Alan Lonneville
Alan Lonneville
Ohio,USA
51 registered members (Alan_nc), 264 guests, and 405 spiders.
10476 Registered Users
NickL 89
franko 71
Triless 67
746,989 mail-order LSR
Topics68,810
Posts670,256
Members10,476
Opening up the gearbox for mainshaft replacement #518969
12/16/13 8:40 am
12/16/13 8:40 am
Sunny South Carolina, (US)
T140V-Rich Offline OP
I wanted to start a new topic since I'm right at the gearbox. In the other post, I mentioned I am replacing the gearbox mainshaft that has snapped at nut on the the kickstart side.
First question up for you lads.
I've removed the clutch drum, rotor, crank sprocket, clutch door, etc. Exposed is the mainshaft sprocket on the primary side, and I can re-open the outer gearbox cover to expose the inner cover.
My question is does the mainshaft sprocket have to be removed or can the mainshaft be pulled out after the gears have been removed? Reading the factory manual, it seemed so. But I wanted to ask first.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #518971
12/16/13 8:56 am
12/16/13 8:56 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
You can leave the sprocket and output sleeve gear in place.The mainshaft and layshaft will just slide out,with all the other gears and selector forks on them.
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #518973
12/16/13 9:02 am
12/16/13 9:02 am
Thanks, Pete. I read that section about four times late last night wondering if I were reading it correctly.
The manual I have seems to be calling for indexing to be made in neutral. But I recall your earlier recommendation, it was to index in first or fifth.
More reading on part is in order, I'm certain. But it almost seemed as if the gears etc could be removed, in sequence, lain out in sequence, shaft removed, camplate quad remaining in place and - possibly - the plunder quad, the manual calls it (the big "foot" that changes gears", remaining in place.
As I say, more reading to do. But thank you, Pete!
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519042
12/16/13 5:25 pm
12/16/13 5:25 pm
Vic. Australia
Vic. Australia
Have it in neutral to dismantle and assemble.Select 1st or 5th after that for indexing.
Once you've pulled the selector spindle clear of the case,you can move the selector forks away from the camplate and slide the lot out.Grab both shafts and selector forks,and slide the lot out as a unit with all gears attached.
Only the output sleeve gear will remain in there.
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519043
12/16/13 5:39 pm
12/16/13 5:39 pm
Tridentman Online content
Tridentman  Online Content
I agree with Pete--ease out the selector fork shaft and then remove everything except the high gear as one unit.
Last one I rebuilt it was the middle of the summer.
All the garbage in the manuals about holding in place with a dab of grease was useless advice--the grease just ran away because it was hot.
To get the selector forks in the right position but held into the selector cam plate is not so easy.
What I did when the grease was not cooperating was to take a length of welding rod and turn a U at one end. The U end I then pushed through the spindle hole in the selector forks and the U at the end of the rod located in the housing at the far end of the box.
With the extra wiggling room because of the smaller diameter of the rod compared with the spindle you can fiddle the forks into the correct position. Then place a large screwdriver across the tops of the forks and lightly hold them in position.
Then gently ease out the welding rod and ease in the spindle.
Sounds worse than it is--and worked first time for me!
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519184
12/17/13 7:10 pm
12/17/13 7:10 pm
Vic. Australia
Vic. Australia
I think if you practice a few times,you'll get it down to about 15 or 20 seconds to load an empty box with shafts gears and selectors and have the selector shaft in place.
You're then ready to index the quadrant and fit the inner cover.
Re: Opening up the gearbox for mainshaft replacement [Re: Pete R - R.I.P.] #519201
12/17/13 9:05 pm
12/17/13 9:05 pm
Western NY
Pete Suchawreck Offline
Western NY
It's not that bad Rich. Turning the rear wheel while shifting works well. Just keep an eye on the parts manual. Keeps everything in order. If it warms up I'm at replacing mine -maybe Christmas...
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519203
12/17/13 9:07 pm
12/17/13 9:07 pm
What you lads are saying is very encouraging. I've simply been reading the manual through and through so I'll know what this is or that before I even see it.
Both of what you're saying sounds solid. I was thinking of a clothes hanger bent into a U at the end, T-man. If you think that works.
Pete, I think my biggest lack of understanding is the indexing. I under what it's for. But I'm not certain the step at which the selector quadrant (that big duck's foot that protrudes through the inner cover) goes into the box.
It looks to be behind the camplate, implying it goes in first. If it does, then the indexing becomes complicated, in my mind. You're to have the selectors in the correct position in the camplate when the entire shooting match goes back into the box?
I hope you'll forgive me for asking queries without having removed the inner cover. I'm trying to understand the workings, the procedure, the correct process, etc before I open her up. In addition, time in the day gets away before I can home to it. But this weekend, I'll be taking the inner cover off, good or bad.
I also appreciate you lads' patience.
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519218
12/17/13 10:48 pm
12/17/13 10:48 pm
Scratch part of the comment above about when and where the duck's foot (quadrant) goes back in. Looking at my own resto pics on the Member's Bike Projects, I see the selector quad is installed inside the inner cover.
So. With that in mind, the gears are indexed in say, 1st or 5th. The quandrant and cover are re-installed with the quadrant meshing with the camplate in the 1st or 5th (or whichever) position, if I'm understanding it correctly.
It made muchly sense when I saw the pic of my own making, no less, of the quadrant mounted in inner cover.
I think I have made progress, Watson!
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519227
12/18/13 12:10 am
12/18/13 12:10 am
You got it, Rich!
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519228
12/18/13 12:11 am
12/18/13 12:11 am
I think it will become very clear when you take the inner cover off.
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519264
12/18/13 9:25 am
12/18/13 9:25 am
I can say I agree, T-man. Once the inner cover's off, I'll understand much more. I'm hoping to make a go of it this afternoon, actually. At least open it to take pics, if nothing else.
I had been studying the pics in the manuals since the bike's in the shed, which was a long distance with the rain we've had over the past weekend.
But the quadrant is mounted inside the inner cover. I'd been studying the manuals to find out *where* it was installed, assuming it was installed behind the camplate. It reaches behind, it isn't installed back there.
I know. You lot are rolling your eyes. laughing I'm getting there. And again I appreciate the insight.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: Pete Suchawreck] #519265
12/18/13 9:30 am
12/18/13 9:30 am
Good luck on the weather, Pete. We're scheduled for 75 and cloudy Saturday. That may be my chance to at least study an open gearbox. Or maybe I can during a small bit of time off next week since I did hear my wife mention shopping Saturday.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519298
12/18/13 2:02 pm
12/18/13 2:02 pm
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
Rich -
You probably already have this thread in your colllection, but there's some good info here from John Healy and others...also a photo or two that may help:
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=56877&page=2
Re: Opening up the gearbox for mainshaft replacement [Re: Tridentman] #519338
12/18/13 8:19 pm
12/18/13 8:19 pm
Farmington,Connecticut,USA
JBMorris Online content
JBMorris  Online Content
The 'Motor Plate' will have to come off first and that issue plagued me due to a 'captured and spinning bolt' syndrome on my old bird.
Right from the factory. .
Gotta love it:=))
1978 Bonneville T140V PX
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519386
12/19/13 10:06 am
12/19/13 10:06 am
JB, that engine plate and the oil junction block is exactly what kept me from getting at the inner cover in the few minutes I had last night. The junction block covers up that bolt securing the right side of the cover.
Steve, "collection" is right. I'm building all manner of instruction from the boards, and your addition is a very good one. I appreciate that. It's saved to favorites now.
At this point, once the cover is ready to be loosened, I'll mark first and fifth gear positions on the quad/inner cover, then remove it.
It may be this weekend before I can make another stab at it. We're closing out our Christmas articles, bowl game pieces at work, in addition to whatever "spot" news comes up.
We have 12 writers at the newspaper. But when it's fourth and long or first and 10, doesn't matter. They give me the ball and sit back and watch. Very frustrating at times.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519679
12/22/13 9:38 am
12/22/13 9:38 am
Update: Mainshaft, layshaft, gears for each have been replaced along with selector forks located in the camplate.
I used the factory manual method of reassembly which is locating the mainshaft along with fourth gear first, then reassembling one gear/selector at a time.
I didn't beat Pete's record of 15 to 20 seconds for reassembly. But I was only off that mark by 20 minutes. smile
It was reassembled in neutrial, and has since been shifted by turning the camplate into first gear. It was rather satisfying watching the innards move.
Without sounding paranoid, I hope, is it that simple? Granted I haven't located the quadrant yet. And maybe that's my Waterloo. But of all the tasks to get to the reassembly, the rebuild was one of the easiest.
OK. Back at it to see if I can correctly install the quad/inner cover.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519683
12/22/13 10:38 am
12/22/13 10:38 am
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
On mine, it was the inner cover that was the pig. I spent ages with trial and error (pre internet) and suddenly it clicked.
Way better than paying someone though
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519685
12/22/13 11:09 am
12/22/13 11:09 am
Well done, Rich---you are on the home stretch now!
Just got to index the selector but I think you will be OK.
Best of luck!
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519688
12/22/13 11:31 am
12/22/13 11:31 am
@Anglo, you hit the nail on the head. I've spent thousands on a rebuild and then the main breaks off on the gearside nut. I debated spending another $6-800 to take the entire bike back to the shop 330 miles away or replace the main myself. Having done every job around the gearbox, I decided I would sort it myself. Leaning on you lads' knowledge very much, I must add.
I'm not discouraged at all, but the gearbox hasn't quite gotten to the point where it shifts into all gears properly. I'm certain it's the quadrant. I'll simply take it out and refit until it works.
@T-man, I appreciate the encouragement. Your kind words certainly have helped me to feel a bit more confident about the task, and now I'm imagining firing the engine up again. Something I haven't thought about for several weeks now.
OK. Let's try another quadrant location.... (it is marked for first and fifth but still off, apparently.)
Cheers lads!
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #519700
12/22/13 12:59 pm
12/22/13 12:59 pm
Latest update. Opened it back up, the forks are in place. I was suspicious of the first fork that went in having seated properly. It appears to be. The quadrant *seems* to be correct.
Is there a certain means by which I can test the gearbox other than the obvious installing the outer cover and changing gears with the shifter? Sort of a double safety check?
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #520135
12/25/13 12:56 pm
12/25/13 12:56 pm
Merry Christmas to everyone.
I should have taken pics of the process but the gearbox is back together, indexed, and changing into all gears with a satisfying "clunk."
For gearbox newbs like myself, I wanted to give a simple definition of "indexing," which is lining up the gears in their proper position for a "certain" position, ie first or fifth gear was recommended most. I went with first gear. Then when placing the inner cover back into its place, the quadrant must be lined up to "match" first gear.
To do this, make a mark on the inner cover that extends onto the quadrant, and this is done with the gearbox in your planned reassembly position - first or fifth gear. Upon reassembly, hold the quadrant with your finger as the inner cover is being slid home, matching the mark(s). You're done.
I have a theory as to why the mainshaft broke and it relates to the clutch nut. I'll post that up a bit later.
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #520196
12/25/13 10:55 pm
12/25/13 10:55 pm
Western NY
Western NY
Huzzah!! T140 Rick rules!
My gearbox rebuilds were 15-20 times not seconds, tho I did get a bit faster... Good on ya, once you do it properly it's pretty simple. Going to Florida tomorrow so maybe when i get back- just too busy to play w/my babies.
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #520305
12/26/13 7:12 pm
12/26/13 7:12 pm
Thanks, Pete. I appreciate it. I feel really good about the gearbox. Like you say, I wondered, actually, "Is that it?" smile
Have fun with your family and enjoy the babies. Are you driving or flying? If driving, you'll be passing within 40 miles of here. Flying might be a bit further. smile
Cheers mate. Appreciate the encouragement!
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Opening up the gearbox for mainshaft replacement [Re: T140V-Rich] #520318
12/26/13 8:30 pm
12/26/13 8:30 pm
Well done, Rich---congratulations!
South Carolina now has a Triumph Gearbox Expert!
