Justice
Justice
NC
36 registered members (AML), 244 guests, and 465 spiders.
Geofft, WJS, Trondgv, Jonathan Ytterli, hunterjim00
10331 Registered Users
Stuart 127
reverb 84
Lannis 62
657,837 mail-order LSR
Topics67,670
Posts657,354
Members10,331
A10 Crankcases big/small journal crank DIFfrent ? #516978
12/01/13 3:16 pm
12/01/13 3:16 pm
Auckland NZ
Ignoramus Offline OP
Auckland NZ
Catastrophic failure of A10 conrod now means I need to start the process of finding out what I need ....
At this stage all I need to know is if the actual crankcase (timing side) takes a different diameter timing side bush ...im not sure if when they say "small journal crank" it just refers to the big ends? ... something tells me that the small journal crank has a 1 1/4" main bush and the latter ones are 1.5" (like A65) ...but I am not certain
bike is 52 plunger
I know its not really the done thing but has anyone replaced JUST only one side of the crankcase (need to retain the numbers or drama with the licencing dept) ? .. You could tell real fast if it was a no go ,, but only by fitting the crank...
Thanks guys
PS no &^%$%&ing warning just BANG!!!!!!!!!! I suspect sudden oil pump failure as the inside of the motor was bone dry and lots of smoke ,,,,,,,,, summer is just starting here to .......
PSS bike was running like clockwork ........ then........
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #516979
12/01/13 3:43 pm
12/01/13 3:43 pm
They always run best right before they blow up. grin
I've replaced one side on an A65 crankcase. Shouldn't be much different for the A10. You will have to be sure to align the bores of the crankshaft (should alignbore the new bush anyway) and the camshaft. Also, you will probably have to work the barrel joint face and the sump plate. Otherwise it should be fine. I am fairly certain that fitting a big-journal crank into an plunger motor shouldn't be a problem because yes, the journals themselves are the only difference of consequence.
Sorry to hear you blowed it up...good luck on the reanimation.
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #516981
12/01/13 4:01 pm
12/01/13 4:01 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Ig,
As Alex says, no problems fitting a large journal crank.
Mixing cases can be a bloody pain. The cam bushes are usually out of line and the decks have to be milled.
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: trevinoz] #517022
12/01/13 7:05 pm
12/01/13 7:05 pm
Ig,
Wished we were MUCH closer...
If you wished to keep the original type small journal crank, I've got one I'd trade, but oh well... .010 under, fresh turned too.
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517057
12/02/13 1:39 am
12/02/13 1:39 am
Auckland NZ
Auckland NZ
thanks so far guys ......... I don't have A BIG JOURNAL CRANK so if the small journal crank I have is stil useable then I will use that but need to know for sure if the case is different...as in is the bush a different OD in the cases depending on big/small journal crank , are there 2 part numbers for cases ?
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517093
12/02/13 9:29 am
12/02/13 9:29 am
derby england
wak Offline
wak  Offline
derby england
bushes are all the same 1 3/8",iv used loads of odd cases and never had a problem.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517119
12/02/13 1:59 pm
12/02/13 1:59 pm
Auckland NZ
Auckland NZ
Wak ... so does big/small journal crank only refer to the big end sizes? with the big journal crank having the same main journal size as small journal ? am confused
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517124
12/02/13 2:43 pm
12/02/13 2:43 pm
derby england
wak Offline
wak  Offline
derby england
yes just the big ends
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517175
12/02/13 8:31 pm
12/02/13 8:31 pm
Auckland NZ
Auckland NZ
cheers
of course what DOES make the cases different is that its off a plunger bike with the bolt up gearbox mount .... bummer
Re: A10 Crankcases big/small journal crank DIFfrent ? [Re: Ignoramus] #517182
12/02/13 9:20 pm
12/02/13 9:20 pm
gavin eisler Offline
Its interesting that the 1 inch and 3/8 ths timing side bush size is the same as the OD for a BSA bicycle bottom bracket cup, not a lot of people know that.
