MikesClassics
MikesClassics
Queensland, Australia
208 registered members (68 royalstar tony), 1,775 guests, and 586 spiders.
10032 Registered Users
Lannis 144
kommando 102
476,308 mail-order LSR
Topics65,711
Posts635,140
Members10,032
Thread size on the bottom of t120 forks please #535254
03/28/14 10:05 am
03/28/14 10:05 am
queensland
kye Offline OP
kye  Offline OP
queensland
Hi everyone
New to the triumph board usually hang out on the BSA board!
I have a stripped thread on the fork bottom, where the two bolts hold axle clamp on my 1968 t120. Does anyone know the thread size/type any help much appreciated.
Re: Thread size on the bottom of t120 forks please [Re: kye] #535255
03/28/14 10:18 am
03/28/14 10:18 am
The threads were changing a lot at that time, I would check the thread on the bolts. 26 tpi will be cycle thread, 24tpi will be UNF. Thread gauge will tell you which or a known tpi bolt.
Re: Thread size on the bottom of t120 forks please [Re: kye] #535257
03/28/14 10:26 am
03/28/14 10:26 am
queensland
kye Offline OP
kye  Offline OP
queensland
Thanks kommando
Will check the bolts for tpi
Re: Thread size on the bottom of t120 forks please [Re: kye] #535273
03/28/14 12:31 pm
03/28/14 12:31 pm
Irish Swede Online content
Irish Swede  Online Content
Tool stores sell Starrett thread gauges. Ask for one in British threads, including "Whitworth."
Owning a '68 Triumph you will be using it often.
Re: Thread size on the bottom of t120 forks please [Re: kye] #535966
04/01/14 11:23 am
04/01/14 11:23 am
Dorset
chainreaction Offline
Dorset
There should be studs in the lower fork leg, unc fork end and 24 tpi nut end.
Re: Thread size on the bottom of t120 forks please [Re: kye] #535979
04/01/14 12:02 pm
04/01/14 12:02 pm
Studs apply to 1970 only, prior to 70 they were bolts but depending on the year they were cycle or UNF.
Re: Thread size on the bottom of t120 forks please [Re: kommando] #536010
04/01/14 1:49 pm
04/01/14 1:49 pm
Stuart Online content
Stuart  Online Content
You're thinking of the '71-on alloy sliders; pre-'71 sliders are steel; when studs were fitted to the '70 sliders, the thread into the slider was UNF so the studs are UNF at both ends.
Were they fitted for all of '70 - the parts books dated September 1969 still show bolts, only the '70 T150 3rd edition book (dated January 1970) shows studs?
Re: Thread size on the bottom of t120 forks please [Re: kye] #536130
04/02/14 4:04 am
04/02/14 4:04 am
Dorset
Dorset
Odd one this, yes 69 parts book shows bolts but both my late 69's have studs :-(
Re: Thread size on the bottom of t120 forks please [Re: Irish Swede] #536207
04/02/14 2:35 pm
04/02/14 2:35 pm
Lyons, NY
Britishtools Offline
Lyons, NY
Note that for what Starrett sells for $47.00, we have for $17.00 and are a paid vendor here.
Re: Thread size on the bottom of t120 forks please [Re: kye] #536216
04/02/14 3:17 pm
04/02/14 3:17 pm
(When I bought my Starrett gauge 30 years ago, it was a lot less expensive)
Re: Thread size on the bottom of t120 forks please [Re: kye] #536220
04/02/14 3:42 pm
04/02/14 3:42 pm
John Healy Online content
John Healy  Online Content
Kye:
To answer your question they are 5/16" diameter and can be Recoiled to 5/16" UNF or 5/16" CEI.
For the CEI use a 97-1070 bolt.
For the UNF use the 14-0218 bolt or the 21-2014 stud and 5/16" UNF nut.
Re: Thread size on the bottom of t120 forks please [Re: kye] #536234
04/02/14 5:50 pm
04/02/14 5:50 pm
Kapiti New Zealand
Paul in NZ Offline
Paul in NZ  Offline
Kapiti New Zealand
Not much help but.... Every 60's triumph I have had with the outside spring forks I have convered by adding studs and nuts instead of bolts... Its just easier....
