
england
I'll show you at the Manx!!!!
Re: A65 caf [Re: lilo] #552079
07/09/14 5:24 pm
07/09/14 5:24 pm
england
lilo Offline OP
lilo  Offline OP
england
Does anyone have any experience of the 90 degree Pazon system.
It seems to have a wasted spark which means a lot of kickback with the following piston starting the compression stroke as the 1st one is about to fire.
Ive emailed the question to Pazon but they have not replied.
Re: A65 caf [Re: lilo] #552718
07/13/14 4:22 pm
07/13/14 4:22 pm
england
lilo Offline OP
lilo  Offline OP
england
Thanks for that info.
Im also using long inlet tracks but this is kickback and not spitting out the carb.
Ive emailed Pazon twice. Don't want to have to phone New Zealand in the middle of the night.
How did you make your own system?
Re: A65 caf [Re: lilo] #552818
07/14/14 6:32 am
07/14/14 6:32 am
Looks the DB's Lilo!! A very nice bike indeed
Re: A65 caf [Re: lilo] #552901
07/14/14 3:48 pm
07/14/14 3:48 pm
england
lilo Offline OP
lilo  Offline OP
england
I'm running the bike with the standard 9mm before tdc.
We've retarded the timing bit by bit until the bike won't start but the problem still exists.
Its as if the following piston is just starting to rise when the wasted spark hits and if the primary piston doesn't fire properly the following one bounces back.
Compression is 9:1
Carbs, as you can see maybe not the most sensible choice.
Cam timing, Im not sure. A special from Rainer.
Re: A65 caf [Re: lilo] #552902
07/14/14 3:49 pm
07/14/14 3:49 pm
england
lilo Offline OP
lilo  Offline OP
england
I take back everything I have said about Pazon.
Andy has just mailed me with the most comprehensive list of solutions I have ever received from a query.
Re: A65 caf [Re: lilo] #553003
07/15/14 8:50 am
07/15/14 8:50 am
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
Lilo, could you please share the solutions that Andy sent you?
.. Gregg
magneto@spyder-it.com
Re: A65 caf [Re: lilo] #553053
07/15/14 3:15 pm
07/15/14 3:15 pm
england
lilo Offline OP
lilo  Offline OP
england
Hi Lilo,
Thanks for contacting us.
The kick back you describe is very rare at least with our ignitions.
The Smart Fire uses a fully retarded mechanical reference point (on the rotor) at slow speeds.
Our systems for twins/v-twins/triples are all wasted spark, as are most of the electronic ignition systems currently available for classic British bikes.
We have supplied many systems over the years, and wasted spark works fine on a properly tuned/timed engine.
Fuel generally only ignites under compression, unless there are problems with ignition timing and/or carburetion.
However, wasted spark ignition should be avoided on a supercharged engine, where problems could occur.
Our systems have been fitted to 45, 50, 72, 90 and 180 crank twins.
Harley used wasted spark (with a single set of points) for decades, without a problem.
With later models there has been a need to cater for fuel injection, lower emissions, improvements in economy and power, etc.
So you will find that most modern bikes and cars have switched to engine management systems.
These systems offer greater efficiency and non-wasted spark (single fire) ignition.
This certainly makes sense, although it means more complexity, i.e. increased circuitry and extra ignition coil(s).
Independent firing is something we have considered, and may offer at some point for those that want/prefer this method of firing.
For most classic bikes the wasted spark system is the simplest, and in our experience works fine
Normally kick back would be due to incorrect timing, wiring fault, battery, connections, switch, fuse, grounding or mechanical problem.
Can you see the advance/retard working with a strobe, i.e. the alternator rotor mark moving as rpm increases?
Retarding the timing may help, but shouldn't be necessary if the ignition was timed/strobed correctly.
What other work was done to the bike before (or after) fitting the new ignition?
Does the bike run normally (once started)?
Some problem areas to check include:
Bad electrical connection, switch or fuse contact
Poor grounding
Faulty battery
Faulty/high resistance plug cap
Air leak
Carb fault
Faulty ignition trigger
Faulty ignition coil
Faulty ignition module
If you have a test meter you can check the plug caps and ignition coil for correct resistance readings.
The plug caps normally read about 5k (5000) ohms from end to end.
The dual ignition coil primary resistance is 0.6 ohms across plus/minus terminals, and about 8k ohms across the two ht outlets.
Its worth checking that the timing is still correct, in case the rotor has slipped (unlikely, but possible).
You could also try running a temporary wire directly from the battery to the ignition module, bypassing the wiring harness, switch etc.
See if the kick-back persists.
Its also possible for a weak mixture to cause or aggravate a kick-back problem.
This could be due to a carb fault/setting, air leak, valve problem, etc.
Hope this helps.
If this cannot be resolved, our ignition parts can be returned to us for testing.
We can check for correct advance/retard operation etc. on our rig.
Best regards,
Andy Perkins
PAZON IGNITIONS LTD.
Keeping Classic Bikes on the Road
www.pazon.com
274 Hot Springs Road
RD 2
KATIKATI 3178
Bay of Plenty
New Zealand
Tel: 0064 75495878
Fax: 0064 75495879
Email: ignition@pazon.com
Re: A65 caf [Re: lilo] #553228
07/16/14 4:16 pm
07/16/14 4:16 pm
Ipswich England
wbabojo Offline
wbabojo  Offline
Ipswich England
Hi lilo, Fitted a C5 electronic Kit from Wisconsin. 38 duty paid ouch! It is a single fire set up, and works a treat. I too have a set of Rainer's cylinders, but use an SRM 90 Deg. Spitfire profile cam supplied new by them. I have yet to ride it yet, but it sounds a brahma. Standard siamese pipes but a single carb head for simplicity. I just fitted a Smiths electronic speedo, but have yet to calibrate it/finish wiring. Those GP's look great, I use a 30mm Mikuni. It has proven much easier to set up. You need WOT to appreciate those GP's I think. My bike can't hold a candle up to yours when it comes to good looks though. You've done a fantastic job of utilising the standard with the modern, good job mate.
Gavin
Re: A65 caf [Re: wbabojo] #553295
07/17/14 5:07 am
07/17/14 5:07 am
Belgium
Julian Offline
Julian  Offline
Belgium
Looks fantastic!
Absolutely love it!!
Soooooo glad you haven't succumbed to fitting modern Mk2 Amals!
Great!
Julian
Royal Enfield Works Trials
BSA Super Rocket Scrambler
BSA Gold Star Scrambler
Triumph Bonneville 1966
Laverda 750SF
Laverda "1000"SF
BSA Rocket 3
Norton Commando 850
Moto Morini 3-1/2 Sport
Moto Guzzi Le Mans 1
Ducati MHR 1980
Re: A65 caf [Re: lilo] #553359
07/17/14 3:36 pm
07/17/14 3:36 pm
england
lilo Offline OP
lilo  Offline OP
england
Don's speak too soon!!!!
Re: A65 caf [Re: lilo] #553453
07/18/14 2:24 am
07/18/14 2:24 am
Belgium
Julian Offline
Julian  Offline
Belgium
I think, Dump the wasted spark. Can't imagine it will be a clever thing going on in a 270/450 firing pattern.
Thought about it for my 90 degree Laverda 750/1000 project and decided I didn't like the idea. I have had bikes running extremely well on both TTs and GPs to find no reason that yours would not work. And they look so damn cool that it would be worth some sweat to get them right. And what is that old saying? 90% of carburetor problems are down to the ignition. ;o)
Good luck mate and again great looking bike!
Julian
Laverda 750SF
Laverda "1000"SF
BSA Rocket 3
Norton Commando 850
Ducati MHR 1980
Re: A65 caf [Re: lilo] #557547
08/09/14 12:55 pm
08/09/14 12:55 pm
england
lilo Offline OP
lilo  Offline OP
england
Thanks Julian and after loads of messing about I have to agree that the wasted spark is causing a lot of starting problems and worst of all the mother of all kickbacks.
We've got the carbs well sorted ;as my teenage daughters would say; The bike ticks over nicely and the pickup is crisp and sharp.
It sounds fantastic through the shorty mega.
Do you know who can make a good individual ignition system for a 90 degree without using the cheaper wasted spark design?
Any help would be greatly appreciated.
Re: A65 caf [Re: lilo] #557558
08/09/14 2:21 pm
08/09/14 2:21 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
A post further up this page from wbabojo says that he is successfully using an ignition system from 'C5', which is the same as 'PowerArc'.
They say their system can be run single fire on a 270 degree engine, but for the life of me I can't see how that is possible then it has only a single TDC sensor, and a second one that divides crank rotation into 4 degree intervals. Problem is that the TDC marker can correspond correctly only with one cylinder .. it will be out 135 degrees on the other ... and there is no way for the ignition to know which is which.
I've been interested in C5 and PowerArc for my own 270 degree Commando for some time, but have never been given the courtesy of an explanation of how it works ... all I get is "it's a secret, just believe us".
wbabojo, can you shed any light on this, and can you confirm that the C5 truly runs single fire?
... Gregg
Re: A65 caf [Re: lilo] #557589
08/09/14 5:48 pm
08/09/14 5:48 pm
Ipswich England
wbabojo Offline
wbabojo  Offline
Ipswich England
The coil that C5 supplied for my fitment, was a "Single Fire" coil, as they describe it. It is their mandatory fitment, for it charges in quick time and with enough power to send three pulses (Multispark)in quick succession every BTDC. From this, I can only guess it's a single fire system. I've only ridden it three times, today last time, to the MOT test. Reprogrammed the Smiths electronic speedo as well today (Correctly this time lol), and that too is a revelation. I'll PM you now Lilo, C5 are not a sponsor here FAIK.
Kind Regards
Gavin
Re: A65 caf [Re: lilo] #557636
08/10/14 12:48 am
08/10/14 12:48 am
Ipswich England
wbabojo Offline
wbabojo  Offline
Ipswich England
Well I would, but your box is full.
Kind Regards
Gavin
Re: A65 caf [Re: lilo] #557849
08/11/14 2:20 pm
08/11/14 2:20 pm
england
lilo Offline OP
lilo  Offline OP
england
Hi wbabojo, Sounds interesting. I've just emptied my PM box.
Re: A65 caf [Re: lilo] #557850
08/11/14 2:24 pm
08/11/14 2:24 pm
england
lilo Offline OP
lilo  Offline OP
england
Surely a single fire system would need 2 coils with 2 HT leads?
Re: A65 caf [Re: lilo] #558099
08/13/14 6:04 am
08/13/14 6:04 am
Belgium
Julian Offline
Julian  Offline
Belgium
http://www.elektronik-sachse.de/shopsystem/index.php?language=en
Try this link.
Extremely good system and they do a modified one specially for "Bent Cranks" Just ask them and it will be done.
julian
Laverda 750SF
Laverda "1000"SF
BSA Rocket 3
Norton Commando 850
Ducati MHR 1980
Re: A65 caf [Re: lilo] #558355
08/14/14 6:34 pm
08/14/14 6:34 pm
england
lilo Offline OP
lilo  Offline OP
england
Thanks Julian.
I'll see if they can sort one out for me.
Re: A65 caf [Re: lilo] #572496
11/16/14 4:21 pm
11/16/14 4:21 pm
england
lilo Offline OP
lilo  Offline OP
england
Managed to get the C5 ignition system from the States.
The first one arrived damaged ,not packed well, but they changed it immediately and now fitted the bike starts very easily.
Its a strange technology, only one pickup but with 2 coils and no wasted spark. You have to turn off the ignition turn over the engine a couple of times for it to reset itself in a 10 degree btdc position and sort out which cylinder it is going to fire and then it sparks ferociously with a triple spark from the chunky coils.
The Pazon system is not ideal for a 90 degree engine. Any system with a wasted spark will cause starting problems. 2 sets of points would be more applicable.
Page Time: 0.114s Queries: 16 (0.011s) Memory: 1.2195 MB (Peak: 1.5623 MB) Zlib disabled. Server Time: 2018-04-21 15:16:24 UTC
