Soup Dragon
Soup Dragon
South Cotswolds, England
19 registered members (Alan_nc), 193 guests, and 435 spiders.
10418 Registered Users
btour 89
Triless 77
reverb 75
710,228 mail-order LSR
Topics68,305
Posts665,025
Members10,418
Tightening up dynamo chain? BSA A10 #532563
03/12/14 5:07 pm
03/12/14 5:07 pm
Denmark
F
FoxDK Offline OP
FoxDK  Offline OP
F
Denmark
Hallo,
Today I had the timing cover pulled of my BSA A10 Golden Flash from 1960.
I noticed that the chain to the dynamo is a bit loose. How do I tighten this chain up?
Regards from Denmark, Frederik smile
Re: Tightening up dynamo chain? BSA A10 [Re: FoxDK] #532570
03/12/14 5:48 pm
03/12/14 5:48 pm
I just learned how to do this VERY thing in my shop last night!
You loosen the clamp ring that holds the dynamo in place, rotate the case of the dynamo until the chain has about 6 mm of play up and down in the middle of the run, and tighten down the clamp. The dynamo is mounted "eccentrically" to the case and moves in and out as the case is rotated in place. Don't let the dynamo move away from the cases as you tighten back up, make sure it's pressed right up against it ...
Re: Tightening up dynamo chain? BSA A10 [Re: FoxDK] #532581
03/12/14 7:42 pm
03/12/14 7:42 pm
Lannis,
Did you get it on the first try? clap
Bill B....
Re: Tightening up dynamo chain? BSA A10 [Re: Boomer] #532614
03/12/14 9:56 pm
03/12/14 9:56 pm
Originally Posted By: Boomer
Lannis,
Bill B....
I did, actually. I could tell that chain tension was going to change as I tightened up the clamp, so I "wedged" the dynamo in place, made sure the tension was where I wanted it, and then tightened the clamp down .... Otherwise there would be a couple of "hit and miss" tries!
Re: Tightening up dynamo chain? BSA A10 [Re: FoxDK] #532662
03/13/14 9:37 am
03/13/14 9:37 am
Denmark
F
FoxDK Offline OP
FoxDK  Offline OP
F
Denmark
Thank You! smile
I will try that today.
