27 registered members (AML),
173
guests, and 393
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,550
Posts645,144
Members10,170
Most Online3,995 Feb 13th, 2017
Re: any suggestions for an A65 replacement alternator
[Re: hacksaw]
#532519
03/12/14 11:40 am
03/12/14 11:40 am
Posts: 9,685 Scotland
Stuart
Hi, What've you got and what do you want? . If it's still got the 3-wire single-phase stator, Sparx do an encapsulated replacement. . Above that, the 2-wire RM21 (10.5A @ 5,000 rpm) is available from LAP ( Lucas Aftermarket Products), Sparx and Wassell have copies. . Above that again, the high-output 3-wire 3-phase RM24 (14.5A @ 5,000 rpm) is available from LAP, Sparx has a copy, Wassell has an alleged 20A 2-wire, single-phase stator, but don't appear to mention the rpm where this wonderful 20A is generated (not a lot of use @ 10,000 rpm  ). Ime and mho, you can never have too many Amps. Hth. Regards,
[Re: hacksaw]
#532523
03/12/14 11:52 am
03/12/14 11:52 am
Posts: 3,245 arkansas
leon bee
Hack for electrical stuff I like an eBay seller called racingnorton who is also a real guy named Carl Hokanson. I don't think he tries to get rich off of us, email is chokanson at aol dot com. I'd check with him.
[Re: hacksaw]
#532542
03/12/14 2:45 pm
03/12/14 2:45 pm
Posts: 406 Chelmsford MA
MarcB
Chelmsford MA
I've use a Sparx 3-wire set-up for over 10 years (holy crap, even longer than that) and it's been very good, except they had issues with the rotor not fitting the shaft early on. Because of this, I use a Lucas rotor and it's been trouble-free the whole time. I'll second the mention of Carl Hokanson. I've dealt with him in the past and he is very reliable.
[Re: hacksaw]
#532641
03/13/14 4:53 am
03/13/14 4:53 am
Stuart
Hi, its not charging so I just assumed its a bad alternator, but I realize It could be broken wires as well Also don't forget the rectifier or rect./reg., it could've broken.  Hth. Regards,
[Re: Stuart]
#532785
03/14/14 4:38 am
03/14/14 4:38 am
Posts: 91 UK
TripleTown
Hi, What've you got and what do you want? . If it's still got the 3-wire single-phase stator, Sparx do an encapsulated replacement. . Above that, the 2-wire RM21 (10.5A @ 5,000 rpm) is available from LAP ( Lucas Aftermarket Products), Sparx and Wassell have copies. . Above that again, the high-output 3-wire 3-phase RM24 (14.5A @ 5,000 rpm) is available from LAP, Sparx has a copy, Wassell has an alleged 20A 2-wire, single-phase stator, but don't appear to mention the rpm where this wonderful 20A is generated (not a lot of use @ 10,000 rpm  ). Ime and mho, you can never have too many Amps. Hth. Regards, +1, regarding what do you want? It's a preference thing and probably best to get some independent advice. LAP, Sparx and Wassell all make 3-wire 3 phase 12V RM24 LU47244 (14.5A) stator, while LAP and Wassell also make a lower output (10.5A) RM24 LU47252 3 phase unit. All available in the US. 100% need to check the rectifier/regulator. Can't go wrong with Podtronics which are readily available. Good luck!
[Re: hacksaw]
#534318
03/22/14 11:38 pm
03/22/14 11:38 pm
Posts: 1,164 hamden, ct.
hacksaw
hamden, ct.
well I finally pulled the primary cover. I find I have a 2 wire system. the Lucas rotor doesn't wobble, but it has maybe an inch in rotational play. the alternator looks old, but intact. the encapsulating material is pock marked and a bit weird looking, but seems intact. except where there is a plastic housing for the wires, it is broken away where the wires actually enter the alternator. the wires themselves dont appear to be damaged. on the other end, one of the spade connectors to the rectifier may have been loose. part of me just wants to replace the whole shebang. part of me wants to diagnose the the problem if possible. I believe I tested the output at those spade connectors a couple of years ago while the bike was still set up to run. there was no output. can I check to see if there is a break in the alternator windings itself? do rotors lose magnetism in time and should it have that 1 inch play? how can a rectifier be checked with a meter? thanks men. or mates, if that's the case!!!!!
[Re: NickL]
#534747
03/25/14 6:02 am
03/25/14 6:02 am
Posts: 3,674 Sydney Australia
BSA_WM20
A puller and a lot of heat
Or as had alread been suggested split the arbour. A big nut spliter will do the job
Bike Beesa Trevor
