Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
B44 Chainguard Attachment Points #530903
03/01/14 1:44 am
03/01/14 1:44 am
KennethC. Offline OP
life member
life member
My "new" chainguard doesn't fit. No telling what it is off of, it's close. So is all that is missing is relocating the front bracket to the left side of the chainguard, or should I try and find the correct one?
Ken
1967 Triumph Mountain Cub
1968 BSA Victor Special
1968 BSA Lightning
1971 BSA Thunderbolt
1971 AJS Stormer
1972 Bultaco Sherpa
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530905
03/01/14 2:17 am
03/01/14 2:17 am
The Northwoods... Michigan
Steve Erickson Offline
It is from a gooseneck C15/B40 frame.
You might be able to make it work. I once compared one of these very closely with a B44 chainguard. They appeared identical except for the placement of the front tab, and I seriously toyed with the idea of making the change. However, there are some differences in the height of the rear mounts for various years and models also. So I decided to be patient and get the right one.
The correct guards come up often enough on eBay, and the one you have can be sold for about the same amount as buying the right one. Better that than going through the effort of making the change to the guard and finding that it rubs on the chain because the rear tab isn't set for enough clearance. IMHO.
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530946
03/01/14 10:50 am
03/01/14 10:50 am
life member
life member
Thanks Steve, I will start searching eBay for the correct part.
Is the chainguard unique to the 1968 model or will a 67 or 69 fit?
Ken
1968 BSA Lightning
1971 AJS Stormer
1972 Bultaco Sherpa
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530959
03/01/14 11:48 am
03/01/14 11:48 am
66 probably, 67 and 68 will fit. 69 and 70 were a different rear mount entirely.
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530964
03/01/14 12:12 pm
03/01/14 12:12 pm
You can make a 69/70 fit, in fact I have a 70 on a C15 frame, you fit the guard using the front bracket to bolt it in position and use the rear bracket holes as a guide to drill and tap 2 holes in the flat plate with the spindle slot. Fit 2 bolts and the chainguard is fully fitted. All the changes they made do not make them any less prone to falling apart though smile
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530978
03/01/14 1:59 pm
03/01/14 1:59 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Ken,
I have them available.
http://www.pssconline.com/item.wws?sku=40-7718U
or
http://www.pssconline.com/item.wws?sku=41-7710U although the ones with the big flap are really a bigger pain that they are worth.The flap always seems to rub on the tire or chain and I usually just cut them off. Folks seem to like to buy them off me because they match what is displayed in the parts book. Oh well.
Peter
Re: B44 Chainguard Attachment Points [Re: KennethC.] #530982
03/01/14 2:41 pm
03/01/14 2:41 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Ken, Your guard would be for the C15 dirt bikes with the gooseneck frame. They run a longer swing arm than the C15 road bikes. There were at least 3 different chain guards for the C15 & B40 gooseneck framed bikes and 4 different guards for the B44 / B25 series (perhaps more?). Two different mount set-ups, both with and without chain / wheel flaps. For those who need to know smile
Peter
Re: B44 Chainguard Attachment Points [Re: Peter Quick] #530992
03/01/14 3:44 pm
03/01/14 3:44 pm
Good price on that chainguard Peter.
Re: B44 Chainguard Attachment Points [Re: KennethC.] #531033
03/01/14 10:12 pm
03/01/14 10:12 pm
life member
life member
Thanks Peter, I have order the chainguard from you.
I thought the transmission or primary drive was going south on me, but it was only my old bodged misfit chainguard wearing through.
Ken
1968 BSA Lightning
1971 AJS Stormer
1972 Bultaco Sherpa
Re: B44 Chainguard Attachment Points [Re: KennethC.] #538299
04/16/14 11:19 am
04/16/14 11:19 am
life member
life member
Thanks Peter for setting me up with a very good conditioned chainguard. It is now stripped, painted and everything lines up as it should. Great store you have there! Nice to see us unit single guys so well taken care of.
Ken
1968 BSA Lightning
1971 AJS Stormer
1972 Bultaco Sherpa
