norbsa48503
norbsa48503
Flint,Mich
204 registered members (1xfatboy), 1,770 guests, and 572 spiders.
Lannis 144
kommando 105
Stuart 64
477,131 mail-order LSR
Topics65,722
Posts635,286
What expendables for magneto rebuild #522601
01/12/14 11:06 am
01/12/14 11:06 am
Westminster, Colorado
stubbicatt R.I.P. Offline OP
Guys, what parts such as seals, corks, etc., should I source for when I remove, have rebuilt, and replace the magdyno? I have the parts book, and can look up part numbers etc., but my concern is there are doubtless desirable parts for replacement that I haven't thought of.
Thanks in advance.
BSA Gold Star eBay items
BSA Gold Star forum This board is dedicated to BSA Gold Star motorcycles.
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522608
01/12/14 11:39 am
01/12/14 11:39 am
Santa Fe, Texas
bsalloyd Offline
bsalloyd  Offline
Santa Fe, Texas
I can tell you I have rebuilt a few magnetos with various levels of success. I you want to be sure you have a good reliable mag send it to one of the individuals that provide this service. They will have all of the quality parts needed. They also have the tools required. This would be a spark gap tester, lathe, and re-magnetizer to make sure you are getting the correct spark intensity. Not sure if we are allowed to suggest a provider. If we are I can give you a couple of names.
1951 ZB GS
1953 BB GS
1953 Super Flash
1954 Vincent BS
1963 RGS
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522611
01/12/14 11:45 am
01/12/14 11:45 am
Thanks bsalloyd. I have no intention of trying to rebuild a magdyno. I am trying to amass the proper seals, gaskets, bolts, washers, things like this which make putting it back together on the bike a single chore, rather than one spread out over several days while awaiting parts.
smile
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522616
01/12/14 12:27 pm
01/12/14 12:27 pm
Middle East,
Kerry W Online content
Kerry W  Online Content
Middle East,
I'm with bsalloyd - the mag reconditioner should have the requisite parts for the mag instock. I suspect, however, that you want to klnow what you need to put the rebuilt mag back on the bike.
Easy: Need to have items I'd have on hand:
1 x timing cover gasket (Phil Pearson or several suppliers on eBay)
Possible extra items that would be Nice to have:
1 x mag pinion seal (65-2316)
2 x oil feed washer (rubber) for cam spindles (66-1923)
Plus maybe:
1 x timing cover crank end oil seal (prob not required)
Plus means of timing the igntion.
Kerry
Oliver Wendell Holmes
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522618
01/12/14 12:56 pm
01/12/14 12:56 pm
Norfolk England
DBDBrian Online content
DBDBrian  Online Content
Norfolk England
The main thing you will need is a mag pinion puller.Gasket and seals as recommended by Kerry. If you are refitting your original mag then you most likely won't require any base shims. Watch out for the spring in the breather valve when you remove the cover. On re-installing the cover, I remove the oil check valve, ball and spring, and insert a piece of rod through the cover and gasket, into the oil way in the crankcase, to ensure the gasket is not impeding the oil hole. Also be sure to time the breather valve, when installing the pinion.
Hope this is of some help.
Brian
Brian
Made In England
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522641
01/12/14 2:40 pm
01/12/14 2:40 pm
Thanks fellas. You reckon it would be good to get the allen wrench, hex socket-type, screws for holding the timing cover on?
In this application, how tight is "tight," and would a dab of blue loctite be appropriate?
I read somewhere that I will need a cork gasket to go between the magneto and timing chest on the back, as well as an oil seal. Is this correct, and if so, where to source this cork?
When I remove the cover, and the oil check valve, will I be greeted by a bunch of oil pouring out the timing cover? Is it advisable to drain the oil tank prior to this exercise?
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522725
01/12/14 9:55 pm
01/12/14 9:55 pm
Middle East,
Middle East,
A little oil will escape thre timing cover.
If you don't have hex-head cap screws in the timing cover and the slotted cheese-head type are OK, leave them in - it's easy to over-tighten the cap screws.
Never used a cork gasket behind the mag.
The trick from Brian about making sure the oil hole is clear is a good one I will adopt too! (esepcially as the timing cover is off my bike..!)
Kerry
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522843
01/13/14 3:23 pm
01/13/14 3:23 pm
Elko, Nevada USA
dave - NV Online content
dave - NV  Online Content
Elko, Nevada USA
An important detail I've not heard mentioned here this time ...
As the mag will move side/side in the slotted holes in the mag platform, it's location can be a bit vague.
Here's the issue .. if the mag is positioned too far over the breather drive peg on the mag gear will cut into the outer timing cover. The 'trick' is to position the mag and with a straight edge across the timing chest face, insure the peg is below the face. Make sense?
There's a cork washer supplied in the (junko) OEM gasket set for use between the mag and timing chest. I've always found it too thick and useless and fab my own gasket.
Now would be a good time to replace the mag gear seal in the timing chest. Don't forget to grease the lips on the new seal.
Be sure to have a mag puller on hand as DBDBrian suggests. And be prepared to retime the engine when the mag is replaced, 'a whole nuther discussion'.
I would suggest you consider fitting a SRM Boyer electronic ignition vs rebuilding the mag as I and many others have done. Whatever ...
And speaking of Goldie sparklers ... I've gotten off center and ordered up a Powerdynamo magdyno from GER for my '62 'improved' GS project bike under construction. I ordered the dual spark version for use with my twin plug heads.
Do any of your GSrs have good/bad/ugly experiences with this unit?
dave - NV
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #522865
01/13/14 6:49 pm
01/13/14 6:49 pm
Norfolk England
Norfolk England
No Stubbi you won't be up to your knees in oil, but it will drain through, if the cover is off for a long period.
I also have never fitted a cork washer.
Yes Dave, Good point re the breather drive peg, I have removed many a cover with the valve thrust face damaged, and who knows where the swarf went.
Re the Boyer system, I have just removed a Lucas MO1L mag converted with a Boyer unit. The owner found it a problem to start if it had not been used for a while, as it went into maximum advance when the battery was not a full 12 volts.
I fitted a new self generating BT-H magneto at his request. (I thought all magnetos were self generating) Bench tested only to date.But it starts well.
I must confess I prefer a good standard magneto for road use, but accept racing is a different ball game.
I'm afraid I have no knowledge of the powerdynamo magdyno.
Brian
Brian
Made In England
Re: What expendables for magneto rebuild [Re: stubbicatt R.I.P.] #523164
01/15/14 6:16 pm
01/15/14 6:16 pm
Well I ordered up the magneto shaft seal, 2 cam seals, and 1 main shaft seal. The vendor suggested using Yamabond or the like in lieu of a gasket between the 2 halves of the timing chest. Didn't even carry any gaskets.
I guess I'll call Baxter's after awhile and see about a timing chest gasket or 2.
