smitty
smitty
cleveland,ohio
29 registered members (AML), 271 guests, and 385 spiders.
goatroper, Hawaii70BSA, itomtom, Wristpin, Mom1
10450 Registered Users
NickL 69
Jeff K. 60
DavidP 57
735,545 mail-order LSR
Topics68,592
Posts668,054
Members10,450
con rod big end roller 'play' #553549
07/18/14 4:01 pm
07/18/14 4:01 pm
Pacific northwest
quinten Offline OP
quinten  Offline OP
Pacific northwest
My 67 T20M's con rod has what appears to be a roller-bearing big-end
How much , if any , up and down play is acceptable ? ( I'm not dying to split the cases)
There is discernable play , quite a bit side to side and I'd guess around 0.1mm
In and out
Re: con rod big end roller 'play' [Re: quinten] #553553
07/18/14 4:30 pm
07/18/14 4:30 pm
Not familiar with the tolerances for the Cub's but the big singles are not supposed to have any up and down play.
Wasn't that late Cub roller big end like a needle roller?
Re: con rod big end roller 'play' [Re: Boomer] #553577
07/18/14 5:56 pm
07/18/14 5:56 pm
No up and down, side to side is easily confused with it but side to side is ok.
Re: con rod big end roller 'play' [Re: quinten] #553582
07/18/14 6:17 pm
07/18/14 6:17 pm
John Healy Offline
John Healy  Offline
If my calculator is right .1 - .0039". I need to use one of Stuart's shocked to express my feelings.
.001" would be more like what you were looking for to be cool
Re: con rod big end roller 'play' [Re: John Healy] #553633
07/19/14 12:55 am
07/19/14 12:55 am
Using just feel you start to detect play at 3 thou, so once you can feel it by pulling and pushing on the rod you are at a minimum of 3 thou play.
Re: con rod big end roller 'play' [Re: quinten] #553688
07/19/14 9:12 am
07/19/14 9:12 am
John Healy Offline
John Healy  Offline
Kommando is right and you can experience this when adjusting Triumph rockers to .002" intake and .004" exhaust.
At .002" there is no vertical movement, but the rocker will slide freely side to side against the spring.
As you approach .004" clearance you will begin to feel vertical rocker movement and at .004" you will hear and feel the rocker "click." This can be verified using a dial indicator.
.002" vertical movement on a Cub rod is the absolute upper limit. While the engine will continue to run with a rod with more than .002" vertical clearance it is not if it will fail, but when.
Re: con rod big end roller 'play' [Re: quinten] #553713
07/19/14 12:02 pm
07/19/14 12:02 pm
lancashire united kingdom
run990 Offline
run990  Offline
tiger cub big ends are a weakness ,place a feeler gauge down the side of the big end eye that just takes up any side float.blast a load of petrol into the roller cage to remove any stiction from oil.then test for up & down play at various positions during rotation.if its suspect change it before it wrecks the rod.
Re: con rod big end roller 'play' [Re: quinten] #553717
07/19/14 12:32 pm
07/19/14 12:32 pm
Alpha made a rod/roller bigend conversion to replace the plain shells.
Any Cub run hard needs one.
As the first unit single these engines are lucky to have bushings at all.
Re: con rod big end roller 'play' [Re: run990] #553738
07/19/14 3:30 pm
07/19/14 3:30 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
Originally Posted by run990
<SNIP> blast a load of petrol into the roller cage to remove any stiction from oil. then test for up & down play at various positions during rotation.if its suspect change it before it wrecks the rod.
Run990 makes two good points that warrant repeating with the "reason why",in case they get missed. Big ends do not wear uniformly because of the reciprocating loads they carry, and also, the presence of oil in a bearing will mask wear.
So be sure to check the bearing dry, and inspect for slop at every orientation you can manage ... while it may 'feel OK' in one position, it may be beyond its allowable limit at a more heavily loaded position.
... Gregg
magneto@spyder-it.com
Re: con rod big end roller 'play' [Re: gREgg-K] #553822
07/20/14 4:02 am
07/20/14 4:02 am
Pacific northwest
quinten Offline OP
quinten  Offline OP
Pacific northwest
Some late model Cubs came with a roller big-end , others may have been fitted with one over time. I have yet to see mine .
I have blasted it with wd40 ( to de-oil) and more than triple checked it from multiple positions , its not so easy to isolate the side to side from the up and down
On a roller bearing you cant see ... so I placed a wood 1x1" against the conrod , front to back on the engine case , to minimize lateral movment ... and can "feel" consistant slight movement , up and down , from all positions where the little end is high enough to work with ... and hear the slightest ' tink -tink' as the rollers move in their races . No spots feels bad , different or worse than any other , but the amount of play is disheartening.
The p.o. installed a poorly-fit under-sized 10:1 piston in the cylinder with no discernable hone , which allowed front and back scoring of both the piston and bore ... and just tonite , on closer inspection , I now see how
The original over sized intake valve , for this model , has " kissed" this new high-dome piston . I now see why the
P.O. could not get it running "right" ... i am slowly getting used to the idea of having to split the cases on this low mileage bike ... and my growing 'things to buy list'
Re: con rod big end roller 'play' [Re: quinten] #553858
07/20/14 9:02 am
07/20/14 9:02 am
Fit the lower cr piston for a start. I fitted a Todd racing head to the D14 once. The head was designed for the low cr d7 but I placed it on a already 10:1 piston. It didn't run any better just became a bit noisier on the bearings.
I'd suggest if your in any doubt of the big end, get it done. That way you know it's right and will give you many years of good service. Otherwise you'll be preying for that bit between your legs in the hope it doesn't fail you ( the engine i mean wink )
