lit67
lit67
Central Illinois, USA
37 registered members (Adam M.), 263 guests, and 80 spiders.
10389 Registered Users
NickL 98
Triless 88
Mori55 83
reverb 80
Rohan 80
DavidP 72
btour 66
690,580 mail-order LSR
Topics68,051
Posts662,152
Members10,389
Boyer ignition plate attached to cam removal ?tion #521590
01/05/14 8:16 pm
01/05/14 8:16 pm
Chris R Offline OP
Chris R  Offline OP
I am wanting to my cam cover on my '70 T120R. The bike came with a Boyer ignition pointless plate. I removed the pickup plate then pulled the center allen blot out that holds the ROTATING magnet plate to the end of the exhaust cam. How do I get the plate off of the tapered end of the cam safely? I tried running a 5/16" fine thread bolt into the threaded center of the Boyer magnet plate to try to push it off of the cam but I didn't want to crank on the bolt too much and screw something up. ALSO, is the piece KEYED to the cam or not? Thanks for any help! Heck....It's been in the high 60's to low 70's here on the Left coast. Getting excited to get the 650 back on the road! Chris
1970 T120R Bonneville
1967 T20SM Tiger Cub
1976 Honda 550F 4 cylinder
1955 VW Bug European Delivery
1939 Willys Pickup
2007 Dodge, Cummins 5.9 4X4 6spd
Re: Boyer ignition plate attached to cam removal ?tion [Re: Chris R] #521595
01/05/14 8:50 pm
01/05/14 8:50 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
Re: Boyer ignition plate attached to cam removal ?tion [Re: Chris R] #521602
01/05/14 9:42 pm
01/05/14 9:42 pm
Note the rotor's position so you can put it back in the same place. Find a bolt like the one used to hold the rotor in place, but a bit longer. Screw that into the rotor. Give the end of the bolt couple of sharp raps with a hammer, and the rotor will come loose.
72 T150V yet to be named
Re: Boyer ignition plate attached to cam removal ?tion [Re: Chris R] #521612
01/05/14 11:49 pm
01/05/14 11:49 pm
Chris R Offline OP
Chris R  Offline OP
quinten, DavidP, Thanks for the tips. The youtube is a good instructional. GET the BIG Torch out!
1939 Willys Pickup
Re: Boyer ignition plate attached to cam removal ?tion [Re: Chris R] #521620
01/06/14 12:57 am
01/06/14 12:57 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
DaveP's method should be tried first ,
it works for most and is quicker ,
a sharp small rap usually Frees the taper
... but if a P.O. foolishly added locktite ,
you need a back-up plan
