Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
ATF vs. 80w-90 gear oil for gearbox? #533718
03/19/14 9:05 am
03/19/14 9:05 am
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
Do any of you use ATF in your gearbox instead of 80w-90 gear oil? It seems I have heard that some do.
Re: ATF vs. 80w-90 gear oil for gearbox? [Re: zoe] #533732
03/19/14 10:29 am
03/19/14 10:29 am
kommando Offline
kommando  Offline
I have heard of it being used in gearboxes but its thin and escapes on bikes with older seal technology, I use 80-90W full synthetic gear oil in my boxes and its fine.
Re: ATF vs. 80w-90 gear oil for gearbox? [Re: zoe] #533734
03/19/14 10:36 am
03/19/14 10:36 am
You may be confusing the oil to use for the primary versus the gearbox. The pre-unit BSA clutches run in a small amount of oil and most use Ford Dextron ATF in the primary. You want to use a gear oil in the gearbox.
Re: ATF vs. 80w-90 gear oil for gearbox? [Re: zoe] #533739
03/19/14 11:11 am
03/19/14 11:11 am
New York
ShearedCrank Offline
New York
Regardless of if you have heard that it's been used, it's wrong.
While at work I broke out my Viscosity Equivalents chart, ATF is nowhere even CLOSE to the viscosity that the OEM had recommended (50 Weight Engine Oil). Times have changed and now we have dedicated gear oils that have a host of additives that make it ideal for our application (straight cut gears).
The correct cross to SAE Grade GEAR OILS, is 90W (Kommandos suggestion is fine). If you google it, you can have your own Viscosity Equivalent chart. I find it useful as I'm constantly converting AGMA to ISO grades to MobilSHC series numbers.
Matt
Re: ATF vs. 80w-90 gear oil for gearbox? [Re: ShearedCrank] #533749
03/19/14 12:56 pm
03/19/14 12:56 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
Thanks you to all.
