Mike W.
Mike W.
North Bay Ontario Canada
204 registered members (68 royalstar tony), 1,786 guests, and 593 spiders.
10032 Registered Users
Lannis 145
kommando 102
476,359 mail-order LSR
Topics65,713
Posts635,151
Members10,032
burman gb gearbox #54069
05/03/07 2:54 am
05/03/07 2:54 am
quinlan tx
propwash Offline OP
propwash  Offline OP
quinlan tx
I'm working on a Burman GB (b-52) gearbox for a project,and I was wondering how to find OEM part numbers for the different brands of bikes without buying several parts catalogs.I have been told that Burman has it's own numbers and some manufacturers use their own numbers. Can anyone enlighten me?
Re: burman gb gearbox #54070
05/07/07 7:29 pm
05/07/07 7:29 pm
Bangalore, India
Naozar R. Garda Offline
Bangalore, India
Propwash, I just 'Googled' "Burman Gearbox" and found several sites which may be of help to you. (I havent had the time to explore these as yet) (I am looking for a Burman GB (B52) kick starter lever for my Matchless G3LS 1955.) Hope you find what you want. Cheers!! Naozar R. Garda
Re: burman gb gearbox #54071
05/08/07 8:33 am
05/08/07 8:33 am
Norway
MiG16 Offline
MiG16  Offline
Norway
I have never seen a Burman spares list, but here you have an AJS/Matchless spares list including their gearbox part numbers:
http://217.157.196.176:8181/ajs/Book/Spares_lists/1955_AJS_Spares_List_twins.pdf
Hope this helps.
Michael
Re: burman gb gearbox #54072
05/08/07 2:06 pm
05/08/07 2:06 pm
quinlan tx
propwash Offline OP
propwash  Offline OP
quinlan tx
Thanks Naozar&Mig 16:It appears to me that these gearbox numbers may be the Burman numbers,since they are different from most AJS numbers.A friend loaned me a Mustang manual(they used the GB for several years) but they used their own numbers.Ariel used these boxes but I don't know about their numbers.Also Naozar: it appears the kick start levers were probably from Burman and fit several bikes the folding one being optional
Re: burman gb gearbox #54073
05/08/07 6:18 pm
05/08/07 6:18 pm
Bangalore, India
Bangalore, India
Without knowing more on this I somehow doubt that would be so...i 'feel' that the manufacturer would have its own kick start lever ....otherwise did Burman have different design of kick starter levers for the different marques their gearboxes were used on? From what source did you get this info? I am not doubting or challenging, just trying to learn more. Anyway, thanks for the tip, in which case I will now definitely have a closer look at the sites I suggested to you through Google, and look to Burman as a source rather than AMC. Thanks again, and any more info will be appreciated. Naozar R. Garda.
Re: burman gb gearbox #54074
05/08/07 11:35 pm
05/08/07 11:35 pm
quinlan tx
propwash Offline OP
propwash  Offline OP
quinlan tx
Naozar:I've been researching these gearboxes for a while,but I'm not an expert by any means.If AMC bought the gbox clutch and other parts it would probably be cheaper to also buy the k/start arm & shift arm at the same time.Did you look at the link that MiG 16 listed?AJS and Matchless were very similar. On the AJS link the Gearbox parts numbers were mostly like X-7-19 while the cycle and engine parts were like 012345,which most AMC parts seem to be,this makes me think that they are Burman parts(gbox&controls).I also spoke to a retired bike mechanic and he said he had seen lots of different shifters but only the 2 different k/starters
Re: burman gb gearbox #54075
05/09/07 8:11 pm
05/09/07 8:11 pm
Bangalore, India
Bangalore, India
Thanks propwash, good info, and looks like your deductions are correct. Yes I am familiar with the link suggested by MiG16, it has a wealth of info. The milling/knurling on my 1955 G3LS kickstarter has worn out and so I am trying to rebuild/replace it. If you find info suitable for me please do give me a tip-off!!. Cheers!! Naozar.
Re: burman gb gearbox #54076
05/09/07 9:02 pm
05/09/07 9:02 pm
quinlan tx
propwash Offline OP
propwash  Offline OP
quinlan tx
Naozar: Do you mean the splines where the kick start lever slides onto the shaft at the gearbox or at the top of the lever?I looked at some of the lists on the AJS web site but my connection is so slow I didn't look at many.At least 3 different bikes ,your g3ls, an AJS 16ms,and a AJS twin all use the G-43-2 lever theG-45-1 pin and the 17-3-2 nut.amcclassicspares.com shows a G-43-2 for 25 pounds UK.Maybe you can find a used one .good luck
Re: burman gb gearbox #54077
05/09/07 9:20 pm
05/09/07 9:20 pm
quinlan tx
propwash Offline OP
propwash  Offline OP
quinlan tx
Nozar:I just found another site.http://www.petersclassicbikeparts.nl/html/burmankickstarter.html It's a complete kick starter,fits most Burmans with 27 mm shafts and is 27 euros,netherlands
Re: burman gb gearbox #54078
05/11/07 6:54 pm
05/11/07 6:54 pm
Bangalore, India
Bangalore, India
Hello Propwash, first I really appreciate the interest and help, thankyou. Yes, i do mean the splines where the kick start lever slides onto the shaft at the gearbox. I had earlier seen the spares list and have the spares numbers given by you but on checking with the jampot site i find that unfortunately they do not have this part. Circumstances here have been such that after my earlier postings, i have just had no time to pursue the matter further. Thanks again. Naozar.
Re: burman gb gearbox #54079
05/11/07 6:56 pm
05/11/07 6:56 pm
Bangalore, India
Bangalore, India
Thanks again. This will be very useful if i finally have to orderout for a new starter. I am trying to get a good repair job done first, hope it works...else i'll have to order new. Appreciate your help and support. Naozar.
