ADC
ADC
CALIFORNIA
206 registered members (57nortonmodel77), 2,327 guests, and 681 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,353 mail-order LSR
Topics66,021
Posts638,989
Members10,073
Mainshaft Nut Backing Off #553637
07/19/14 1:09 am
07/19/14 1:09 am
Monterey, CA
stugs Offline OP
stugs  Offline OP
Monterey, CA
I have a TR25W basket case I finally finished getting back together. I took it for a test ride and about 5 minutes in the clutch ceased springing back.
I took the timing cover off and the mainshaft nut, which was new, had backed itself off and stripped some of the threads (of the nut). I did some searching and it appears lots of folks have recommended using loctite.
Before I pick up a new nut and get things back together tomorrow, I was curious if anyone had other suggestions.
matt
Re: Mainshaft Nut Backing Off [Re: stugs] #553657
07/19/14 4:30 am
07/19/14 4:30 am
dave jones Online content
dave jones  Online Content
Did the clutch hub come off the taper on the mainshaft or did the centre slide on the hub? You can grind the hub to the centre or you can clean it and use a little powdered chalk dust to help the tapers grip. On mine I used some blue loctite 243 on the treads and torqued the nut to the figure in the manual.
dave
Re: Mainshaft Nut Backing Off [Re: stugs] #553689
07/19/14 9:12 am
07/19/14 9:12 am
The mainshaft under the timing cover should have a tab washer under the nut but loctite blue will suffice for now as long as you torque it correctly.
Re: Mainshaft Nut Backing Off [Re: stugs] #553690
07/19/14 9:14 am
07/19/14 9:14 am
John Healy Online content
John Healy  Online Content
And the threads were free of oil when the Loctite was applied.
Re: Mainshaft Nut Backing Off [Re: stugs] #553725
07/19/14 1:51 pm
07/19/14 1:51 pm
Monterey, CA
stugs Offline OP
stugs  Offline OP
Monterey, CA
Thanks all. I just installed a new nut + tab washer with loctite blue. Shakedown run #2 in 24hrs when this sets up.
matt
Page Time: 0.111s Queries: 15 (0.007s) Memory: 1.0151 MB (Peak: 1.1650 MB) Zlib disabled. Server Time: 2018-02-21 14:38:49 UTC
