ChrisX
ChrisX
Lake Macquarie NSW Oz
201 registered members (57nortonmodel77), 2,291 guests, and 669 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 80
Stuart 63
502,996 mail-order LSR
Topics66,018
Posts638,960
Members10,073
1977 TR7V headlight switchgear wiring in headlight #530437
02/26/14 2:04 pm
02/26/14 2:04 pm
Near London, England
TT Rider Offline OP
TT Rider  Offline OP
Hi, I'm replacing the damaged original left hand Lucas switchgear on my '77 750 Tiger with a new Sparx item. The cables from the original connected to a 3-way and a 6-way white plastic pin connector in the headlight shell. The new switchgear has bullet connectors. Does anyone know where the white plastic connectors can be purchased (they could do with replacing) and how are the wires connected to the pins? Alternatively, is it simpler to just replace them with more standardised bullet connectors/another form of connector?
Also the old switchgear only had 5 wires connected to the 6-way connector while the new one has six - the additional one being white/green.
Grateful for any advice!
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530472
02/26/14 3:54 pm
02/26/14 3:54 pm
JubeePrince Online content
JubeePrince  Online Content
Tiger -
Do yourself a HUGE favor and cut that plastic pin-connector out and get some proper Lucsr connectors/bullets to mate up with the Sparx switch. Those plastic connectors with the pins are POS's
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530475
02/26/14 4:03 pm
02/26/14 4:03 pm
Stuart Online content
Stuart  Online Content
Firstly, welcome to the Forum.
Sparx. smile
However, from personal, first-hand experience, mad I would strongly recommend against using the pin (AMP) connectors. Lucas supplied Meriden and Small Heath with individual bullets connections for years before starting to use the pin connectors from 1975; the pin connectors were such a warranty nightmare that the Co-op actually swapped back to bullets! shocked Pattern switch clusters come with bullet connections for a very good reason ... smile
When replacing the pin connections on the main harness cables, I recommend using these, crimped with the 'M'-shaped cutouts in a tool like this (there are more expensive/ better made ones smile ). There are bullet terminals that look like the Lucas originals elsewhere on your bike's loom but the modern ones are for metric-sized cables and your bike has slightly (but significantly frown ) smaller Imperial-sized cables.
Did the old switchgear have a 'headlamp flash' - push the horn button upwards instead of inwards? The connecting cable into a small hole in the top of the horn button unit was often missed off. frown If not, and your new "white/green" connects to a Blue/White in the other part of the 6-way connector, you might find your bike now has an extra feature. grin
There should be White (power in to the horn button), Purple/Black (output to the horn), Light Green/Brown (input to the indicator switch), Green/White (mainly Green with a White tracer, output to the right-hand indicators), Green/Red (output to the left-hand indicators), Blue/Yellow (input to the dip switch), Blue/White (output to headlamp main), Blue/Red (output to headlamp dip).
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530477
02/26/14 4:06 pm
02/26/14 4:06 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
(Stuart posted while I was typing)
3-way
4-way? (but with 3 pins/wires)
The 2,4, & 6-way pin connectors can be obtained from Tri-Cor England (Sparx).
http://www.tri-corengland.com/acatalog/4-Pin-connector-SPX032.html
http://www.tri-corengland.com/acatalog/6-Pin-connector-SPX033.html
The pins/sockets need to be crimped onto the wires before the pins/sockets are snapped into the blocks.
Yes, bullet connectors are a better choice.
Green/White is the colour normally used for the right hand indicator circuit and there should already be a switch-to-harness Green/White "pair" in the 6-way connector.
Could the "White/Green" in fact be a Blue/White wire, as Blue/White would normally be the "extra" switch wire.
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: Stuart] #530487
02/26/14 4:27 pm
02/26/14 4:27 pm
Norfolk, UK
Norfolk, UK
However, I'd hazard a guess that there probably isn't going to be any corresponding Blue/White "headlamp flash" harness wire to the 6-way connector (only the 4-way).
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530546
02/26/14 9:09 pm
02/26/14 9:09 pm
TT Rider Offline OP
TT Rider  Offline OP
Thanks everyone for the advice - much appreciated! I will be junking the AMP connectors in favour of bullet ones. Stuart (thanks for the welcome!)- yes, you're right, the Blue/White is the extra wire. The original horn button does press up for headlight flash,but has no wire connected. LAB - I'll need to check whether there is a corresponding Blue/White on the 6-way or the 4-way (yes, it is a 4-way not a 3-way!) Thanks for clarifying matters - I'd better get those Imperial bullet connectors ordered!
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530601
02/27/14 4:47 am
02/27/14 4:47 am
I sent you a pm about something else. You should see a flashing icon next to "My Stuff" in the top bar when you sign in, click on the down arrow and then on "Messages".
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530682
02/27/14 4:16 pm
02/27/14 4:16 pm
Plymouth UK
doug748 Offline
doug748  Offline
Plymouth UK
Hello Tidza, I buy my bullets from Paul Goff:
http://www.norbsa02.freeuk.com/goffyelectrex.htm
..might be useful.
If you wish to sell on your broken left hand switch, I think I could use it. I only need the horn button bit - I am guessing it will be the same as my '81 Bonnie.
Bloody annoying, I sent the bike for a bit of top end work and they managed to break off the horn button (and lose a solenoid cover). It took me about 4 hours to botch up a soldered repair. It would have been easier to tackle the full job myself Anyway, just a thought.. and welcome!
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: doug748] #530718
02/27/14 8:32 pm
02/27/14 8:32 pm
TT Rider Offline OP
TT Rider  Offline OP
Hi Doug - thanks for the link - looks good.
Currently got an interested party for the left hand switchgear but will let you know if I don't get rid of it. Not sure whether the horn button is the same as an '81 Bonnie though?
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530789
02/28/14 8:25 am
02/28/14 8:25 am
UK Berks
AngloBike Online content
AngloBike  Online Content
UK Berks
doug,
is your switch a Norton/Trident/T140E type? or the flipper type?
I might be able to find a button. I bought a whole assembly on eBay for the casing. Due to stripped threads
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: AngloBike] #530795
02/28/14 9:01 am
02/28/14 9:01 am
Plymouth UK
doug748 Offline
doug748  Offline
Plymouth UK
Hello Anglo. I will try to attach a photo:
......Failed with the snap! Maybe you can see it here:
http://www.flickr.com/photos/25720405@N02/12833936924/
It is part no: 60-7464 Handlebar switch left hand
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: TT Rider] #530798
02/28/14 10:02 am
02/28/14 10:02 am
UK Berks
UK Berks
I'm Dave m on Triumph Rat but somebody beat me to it here.
I have the RH switch but I'd bet the button is the same part.
I will need to search the garage for it, as it was a brainwave a year ago that somehow got stalled.
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: AngloBike] #530826
02/28/14 2:06 pm
02/28/14 2:06 pm
Norfolk, UK
Norfolk, UK
A '77-'78 T140V/TR7 would usually have the T160 style LH switch assembly.
http://www.classicbike.biz/Triumph/Brochures/1970/77ModelsCanadaTri.pdf
http://www.tri-corengland.com/acatalog/SPX007-T140V-T160-LH-Switch-Gear--SPX007.html
The difference being that the original T160 LH switch assemblies (and pattern items) have the headlamp flash function whilst the T140V/TR7 assembly apparently didn't.
Re: 1977 TR7V headlight switchgear wiring in headlight [Re: L.A.B.] #530907
03/01/14 3:00 am
03/01/14 3:00 am
Hi Les,
As a matter of possible interest, 'early' T160's don't have the headlamp flash connected either. I wonder if it was an assembly cock-up at Lucas, some 'wrong' ones were then put on the shelf when the mistake was rectified and later the newly-fledged Co-op agreed to take 'em, possibly at a knockdown price?
Page Time: 0.816s Queries: 15 (0.015s) Memory: 1.1033 MB (Peak: 1.3381 MB) Zlib disabled. Server Time: 2018-02-21 01:25:40 UTC
