Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
Later type QD rear wheel in a CB32 frame? #553146
07/16/14 2:16 am
07/16/14 2:16 am
Orygon
F
farrandr Offline OP
farrandr  Offline OP
F
Orygon
Trying to find an original 50's B33/B34 rear wheel for the swing arm CB32 frame is pretty impossible. So is it possible / practical to use an A65 / B44 QD wheel in the CB32 swing arm frame?
Main considerations being:
1) rear sprocket alignment to STD gearbox
2) correct rear wheel rim orientation to swingarm fork centre and
3) axle diameter of 17mm.
If possible to use the later QD wheel hub, it would seem that the detachable rear sprocket is something of an advantage?
Thanks in advance for any help.
Farrand
'55 Ariel Sq 4
Framecrafters North-Seeley Hurricane R3
'65 BSA Hornet
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553150
07/16/14 3:11 am
07/16/14 3:11 am
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
Pity you didn't mention it a couple of weeks ago -just disposed of a wheel, and complete QD brake drum setup.
I have seen the later setup used, with the alloy backplate. The removable sprocket would be an advantage.
Oliver Wendell Holmes
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553154
07/16/14 4:11 am
07/16/14 4:11 am
You need to be careful, BSA made lots of small but potentially significant changes to these bits.
http://britbike.com/forums/ubbthreads.php?ubb=showflat&Number=551491#Post551491
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553201
07/16/14 1:42 pm
07/16/14 1:42 pm
Orygon
F
farrandr Offline OP
farrandr  Offline OP
F
Orygon
Thanks much, I purchased a complete A65 QD rear wheel from a salvage operator. It is complete with brake drum , brake plate and shoes, etc and has the 530 sprocket in good shape. Since this project is a custom I'm hoping it will work out well. Thanks again for the advice, that is what makes this forum so invaluable.
Farrand
'55 Ariel Sq 4
'65 BSA Hornet
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553230
07/16/14 4:21 pm
07/16/14 4:21 pm
duncannon penna
penna-john Offline
penna-john  Offline
duncannon penna
the sub axle that goes thru the brake drum is shorter on the singles--b31 as there should be no spacer between the brake plate and swingarm like the twins have, i just fitted a twin wheel to a bb32r frame, i had to remove the subaxle and grind the flats further and reinstall it with the spacer to the outside of the frame, now my sprockets line up
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553357
07/17/14 3:30 pm
07/17/14 3:30 pm
If you have the steel brake plate you should be able to make it work with tweaking. If you have the later alloy brake plate it will be more difficult in that most or all of the outside centre extension will need to be milled off to align the sprocket. As for the rim position you should be able to shift as needed.
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553378
07/17/14 5:02 pm
07/17/14 5:02 pm
duncannon penna
penna-john Offline
penna-john  Offline
duncannon penna
also i used a steel brake plate, see above
Re: Later type QD rear wheel in a CB32 frame? [Re: farrandr] #553571
07/18/14 5:34 pm
07/18/14 5:34 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
Some years ago I was building up GS racer for a friend with pieces from his 'boxes'. aarrgh. He wanted to use a A65 rear wheel assy He had on hand. All looked OK, but Not! There were many differences from the earlier, ie Goldie parts. BSA had increased in size any dimensions on the A65s. The stub axle diameter was greater, The spline drive was larger, a larger diameter axle was used with larger metric bearings in the hub and drum. Yeah, it could of been used on a Goldie with some machine work. But why bother?
I have no idea what year A65 this wheel assembly was from, but I understand earlier A65 wheels & hubs are different and much the same as a Victor's?
and speaking of Victors ...
Some time ago I adapted a Victor alloy backing plate for use on my Goldie much modified 'Special' with a late GS 'bolt on sprocket' brake drum. As I remember I had the center extension milled down for a total width equal to the thickness of a steel backing plate and the steel spacer. I could than fit a Victor 520 bolt on sprocket to allow using a sealed 520 'X Ring'.
Also ... with a bit of lathe work a Victor rear axle can be used on a Goldie. This gives you a hex head that will fit your tool box plug socket. The increased diameter shoulder area next to the hex head needs to be machined off and it needs shortening about 1/8" by trimming the threaded end.
And you can use a Victor splined hub by removing the speedo drive and fitting a Huber hub cover to fit the smaller diameter threaded hub.
Dave - NV
