Buster Conrod
Buster Conrod
uniontown, pa, usa
28 registered members (Andy Higham), 270 guests, and 173 spiders.
Bart223, Duckster, IDG1, pemdoc65, creativecroc
10172 Registered Users
Lannis 97
Stuart 82
reverb 81
NickL 69
koan58 59
550,354 mail-order LSR
Topics66,557
Posts645,226
Members10,171
1962 Tiger Cub, #507115
09/19/13 8:43 pm
09/19/13 8:43 pm
San Diego Ca.
scottgarland Offline OP
San Diego Ca.
I bought three Tiger Cubs in baskets and started sorting things out to start putting the first one together. I have a Haynes shop manual and was about to mock up the bike (model T20)and found only two wires coming from the stator. Yellow and White. The wire diagram shows the normal three wire dark green, light green, green and yellow. What have I got here? Looking for a battery box, or dose this carry a battery? I have never done one of these bikes before and am in the learning curve.
Re: 1962 Tiger Cub, [Re: scottgarland] #507124
09/19/13 10:57 pm
09/19/13 10:57 pm
This should help...
http://www.cubsite.com/Cubs.htm
1956 Zundapp KS601EL
1960 Greeves Scottish/Hawkstone Velorex 560
1963 BSA Gold Star Spitfire
1964 Triumph T20SM
1965 BSA C15T
1966 BSA VE
1968 Bonham Tote Gote
1969 BSA VS
1970 BSA A65L (with a "Y")
1972 Husqvarna 450 WR
1986 Yamaha TT 225
1987 BMW K75C
Re: 1962 Tiger Cub, [Re: scottgarland] #507130
09/20/13 2:07 am
09/20/13 2:07 am
Stuart Offline
Stuart  Offline
Hi Scott,
Educated guess - "two wires" = 12V single-phase, "Yellow and White" = pattern aftermarket. Both wires would connect one each side of a rectifier, doesn't matter which way 'round as they're both carrying AC.
Risking stating the obvious, don't rush for one of these. Known as the Lucas RM13/15, as standard they were rigged to produce 6V, but can be connected to supply 12V; however, the output wasn't huge when they were new, any are at least 50 years old and the thin wires of the open coils were prone to breakage by vibration, if nothing else. frown Also, if the wiring diagram's the same as in the contemporary Triumph 'C'-range manual, it has a misprint that means all some of the 6V functions don't work if you follow the diagram. shocked
Finally here, if the alternator stator you have is 12V, bear in mind that it'll need a Zener diode - or the Zener and the rectifier replaced with a combined rectifier/regulator - that the '62 wiring diagram won't show.
The original 3-wire alternator indicates the bike would have had a battery originally, the battery provided at least some of the 'regulation' laughing in a 6V system.
Re: 1962 Tiger Cub, [Re: scottgarland] #507140
09/20/13 5:06 am
09/20/13 5:06 am
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
hi scott,
I'm over on the cubsite as well and there's a lot of info there
big D cycles have parts books online to view, and the cubsite has some manuals too.
Greystones in the UK have loads of parts and a decent website that will allow comparison of parts even if you don't buy from them.
I sympathise as although I have a complete 56, I bought a 60 on a whim and the PO has completely stripped it to the TINNIEST part and labeled nothing.
I had to go through each paint can/box and sort out the dead leaves, dead mouse and lawn mower parts from cub ones and bagged everything up and ticked off the parts list.
Re: 1962 Tiger Cub, [Re: AngloBike] #507142
09/20/13 5:20 am
09/20/13 5:20 am
Plymouth UK
doug748 Offline
doug748  Offline
Plymouth UK
1962 is a very nice year to have.
Following on from what AngloBike has said:
Mike Estall (Cub Guru) has a consolidated parts list available which you might find useful - as you have a bunch of bikes from different years:
mikeestall@hotmail.com
His book: The Triumph Tiger Cub Bible (Veloce) is my favourite bike book of all. It is not technical, in the rebuilding sense, but has loads of interesting information and a year by year overview. Expensive though! Some used copies were going for daft prices, but I think it has now been reprinted.
Re: 1962 Tiger Cub, [Re: Stuart] #507215
09/21/13 12:08 am
09/21/13 12:08 am
San Diego Ca.
San Diego Ca.
Thanks for the reply. After sitting down and looking at the diagram in good light at my desk I think I can work this out. A/C is A/C. I will build my own harness with the minimum, lights, horn, break light. I will put a battery in the system. Thanks again for your input.
Scott
Re: 1962 Tiger Cub, [Re: scottgarland] #507251
09/21/13 11:13 am
09/21/13 11:13 am
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
you don't say what state the rbuild will be. Or much about the bikes as-is
The nacelle mounted switch was a very complicated bit of wiring which brought in more elements of the alternator as you demanded pilot lights and or main lights.
if you're doing it up as a trials type you might want to convert to 12v and just rely on bar mounted switch gear. (or a headlight switch)
Re: 1962 Tiger Cub, [Re: scottgarland] #507357
09/22/13 2:02 am
09/22/13 2:02 am
Stuart Offline
Stuart  Offline
Hi Scott,
Don't know what your expertise level is but ime I wouldn't go just by the diagrams in the Haynes manual. frown I have the Lucas Motor Cycle Electrical Equipment Service manual - it's pretty clear that, at any given time, Lucas made a given harness from smaller, more-common sub-assemblies; the Lucas manual has a number of generic wiring diagrams that are pretty close to the individual diagrams in more-specialised manuals (that's how I spotted the misprint in the early 'C'-range manual). I got my copy of the Lucas manual from British Spares.
Re: 1962 Tiger Cub, [Re: scottgarland] #508047
09/27/13 6:39 am
09/27/13 6:39 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
Scott , sounds like your on the right track
... cubs came with 3, 4 and 5 wire stators ... all 6 volt , with some of the coil taps dedicated to ignition other taps to lighting ... and some cub models had no battery
If your stator has 2 wires I'm bettin' its a single phase 12 volt deal ,
RM21 pattern. .. and none of the bikes oringinal switching diagrams are gonna work without some standard 6 to 12 volt Tweeking ...
What year and what style build are you doing ?
Page Time: 0.043s Queries: 15 (0.005s) Memory: 1.0535 MB (Peak: 1.2382 MB) Zlib disabled. Server Time: 2018-04-21 22:56:41 UTC
