Peter R
Peter R
186 registered members (79T140E), 2,136 guests, and 563 spiders.
koan58 90
NickL 84
Lannis 83
505,428 mail-order LSR
Topics66,059
Posts639,368
Suggested source for piston rings? #513955
11/08/13 5:02 pm
11/08/13 5:02 pm
Houston, TX
H
HarveyH Offline OP
HarveyH  Offline OP
H
Houston, TX
I need a set of piston rings for my '70 A65L, stock bore, "good or better" quality for a street bike. Stateside vendor preferred but not mandatory.
Any suggestions?
TIA,
Harvey
1970 A65L (Yep, it's one of the "Y" bikes)
1942 HD45
1942 Boeing N2S-3
1930 Ford A
Re: Suggested source for piston rings? [Re: HarveyH] #513961
11/08/13 5:58 pm
11/08/13 5:58 pm
new jersey usa
pushrod tom Online content
pushrod tom  Online Content
new jersey usa
Hastings or Total Seal should be able to help you. Or....get in touch with one of the vendors who advertise here. They know whats up. PRT
Re: Suggested source for piston rings? [Re: HarveyH] #513962
11/08/13 6:13 pm
11/08/13 6:13 pm
Magnolia, TX
htown Online content
htown  Online Content
Magnolia, TX
+1 on the Hastings. What grit hone? Need to use something fairly coarse like a 220. Be sure and wash the bores with hot soapy water and a scrub brush after honing to remove stone residue. Should be able to run a white clothe through and see no residue. To prevent rust wipe down with clean rag with a little bit of oil on it.
I do a dry assembly just enough oil to get the pistons into the bores. Drop or two on each face of piston skirt.
Lot of opinions on break in oil. Consensus seems to be that modern auto oil rated SL or SM can cause cylinders to glaze.
I would use at least nothing above an SG rating. Personally, I used Rotella 15/40 diesel oil my last rebuild for first 100 miles, then changed to Valvoline 20w/50 4 stroke motorcycle oil, which is what I use year round in all my bikes. I got excellent ring seating following these steps with the Hastings rings.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: Suggested source for piston rings? [Re: HarveyH] #514014
11/08/13 11:51 pm
11/08/13 11:51 pm
Houston, TX
H
HarveyH Offline OP
HarveyH  Offline OP
H
Houston, TX
Thanks HTown for the great advice. I've always used straight mineral oil in my planes during break-in. Breaking in with synthetic or semi-synthetic oil will guarantee glazed cylinders in an aircraft engine!
What do you think of Aeroshell 100W (which is non-detergent 50 weight) for break-in? I've also got a case of Aeroshell 80W (non-det 40 wt) if the 50 wt is too thick.
Harvey
1942 HD45
1942 Boeing N2S-3
1930 Ford A
Re: Suggested source for piston rings? [Re: HarveyH] #514019
11/09/13 12:57 am
11/09/13 12:57 am
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
I believe 50 wt will be OK in Texas:).
Re: Suggested source for piston rings? [Re: HarveyH] #514065
11/09/13 10:27 am
11/09/13 10:27 am
Magnolia, TX
Magnolia, TX
Depends on the time of year. You might find the straight 50 makes kicking over and starting a little harder even here in the winter. IMHO absolutely the best time of year to ride here. I don't even ride much in the summer except for early mornings. To avoid semi-annual oils changes I just use the 20/50.
The problem with modern SL and SM auto oils is that they are loaded with friction reducers because modern cars run tite clearances and to increase gas mileage. Not good for bedding in rings. As long as the aero-oils don't have those shouldn't be a problem, 40wt would work as long as the weather is fairly cool.
As far as break-in what I did was start the engine up and blip the throttle never letting it idle or go above 3000 rpm for about five minutes or until it was warmed up good. Then overnight cool down and retorque head bolts and regap valves.
Next rides out in the country for 100 miles, varying throttle up and down through the gears, no steady running at one rpm. Not over 3500 rpm. Change out break-in oil to 20/50, retorque and regap valves. Then 500 miles same using gradually more rpm then another oil change retorque and regap.
1974 Trident
Re: Suggested source for piston rings? [Re: HarveyH] #514071
11/09/13 10:58 am
11/09/13 10:58 am
Allan Gill Online happy
Allan Gill  Online Happy
Id say the opposite, get some proper running in oil, its equal to 30wt, get it warmed up and then give it a good blast on the free way.
Do 10 miles then change the oil.
No good comes from nursing an engine.
Re: Suggested source for piston rings? [Re: HarveyH] #514076
11/09/13 12:01 pm
11/09/13 12:01 pm
Adam M. Offline
Adam M.  Offline
+1 to Allan advice, running in hard is necessary for this engines.
Mineral oil, first change after 60 - 100 km, blast it on lower gears after engine is warmed up, minimal amount of idling.
Every blast I did was to 80% of possible revs and slowing down after. It creates heat cycles helping to set the rings right.
One retorque was good enough for my engine.
Re: Suggested source for piston rings? [Re: HarveyH] #514082
11/09/13 12:49 pm
11/09/13 12:49 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
htown,
Did you mark the head nuts and bolts before and after re-torquing to see if they were ever below spec torque amounts? I've never experienced loose nuts or bolts during a torque check.
Re: Suggested source for piston rings? [Re: HarveyH] #514192
11/10/13 11:12 am
11/10/13 11:12 am
Houston, TX
H
HarveyH Offline OP
HarveyH  Offline OP
H
Houston, TX
While my experience is 90% aviation based, I have to agree with Htown on the retorque check. Air cooled engines grow and shrink quite a bit with variations in running-temperatures so a torque check following the first running of a topped engine is good advice.
I agree with all of you on not to baby new rings. My experience is to treat new rings "normally"; not too hard but not too easy either.
Harvey
1942 HD45
1942 Boeing N2S-3
1930 Ford A
Re: Suggested source for piston rings? [Re: HarveyH] #514297
11/11/13 11:09 am
11/11/13 11:09 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Harvey,
Since you are just replacing rings and honing off the glaze, make sure the piston skirt clearance is OK. Back in the day I have replaced rings only to later find out that new rings in a a worn bore don't fix anything. I find that with normal riding there is virtually no special "break-in" requirements. Never had a smoker at start-up after redoing a cylinder and I change 20-50w oil at 100 and 250 miles.
Page Time: 0.153s Queries: 15 (0.006s) Memory: 1.0692 MB (Peak: 1.2760 MB) Zlib disabled. Server Time: 2018-02-25 01:51:27 UTC
