T100Mark
T100Mark
Southern California
50 registered members (Adam M.), 221 guests, and 373 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,659 mail-order LSR
Topics68,846
Posts670,617
Members10,478
BSA B25 Points Cam #507592
09/23/13 5:39 pm
09/23/13 5:39 pm
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
I took a look behind the points cover on my Starfire and found that the cam for the spark advance turns freely back and forth it allotted travel, but there doesn't seem to be any spring tension to return it to its pre-advanced position. I have a feeling this a bad sign, like the spring is shot or missing. I've had this bike running but I haven't ridden it yet. It idles and revs fine. Any advice?
Re: BSA B25 Points Cam [Re: wkoenig] #507631
09/23/13 9:29 pm
09/23/13 9:29 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
There should be a couple of springs attached to the counterweights. Under loads and acceleration it is likely to advance rapidly and likely produce knocking (pinking). I think you can buy the springs. A lot of folks have perfectly good advance mechanisms that they'll give you since they converted to electronic ignition.
Re: BSA B25 Points Cam [Re: Mr Mike] #507640
09/23/13 10:05 pm
09/23/13 10:05 pm
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
Thanks Mike. I'll look for the springs. Meanwhile, if anyone has an AAU they like to offer, I'd be grateful.
Re: BSA B25 Points Cam [Re: wkoenig] #507685
09/24/13 8:38 am
09/24/13 8:38 am
crankbuster Offline
crankbuster  Offline
FYI: This is what it looks like:
http://www.youtube.com/watch?v=o3bPlWmetq8
Re: BSA B25 Points Cam [Re: crankbuster] #507688
09/24/13 8:53 am
09/24/13 8:53 am
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
Electronic ignition will 'transform' the running of your motor. I am more than happy with the Wassell unit I have in my B44.
Re: BSA B25 Points Cam [Re: LarryLebel] #507695
09/24/13 9:15 am
09/24/13 9:15 am
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
I understand that electronic ignition is the way to go, but I was hoping to avoid the cost and effort. As far as effort, how difficult/time consuming was the Wassell installation? This is my first rodeo with a Brit bike.
And how does the Wassell stack up against the other EI's?
Re: BSA B25 Points Cam [Re: wkoenig] #507705
09/24/13 12:26 pm
09/24/13 12:26 pm
triton thrasher Offline
The simple path is to replace the springs, if there's something wrong with them.
If you convert to electronic, you may end up buying expensive electrical improvements, to keep the ignition satisfied. That's maybe something to consider at your leisure, after you have a few rides on the bike.
Re: BSA B25 Points Cam [Re: wkoenig] #507716
09/24/13 2:45 pm
09/24/13 2:45 pm
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
OK, I've removed the points plate and the auto advance springs are in place, they just don't have enough tension to return the cam to the retarded position. I've removed the cam and springs, but the AAU plate is stuck solid. Will I need a puller to remove it? At this point, do you think new springs will help?
Re: BSA B25 Points Cam [Re: wkoenig] #507719
09/24/13 3:05 pm
09/24/13 3:05 pm
Do you have no manual?
Re: BSA B25 Points Cam [Re: wkoenig] #507720
09/24/13 3:07 pm
09/24/13 3:07 pm
If the cam is not stiff on the shaft, the springs usually pull it back to the retarded position with the engine stopped, at least when the points heel is not rubbing on the cam.
Re: BSA B25 Points Cam [Re: triton thrasher] #507740
09/24/13 6:12 pm
09/24/13 6:12 pm
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
The cam was not stiff on the shaft but the springs are too weak to provide any tension. I found some new auto advance springs on Eurotrash for $11 and will try those. if that doesn't do the trick it's time for an electronic ignition, probably Tri-Spark because of its ease of installation.
Re: BSA B25 Points Cam [Re: wkoenig] #507780
09/25/13 1:14 am
09/25/13 1:14 am
PM sent
Re: BSA B25 Points Cam [Re: DavidP] #507806
09/25/13 10:56 am
09/25/13 10:56 am
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
I would think installation of all the EIs is more or less the same. Most of the time is required to mount the black box some where (tool box in my case on my B44) and wire it up to the battery and run the trigger wires through the side case. You'll wire crimpers or a solder gun for this.
Re: BSA B25 Points Cam [Re: wkoenig] #507941
09/26/13 11:19 am
09/26/13 11:19 am
Wales
Ray Smith Offline
Ray Smith  Offline
Wales
My advice would be to stop messing with points and mechanical advance and retard.
I ran my B25 for a couple of years with points and auto advance unit.It was ok but the bike was at times difficult to start,often kicked back.Deciding I had to get it right I strobed the timing and found it to be all over the place.Messing with the points and auto unit brought little improvement.
On advice from others I fitted a Pazon unit.
The improvement is immense 1:- Guaranteed first kick starting (hot or cold engine) 2:-Better and reliable tickover. 3:-Better driving not always changing gear to keep the bike on the boil. 4:-Much improved fuel consumption. 5:-No longer eats plugs.6:-The bike is a lot more fun to ride
Best 97 I have ever spent on a bike
Re: BSA B25 Points Cam [Re: wkoenig] #507975
09/26/13 3:06 pm
09/26/13 3:06 pm
Don M. Offline
Don M.  Offline
I had the same experience with my 441 BitSA with the early, replacable pilot jet carb. After carefully adjusting the points & timing I could get the bike to start well--For awhile, then it would regress to the multi-kick mode. After installing a Pazon unit & adjustable throttle stop it consistantly starts 2 or three kicks cold & 1 when warm. The Pazon is better than some of the older electronic ignitions as it has the same advance curve as original. The old 2 step is OK for high revving twins that spend most of the time in the upper rev range but big singles spend much of their time at the low end, just chugging along. Cheers, Don.
Re: BSA B25 Points Cam [Re: Don M.] #508511
10/01/13 12:10 am
10/01/13 12:10 am
Nashville, TN
W
wkoenig Offline OP
wkoenig  Offline OP
W
Nashville, TN
So I replaced the Auto Advance Unit springs and this added sufficient tension to return the AAU cam to the retarded position. Not a lot of tension, but 100% better than before.
We'll see if this does the trick after I have a chance to time and reset the points and test drive the bike. Hope this $10 fix works well enough or else I'm going to install a Pazon unit.
