MusketVtwin
MusketVtwin
columbus ohio
43 registered members (Al Eckstadt), 272 guests, and 471 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,061 mail-order LSR
Topics67,365
Posts654,057
Members10,288
Rebuild Smiths Gauges (Speedometer Tachometer) #487125
04/23/13 8:34 pm
04/23/13 8:34 pm
FL
Redshirt Offline OP
Redshirt  Offline OP
FL
I wrote this article for my British car club newsletter last month. Please tag on with comments if I've missed something or you have a tip or trick I've missed. Please PM me if you'd like to re-post or reprint somewhere--I'm happy to help.
If your English bike or car has a speedometer or tachometer built in the late 1950s or later that just does not Ďmeter right, youíve probably either tried to pretend it was a transient problem that would go away as mysteriously as it appeared or looked into sending your instrument off for restoration. If youíve done the later, you probably recoiled at the shocking cost of having someone restore the instrument for you.
Iím not here to tell you that restoration services are a rip off. Theyíre not. The last quote I saw was $260 for a gauge restoration. That included new glass, bezels, rubber parts, new face, cleaning, painting, shimming, re-bushing, and calibration amongst other things. The end result IS fabulous for a concourse restoration. However, if you are cheap and/or not doing a concourse restoration, there is a lot you can accomplish at home with patience and a more palatable outlay of cash. The above assumes that your instrument has an acceptable face and that the internal mechanism is only dirty or maladjusted rather than worn out.
Some of the larger automotive gauges have locking bezels that are removable. If so, thatís great. Just twist off the bezel and protect the glass at all costs. For the motorcycle crowd, Smithís rolled the back lip of the bezel over to improve the instrumentís weather resistance and seemingly to ensure you couldnít get into the gauge ever. I donít know about you, but Iíve prided myself over the years on fixing items that have no user serviceable parts. Iíve opened up sealed relays and emissions valves to get them back into commission, so it was no surprise to find myself carefully prising up the rolled lip on my Ďsealedí BSA tachometer.
Iíve been inside my Jaguarís tach and speedo before, so I expected this was no different. It wasnít. Of course I broke the glass getting the bezel off, but the bezel kits come with new glass and seals in addition to the replacement bezel. I just ordered two kits to the tune of $40 each from Eurojamb.com. They are nice kits and really the only big cash outlay for this project. I twisted a screwdriver for a while to get the bezel off. Caution, this is a great way to end up at the emergency room with a screwdriver through your hand. Take my advice, just grind the rolled edge off. Itís false economy to try and save the bezel. Once the bezel and glass are off, save the glass if it hasnít broken yet. You never know when a spare might be handy. Now remove the screws from the back and separate the core from the case, being very careful not to disturb the needle.
Relocate the project to your sterile bench, above your meticulously clean floor that will allow you to find the parts you are about to lose.
Underneath the gauge face, you will see a section of the frame and a silver pickup disk that moves when you move the needle. With the needle at rest against its peg, take a Sharpie and make a mark that crosses both the disk and the frame. This is the witness mark that will later let you correctly locate the needle when you reassemble the gauge. Note, this is much harder on a speedometer than a tach as the odometer mechanisms hinder access.
If able, round up an assistant to steady the gauge. Protect the gauge face with some tape, plastic, or heavy paper and place the tips of two blade screwdrivers under each side of the needleís center boss. Twist them equally to apply even pressure to both sides of the needle to remove (launch) the needle. After you and your assistant have recovered the needle, open some beers. The hard part is over.
Now itís time to remove the face, which is held on by rivets! Donít despair, take a closer look. These are actually reusable and removable. Take a jewelerís screwdriver or other small tool and push the small dowel all the way through the rivet. Recover the dowels and the rivets. Lift off the gauge face. There is a tiny wire poking through the face that the needle rests against at zero speed or RPM. It is actually the end of a spring welded to the back.
Pull this spring wire back through its hole and let it rest against the back of the face. Wash the face and needle with mild soap and water. After you have dried the parts, go over the center boss of the needle with metal polish and a rag. Use a good quality wax and rub down the gauge face. This cleans the face further and takes away any oxidation.
Before doing any further disassembly, locate the adjustor screw on the back and screw it in tight, counting how many half turns it takes to hit the stop. Write it down! When you reassemble the gauge, youíll use this number to restore the instrument to its pre-disassembly adjustment.
Go ahead and remove the top frame bar along with the adjuster lever. Unscrew the adjuster from the back, and then remove the top reusable rivets. The whole assembly of spring, shaft, top brass bar, adjustment lever, and pickup disk should all come away. Wiggle the needle shaft to check for excess play. If the needle shaft has a lot of side to side movement, your instrumentís bushing has expired. A worn bushing will likely cause the needle of your gauge to jitter after you reassemble it. If you need the gauge re-bushed and feel up to more advanced work, this link: http://bullfire.net/Triumph/Triumph34/Triumph34.html
features a great tutorial on soldering in a new bushing.
Now itís time for the final disassembly. Remove the cap from the bottom of the shaft. It just pulls off. If this cap is missing, youíve probably just solved the problem that led you here in the first place. Without the cap, the cable sheath tightens against the rotating shaft of the gauge, locking it in position. When the inner shaft tries to spin, it canít and shears. Find a right-sized long socket or punch and drift the central shaft out through the bottom of the gauge. Collect the shaft, worm gear, and magnetic disk.
Clean the parts, particularly paying attention to the bushing on the inside of the frame. Metal polish is a good choice for this job, just make sure to clean out all of the polish.
Lube the bushing and shaft with grease. Donít overdo it. Any excess will foul the inside of the gauge.
Drive the worm gear onto the shaft and check for end float.
You want as little play as possible without binding the free movement of the shaft. Drive on the magnetic disk as well and make sure you havenít eliminated the end float.
Replace the spring, shaft, top brass bar, adjustment lever, and pickup disk. Screw the adjuster in until it hits the stop, then back it out by the number of half turns you recorded during disassembly. Install the cleaned instrument face.
Turn the pickup disk to line up with the witness marks and carefully press on the needle such that it is touching the stop peg with the witness marks aligned.
Paint the case and open another beer.
Test functionality of your rebuilt core by hooking up a drill with a screwdriver tip sized to engage the square receptacle in the back of the instrument.
With the drill turning counterclockwise, you should see the gauge register. The odometer isnít adjustable, but the needleís rate is. For a ballpark calibration, it should take about 18 seconds to go a 10th of a mile at 20 mph. To calibrate a tach, youíll need to dig up an old dwell meter and use the RPM function. For a single ignition coil driving on a twin cylinder, multiply the dwell meterís RPM reading for an eight cylinder engine by four to get an accurate motorcycle RPM.
From your bezel kit, install the replacement rubber and screw the core back into the case. Clean the inside of the glass and place the glass and bezel on the instrument. If you have a big automotive gauge, twist the bezel into place and be done with the job. For the motorcycle crowd, place the bezel against a piece of soft wood and compress gently in a vice. If you somehow figure out how to roll the back edge of the bezel without the special factory tool, thatís great.
For me, my BSA gauges go into the big rubber bosses, so no one will ever see my handiwork. I will take a punch and bend over the bezel in about eight places. No, this wonít seal out the weather, but I can always add silicone sealant. What this approach does get me is a second chance to ever get back inside if I need to.
Congratulations, you did it yourself and it is a thing of beauty!
Redshirt
Redshirt
'67 BSA Lightning--A collection of Helicoils held together by matching numbers
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #487529
04/26/13 1:57 pm
04/26/13 1:57 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
Lots of good info and "how to" tips here, Thanks!! I have been working up the v
nerve to try this, and your post comes at the perfect time!
Oops,.. add 1 Sporty
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #541078
05/03/14 1:41 pm
05/03/14 1:41 pm
Kendallville, IN - USA
Hoosier Daddy Offline
'67 BSA Spitfire MkIII
'67 BSA Victor Roadster
'81 Honda GL1100
'80 Suzuki GS750
'72 Honda CB450 K5
'81 Honda CB750
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #541118
05/03/14 8:16 pm
05/03/14 8:16 pm
Westminster, Colorado
stubbicatt R.I.P. Offline
Have you a tutorial for the chronometrics?
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #545451
05/27/14 4:15 am
05/27/14 4:15 am
South Australia
Ponce Offline
Ponce  Offline
South Australia
Thanks for the great info. New at this game but having a go.Can U please tell me what type of grease U use for the main shaft?
Regards Ponce
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: stubbicatt R.I.P.] #545560
05/27/14 8:02 pm
05/27/14 8:02 pm
Australia
downhere Offline
downhere  Offline
Australia
Here you go. It's taken me 5 years to get around Chronos! http://www.hells-confetti.com/Technical%...20mechanism.pdf Although this article refers to car types the only difference is the lack of the warning device on the car version. There are other tutorials also on google.
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #545664
05/28/14 11:49 am
05/28/14 11:49 am
Thanks for the tutorial and the great pictures. The only reason I have to explore the inside of my speedo is to correct the adjustment (reads about 10mph fast.) I can see the screw through one of the lamp sockets, but the bugger won't turn.
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: DavidP] #545680
05/28/14 1:26 pm
05/28/14 1:26 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
The adjustment screw sits in a bit of a recess within the instrument's frame. It has a knurled head, and is locked in place by a center punch mark from the side.
It is fairly easy to turn with a screw driver held head-on, but can't imagine how you'd turn it, coming in from the side.
If you're careful with a shallow brad point bit, you might try drilling an access hole from the rear, but I'd be concerned about the swarf getting into the works ... it is magnetic after-all.
In your shoes I would bite the bullet and open it up.
.. Gregg
magneto@spyder-it.com
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #545819
05/29/14 12:08 pm
05/29/14 12:08 pm
Merry Point VA
W
wildbill Online content
wildbill  Online Content
W
Merry Point VA
An ultra sound cleaner works well on this project. Northern Tool has them for around $20, less with coupon. Lots of other bike uses, work well on most small parts, carbs, etc.
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #545824
05/29/14 12:37 pm
05/29/14 12:37 pm
Death row next in line norfolk
Tribsauk Offline
Tribsauk  Offline
http://www.britbike.com/forums/ubbthread...9309#Post519309
My solution to the problem... Dave
1941 BSA WM20
1958 TRI-BSA 750 PRE UNIT
1957 THUNDERBIRD
1932 R E MODEL GS SPECIAL
1947 BSA YM21
Re: Rebuild Smiths Gauges (Speedometer Tachometer) [Re: Redshirt] #545959
05/30/14 12:17 pm
05/30/14 12:17 pm
Clarkston, MI
redmosquito1 Offline
Clarkston, MI
Great write up, thanks I'll be tackling this project shortly. I know my speedo trip will not reset and the knob pulls out easily. I think someone stripped it possibly prior to my owning. Is it possible to repair that or should I start looking for a new gauge?
Thanks again
