27 registered members (Andy Higham),
267
guests, and 176
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,558
Posts645,239
Members10,172
Most Online3,995 Feb 13th, 2017
Re: BSA C15/SS80 cruising speed?
[Re: kommando]
#546395
06/02/14 4:11 am
06/02/14 4:11 am
Posts: 1,666 Canada
LarryLebel
Canada
At 65 you ass and hands will go numb so you won't be riding at that speed very long even if you could.
[Re: downhere]
#546840
06/04/14 11:05 am
06/04/14 11:05 am
Posts: 7,813 Seattle
Alex
Yeah, and then your conrod will come up and hit your chin! Happen to you a lot? Mind you the taller gearing helps here because there is another weakness, particularly in the C15S/SS and that is that with low gearing they will pull right past where they should. The roller big ends don't like revs over 8000 rpm (the rollers don't roll any more, they slide). This I know from experience  . Mind that limit, though and a properly assembled roller big end will tolerate just about anything other than running out of oil.
A smattering: '53 Gold Flash '67 Royal Star '71 Rickman Metisse '40 Silver Star '37 Rudge Special sixtyseventy Lightboltrocket road racer...and many more.
[Re: Alex]
#546854
06/04/14 12:25 pm
06/04/14 12:25 pm
Posts: 4,279 U.S.
Magnetoman
a properly assembled roller big end will tolerate just about anything other than running out of oil. The C15 doesn't get the respect it deserves, largely because of people repeating things they had heard of problems suffered 50+ years ago by the very earliest non-roller bearing engines. My C15S (with roller bearing) suffered ~5000 miles of hard use at my hands before I turned it over to John O'Regan in Cork, Ireland to undo the cumulative damage I had done. I've subsequently put another ~1000 miles on it, with all ~6000 miles spent making it keep up with the 500s and 650s I ride with when I'm using that bike in Ireland. As I wrote in an earlier post I have my C15S geared for a redline of 84 mph and it purrs along effortlessly at the 45 mph many of the roads limit it to. However, when needed to keep up with the bigger bikes on main roads it goes miles at a stretch at 65 mph, with power to pass cars even at that speed. However, I try to limit top speed to 65 because the bike is located thousands of miles from me so I want it to last a reasonable length of time between major work. Two more things about a C15S. Wherever roads limit top speeds to ~45 mph a 250 performs as well as a 500. Or, even better, in that it is more maneuverable. Also, at the end of a long day, when it's time to start the bike one last time for the ride back to the hotel, kickstarting a 250 is a lot nicer than kickstarting a high compression 500.
[Re: sprung hub]
#546916
06/04/14 6:31 pm
06/04/14 6:31 pm
Posts: 85 Sacramento, CA
sprung hub
Sacramento, CA
Thanks Alex! I will have to strobe time it, and I've only just sorted out the jetting. I ended up going with a new Concentric. It's close and certainly rideable as is, but still a tick rich. Dean
[Re: sprung hub]
#546934
06/04/14 7:57 pm
06/04/14 7:57 pm
Alex
Thanks Alex! I will have to strobe time it, and I've only just sorted out the jetting. I ended up going with a new Concentric. It's close and certainly rideable as is, but still a tick rich. Dean It's a bit of a pain since you have to take the primary cover off and have to make your own marks, but well worth it.
