slug
slug
hereford uk
39 registered members (998John), 296 guests, and 469 spiders.
10257 Registered Users
Stuart 77
Lannis 55
TBolt72 47
611,168 mail-order LSR
Topics67,154
Posts651,698
Members10,257
Rating: 4
Triumph pre unit... stumped - oil seal crank? #542969
05/13/14 8:18 pm
05/13/14 8:18 pm
T120C Offline OP
T120C  Offline OP
Ok guys, I hope this is not a dumb question, but I just can't figure it out... Been trying to, reading all the books, parts pages and online... So in this first pick, the seal that I am referring to is part number 44.. Some list it as a piston pressure relief, it is the same part number as a triumph cub fork seal..
This is primary side, where I think this thing would go, in the recess..
The seal with the typical inside wound spring looking band..
I have tried, and tried... ordered new ones and tried again but it just won't fit. I have ruined about 3 of these, but just can't seem to make it work. I can get one side started but that is it..
What am I missing here?? am I way, way off base in my thinking and interpretation of the parts book?? Oh yeah, 59 bonnie engine...
Thanks in advance, you all have been an amazing help in this long, long, long restoration!!! Thanks
Jack
1967 MGB Roadster..
1959 Bonnie
1967 Bonnie in disguise as a Trophy
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #542977
05/13/14 8:57 pm
05/13/14 8:57 pm
John Healy Online content
John Healy  Online Content
So if I read this right you are asking if the same seal (97-1168) used in late non-unit front forks is also used on the front engine sprocket. Yes, this is the case!
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #542981
05/13/14 9:10 pm
05/13/14 9:10 pm
T120C Offline OP
T120C  Offline OP
the real question is, why won't this fit??
Jack
1967 MGB Roadster..
1959 Bonnie
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #542983
05/13/14 9:34 pm
05/13/14 9:34 pm
What tool are you using? These seals are usually installed before the crankshaft is installed. Failing that you need to make a tool. The i.d. should be a slip fit on the crankshaft. This keeps the end of the tool square with the crankcase. The tool needs to be longer than the shaft so you can tap on the end with a hammer. The face of the tool should be slightly larger than than the o.d. of the seal.
A tool can be made from a couple of drill jig bushings which are a slip fit on the crankshaft and have a head larger than the seal.
You will never be successful trying to tap this seal in with a hammer and drift!
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #543042
05/14/14 6:34 am
05/14/14 6:34 am
T120C Offline OP
T120C  Offline OP
Thanks John, that's exactly what I needed to hear. Off to tool making!!! thanks again..
Jack
1967 MGB Roadster..
1959 Bonnie
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #543060
05/14/14 9:07 am
05/14/14 9:07 am
Ontario Canada
Bob Buchanan Offline
Ontario Canada
Hi T120C:
While its no easier to install, seal should be installed with spring on primary side.( to aid crankcase breathing since 1958 ). Also removing sharp edge of hole with utility knife helps too.
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #543061
05/14/14 9:09 am
05/14/14 9:09 am
bac o burk qld
dommie90 Offline
dommie90  Offline
bac o burk qld
try a box spanner thats what i have usad in the past
baz
62 t/bird
61 dommie99ss
61 b441bsa
71 tr5t
71 commando dunstall rep.
guzzi breva
and other crap
Re: Triumph pre unit... stumped - oil seal crank? [Re: Bob Buchanan] #543068
05/14/14 10:38 am
05/14/14 10:38 am
T120C Offline OP
T120C  Offline OP
Originally Posted By: Bob Buchanan
Hi T120C:
So Bob, you are saying install rubber side out?? if so I was thinking this totally wrong!!!
Jack
1967 MGB Roadster..
1959 Bonnie
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #543110
05/14/14 2:50 pm
05/14/14 2:50 pm
HawaiianTiger Offline
I was gonna say something, but....
I've always installed them so that junk can't get IN the engine, not to seal oil inside. I've seen them both ways, and not sure if it makes a difference. After all, it took Triumph quite a few years before they decided it was a good idea. Early bikes don't have a seal at all.
I've always used a block of wood before the crank was installed, laid it flat across the seal and gave it a good whack. Dressing the edge of the hole is a good idea.
Re: Triumph pre unit... stumped - oil seal crank? [Re: T120C] #543119
05/14/14 3:44 pm
05/14/14 3:44 pm
T120C Offline OP
T120C  Offline OP
Thanks Bill, I will see what I can do to make a suitable drift and put this seal in...
I appreciate all the help y'all
Jack
1967 MGB Roadster..
1959 Bonnie
Re: Triumph pre unit... stumped - oil seal crank? [Re: HawaiianTiger] #543132
05/14/14 4:37 pm
05/14/14 4:37 pm
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
Looks like a block of wood with the proper size hole drilled in it plus some P-80 would do the trick.
Re: Triumph pre unit... stumped - oil seal crank? [Re: desco] #543258
05/15/14 3:44 am
05/15/14 3:44 am
Rotorua, New Zealand
'59 Bonnie Offline
'59 Bonnie  Offline
Here are John Nelson pre unit service notes. I just quickly breezed over it. John makes no mention of the seal, maybe he installs it later. One interesting thing though is he talks a LOT about Loctite.
"We are "motorcyclists" & "historians" our hobby includes the research & preservation of motorcycle history. What we are doing in the research & preservation of iconic bikes is, an important part of its history & value".
