jimt100
jimt100
Tennessee
200 registered members (68 royalstar tony), 1,991 guests, and 523 spiders.
Lou Quirch, Mark Masa, Jody Camak, analyse, Drifter
10042 Registered Users
Lannis 149
kommando 117
Stuart 60
479,420 mail-order LSR
Topics65,754
Posts635,650
Members10,041
Comet ignition timing for 8:1 comp. #555069
07/26/14 8:45 pm
07/26/14 8:45 pm
Concord Township, Ohio
57nortonmodel77 Offline OP
Hi all,
a friend dropped off his Comet to get the mag replaced & I will of course need to set the timing after the install. He has no manuals , or specs on the timing. It currently has 8:1 compression.
Can anyone recommend the correct ignition timing either in degrees, or inches before top dead center?
Thank you in advance,
Skip
Magneto & Dynamo restorations & supplies
My Bikes
1950 Norton Model 7:
1952 Norton ES2
1957 Norton Model 77
1960 Norton Nomad 600cc
1961 Norton ES2 (slimline)
1964 Norton Atlas Scrambler
1972 Bultaco Alpina
Re: Comet ignition timing for 8:1 comp. [Re: 57nortonmodel77] #555187
07/27/14 4:08 pm
07/27/14 4:08 pm
I am thinking about 1/2" BTDC ?
Thoughts?
My Bikes
1952 Norton ES2
1972 Bultaco Alpina
Re: Comet ignition timing for 8:1 comp. [Re: 57nortonmodel77] #555189
07/27/14 4:26 pm
07/27/14 4:26 pm
Thoughts?
My Bikes
1952 Norton ES2
1972 Bultaco Alpina
Re: Comet ignition timing for 8:1 comp. [Re: 57nortonmodel77] #555460
07/28/14 11:23 pm
07/28/14 11:23 pm
New Hampshire, USA
David Dunfey Offline
New Hampshire, USA
Originally Posted By: 57nortonmodel77
Hi all,
Skip
Skip,
With the ATD spring weights open to full advance it should be 36 degrees BTDC for a single plug ignition.
David
Re: Comet ignition timing for 8:1 comp. [Re: David Dunfey] #555500
07/29/14 7:54 am
07/29/14 7:54 am
Thanks David,
So 36 degrees BTDC would be .414" BTDC.
I have already set it at 1/2" and all seems well, but i'll reset at .414 & see how it does.
It has high compression pistons installed giving 8:1 comp., would I still use .414"BTDC ?
Skip
My Bikes
1952 Norton ES2
1972 Bultaco Alpina
Re: Comet ignition timing for 8:1 comp. [Re: 57nortonmodel77] #555532
07/29/14 10:42 am
07/29/14 10:42 am
New Hampshire, USA
New Hampshire, USA
Skip,
That is why I always used degrees, but I would think 1/2" is fine. It is only important if there are other things that are off, because you start second guessing your own work.
If you want to do degrees, because you find something else is wrong, you can make a spindle out of threaded rod and grind the end to fit in the crank shaft oil passage. You can access the crank by removing the brass nut at the bottom center of the timing cover. It is actually not a nut, but a quill delivering oil to the crank bearings. Cut the threaded rod long enough to clear the exhaust pipes and use two nuts to secure the degree wheel. There is a brass nut, or a decorative nut on the timing cover at the top center. I usually put a piece of wire under it as a pointer. Just make sure that whatever goes in the end of the crank is clean and you will be all set.
David
Re: Comet ignition timing for 8:1 comp. [Re: David Dunfey] #555678
07/30/14 10:41 am
07/30/14 10:41 am
Thanks David,
The only reason I guess I was questioning the degrees was because this engine has higher than standard compression pistons & wanted to be sure I has the timing adjusted for that.
I prefer to use a degree wheel, but in this case I had planned on using my spark plug hole tool simply to simplify the process.
Yesterday I used the 1/2" (40 degree) setting as a test. No pinging under a load & the performance seems very good. I may reset it at 36 degrees (.414) and compare the two settings.
Thank you for the advice on the degree wheel mounting!
All the best,
Skip
My Bikes
1952 Norton ES2
1972 Bultaco Alpina
