23 registered members (Bikeosaurus), 294 guests, and 434 spiders.
10291 Registered Users
Stuart 93
Lannis 66
Mori55 64
638,100 mail-order LSR
Topics67,396
Posts654,357
Members10,291
main timing pinion T140E #551692
07/07/14 2:48 pm
07/07/14 2:48 pm
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
Fitting this back tonight. It seems an extremely tight fit over the crankshaft end. Is it normally this tight? I see reference to 'drifting' it on, mid drifting or quite severe?? Any tips / advice welcome. Cheers.
Re: main timing pinion T140E [Re: MalRed] #551753
07/07/14 8:46 pm
07/07/14 8:46 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
According to the manual, it should have a maximum of 0.0005" interference fit.
It can be as loose as 0.0003" clearance, and still be OK.
Measure it. If it's too tight,you could polish the bore with a roll of emery paper to loosen it some.
Re: main timing pinion T140E [Re: NickL] #552059
07/09/14 2:42 pm
07/09/14 2:42 pm
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
Thanks. NEVER do work at night after a busy days work. Took your good advice and heated it up, picked it up with mole grips on the collar, it slipped on a treat. As it was cooling and gripping the crankshaft i looked at and saw I had put it on the wrong way round, idiot.
So now I have the flat side hard up against the case, no room for a puller, tried heating it up to pull off but the crank acts as a heat sink now so no budge!
I think I am faced with setting up the dremel, cutting through by the slot so I work towards the woodruff key.
I can't think of any other fix unless you guys can
Re: main timing pinion T140E [Re: MalRed] #552061
07/09/14 2:57 pm
07/09/14 2:57 pm
gastonia .. NC
limeyrider Offline
limeyrider  Offline
gastonia .. NC
Can you use a gas torch with narrow flame to heat directly on the hub to quickly heat it without the crankshaft sucking away the heat?.
Good luck.
James.
Re: main timing pinion T140E [Re: MalRed] #552062
07/09/14 3:03 pm
07/09/14 3:03 pm
devon
kevin large Offline
kevin large  Offline
devon
HOW FAR TOGETHER IS THE MOTOR IF ITS JUST THE CASES TOGETHER AND NO BARRELS SEPERATE THE CASES SUPPORT THE TIMING SIDE CASE ON BLOCKS OF WOOD PUT SOMETHING SOFT UNDER THE CRANK TO CATCH IT GET A GOOD BLOW TORCH HEAT THE PINION QUICKLY AND TAP THE END OF THE CRANK THROUGH THE PINION USE A PIECE OF ALLOY TO PROTECT THE END OF THE CRANK
Re: main timing pinion T140E [Re: limeyrider] #552074
07/09/14 4:53 pm
07/09/14 4:53 pm
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
Good idea, i will pursue that one
Re: main timing pinion T140E [Re: kevin large] #552076
07/09/14 4:54 pm
07/09/14 4:54 pm
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
Totally, barrels on, cyl head on.
Re: main timing pinion T140E [Re: MalRed] #552215
07/10/14 5:08 pm
07/10/14 5:08 pm
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
Any tips on sourcing a new pinion, don't see many out there. T140E main crank pinion gear.
Re: main timing pinion T140E [Re: MalRed] #554202
07/22/14 4:48 am
07/22/14 4:48 am
Herts UK
MalRed Offline OP
MalRed  Offline OP
Herts UK
All done, my amazing engineer Roger at Full Bore Watford, welded a nut to a washer, the washer to a tube, then the tube to the offending pinion. He effectively created a 'puller' and off she came. I will try to upload a pic next.
