Blapper
Blapper
Kent UK
14 registered members (Carl), 204 guests, and 409 spiders.
10419 Registered Users
btour 85
Rohan 77
Triless 70
reverb 68
713,588 mail-order LSR
Topics68,326
Posts665,175
Members10,419
Carb Manifold Question 67 Bonneville #548496
06/14/14 6:52 pm
06/14/14 6:52 pm
USA
Dave M Offline OP
Dave M  Offline OP
USA
I am assembling the carb manifolds, 67 Bonneville. Both refuse to go farther than 1,1/2 turns and are far from seating against the shoulder to the rear of the head. There is no evidence of cross threading.
How far into the head must these travel? If too shallow might there be a clearance issue with the tanks' petcocks?
Wrong part? Did threads change by year?
I lack a thread gauge which might answer my question.
I'm usure how to solve this, appreciate any help. eek Thanks! dave
This shows 1,1/2 turns in, will travel no farther.
The threads of each.
66 TR6R Trophy
67 T120R Bonneville
68 BMW R60/US
69 T100R Daytona
Re: Carb Manifold Question 67 Bonneville [Re: Dave M] #548508
06/14/14 7:33 pm
06/14/14 7:33 pm
Kent, UK
Nick_Smith Offline
Nick_Smith  Offline
Kent, UK
The threads in the head look finer than those on the stubs.
Rather than trying to force them in, I'd invest in a thread gauge and see what you've got.
Nick
"1967 TR6R"
Re: Carb Manifold Question 67 Bonneville [Re: Dave M] #548516
06/14/14 8:02 pm
06/14/14 8:02 pm
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
Yes, the threads changed somewhere around '69 at a guess.
Re: Carb Manifold Question 67 Bonneville [Re: Dave M] #548544
06/14/14 11:22 pm
06/14/14 11:22 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
From about '64 until mid '72,the thread was 1-3/8" x 16 tpi.It would have been a BSC thread up until '68 model.Your manifolds look right for '67.'69-onward manifolds have brazed-in studs.
The threads would have been UNF form from '69 onward.Even though it's the same pitch and thread angle,a UNF thread is effectively smaller than a BSC thread because of the different nose radius.On a thread with that pitch (16 tpi),it amounts to a little over 0.007" difference.
The '67 manifolds would probably have trouble screwing into a '69-onward head,unless you ran a BSC tap into the head first.
Re: Carb Manifold Question 67 Bonneville [Re: Dave M] #548553
06/15/14 12:09 am
06/15/14 12:09 am
australia
tiger_cub Offline
tiger_cub  Offline
australia
Is there a set distance that the flange sits away from the head? On my T120C I got replacement manifolds & I am struggling to fit the unified airfilter in (actually it won't go in due to the carb float chamber on the right side even though there is a cutout in the filter plate there!)
1970 TR6C
1970 TR6R
Re: Carb Manifold Question 67 Bonneville [Re: Pete R - R.I.P.] #548581
06/15/14 7:56 am
06/15/14 7:56 am
USA
Dave M Offline OP
Dave M  Offline OP
USA
I'm reasonably certain the head is original to the engine, it is stamped 66.
Printing your reply Pete, and will buy a thread gauge. Most helpful, thanks to all. :bigt dave
66 TR6R Trophy
67 T120R Bonneville
68 BMW R60/US
69 T100R Daytona
