Ola
Ola
Norway
30 registered members (Bodie), 237 guests, and 397 spiders.
10294 Registered Users
Stuart 97
Lannis 68
Mori55 67
640,014 mail-order LSR
Topics67,418
Posts654,633
Members10,294
Scavenge pipe. #515699
11/22/13 6:32 am
11/22/13 6:32 am
leicester england
PEH Offline OP
PEH  Offline OP
leicester england
I am putting together a lightening motor that will be fitted to a Trackmaster frame, i hope to use it in the the Uk short track series next season, There is one part i cannot find anywhere which is the oil scavenge pipe in the sump, mine is very rusty and unusable, has any one got one sitting on the shelf or no where there is one? part number 68-0560.any help would be gratefully received. Paul.
Re: Scavenge pipe. [Re: PEH] #515836
11/23/13 11:52 am
11/23/13 11:52 am
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
I have a few removed pipes. You might be surprised how long the inserted piece is, and also how hard it is to get them out. I used a Benzene torch to heat up the casting real hot, and even then it was a bear to twist and pull them out. Getting them back in, and positioned, would be even more trouble I would think, as out is less Fussy! I'll look them up, and if there is a good one, you can have the thing.
Oops,.. add 1 Sporty
Re: Scavenge pipe. [Re: PEH] #515938
11/24/13 6:49 am
11/24/13 6:49 am
leicester england
PEH Offline OP
PEH  Offline OP
leicester england
Thanks KC, i already have it out,it was a bit of a sod to get out,Many thanks for the reply.
Re: Scavenge pipe. [Re: PEH] #516037
11/24/13 9:18 pm
11/24/13 9:18 pm
KC in S.B. Offline
KC in S.B.  Offline
I have one that works OK if you want it, unless you find one closer to home!!
Re: Scavenge pipe. [Re: PEH] #516098
11/25/13 12:28 pm
11/25/13 12:28 pm
wadeschields Offline
Mine fell out when I took the sump plate off. Havent ridden the bike since.
Re: Scavenge pipe. [Re: PEH] #516150
11/25/13 4:52 pm
11/25/13 4:52 pm
KC in S.B. Offline
KC in S.B.  Offline
I love J-B Weld, wish I'd had it when I was a teenager !!
Re: Scavenge pipe. [Re: PEH] #516167
11/25/13 8:34 pm
11/25/13 8:34 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Before JB Weld, we used Marine-Tex. We used to say, "if it can't be fixed with Marine-Tex, silicone seal, or duct tape, it can't be fixed."
Re: Scavenge pipe. [Re: PEH] #516206
11/26/13 5:04 am
11/26/13 5:04 am
leicester england
PEH Offline OP
PEH  Offline OP
leicester england
Thanks KC, if you don,t mind ill give it a couple of days to see, but i have my doubts about finding one over here.
Re: Scavenge pipe. [Re: Gary E] #516209
11/26/13 5:47 am
11/26/13 5:47 am
(You may want to frame this grin but )I agree with Gary. JB weld is good for plugging, leveling out cases that have been hacked at and filling cylinder heads. The times I had used it to try and secure something in place hasn't proved to be a good outcome, I think the reason is there isn't enough free area that the JB weld can fill in and hang onto.
Something like araldite which is an epoxy adhesive may be just fine, and heating the case up first.
