Mike, in Idaho
Mike, in Idaho
orofino Idaho
25 registered members (AML), 178 guests, and 65 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,531 mail-order LSR
Topics68,028
Posts661,829
Members10,383
Mixing and matching A65 trannys - layshaft end-pla #503584
08/27/13 10:59 pm
08/27/13 10:59 pm
Mark Z Online content OP
Mark Z  Online Content OP
I'm in the process of rebuilding what is mostly a 1966 Spit engine, with a 1965 LR crankcase, crank, and connecting rods.
I want to use the '66 gear cluster, because it was working well before, but I also have the gear cluster from the '65. Both gear clusters are assembled, and both appear to be in excellent condition.
Ok, so I was reading in the service manual about layshaft end-play. I never got into this before, because on previous rebuilds I've always put the same tranny back in the same case. I don't really want to disassemble the gear cluster, but the book says you have to do this to check the endplay.
So I decided to compare the thrust washers from the two gear clusters, and I found that the '65 thrust washer is noticeably thicker than the '66 thrust washer.
So I'm thinking, maybe I could just put the '65 thrust washer on the '66 layshaft and call it good. This would be assuming that the two layshafts are the same length, and only the cases are different.
Does this sound reasonable, or do I really have to disassemble the gear cluster? Can the layshaft end-play be checked with the entire gear cluster in place?
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503608
08/28/13 8:23 am
08/28/13 8:23 am
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
You can check the end play with the cluster assembled.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503740
08/28/13 10:30 pm
08/28/13 10:30 pm
Lay shaft end play is only checked with the gear cluster installed and the inner cover buttoned down. You then pull/push on the end of the lay shaft. You're wanting, "just perceptible," end play. The inside thrust washer comes in different thicknesses in order to set end play. I'd try the thick one first.
72 T150V yet to be named
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503746
08/28/13 11:18 pm
08/28/13 11:18 pm
Thanks Tom and David for the input! Tonight, I did just that, installed the gear cluster with the thicker thrust washer. Unfortunately, there's still excessive end-play. I mean a lot, like a sixteenth of an inch, maybe more. I didn't bolt down the plate, but it's right up snug against the case.
Now the question is, how/where do I get the correct thrust washer? Do I measure the end-play and then ask for a specific thickness? I hate to be pessimistic, but this has the scent of unobtainium.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503753
08/29/13 12:13 am
08/29/13 12:13 am
Forfar, Scotland
JER.Hill Offline
JER.Hill  Offline
Forfar, Scotland
Hi Mark
In the past I've added shims between the gear and thrust washers. The amount you have sounds a lot, you might want to tighten down the plate with two nuts and check again.
If you do a search, you'll find a few good posts on here by Gavin Eisler on gearbox set-up.
If your end float is 0.062", then I think you'll end up with shims at both ends to correct the end float and also get all your gears engaging/dis-engaging freely.
regards
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503791
08/29/13 8:29 am
08/29/13 8:29 am
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
You can get a shim assortment from McMaster-Carr. Reasonable.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #503956
08/30/13 2:06 pm
08/30/13 2:06 pm
My first thought would be about the spacer at the other end of the layshaft. Is it the correct one?
The 66 parts book shows three spacers for the left (clutch) side of the layshaft. 42-3079 0.113-115", 42-3212 0.120-122", and 42-3213 0.127-129". Given how little these spacers vary, a 1/16 inch gap would mean we are not talking about just the wrong spacer.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #504007
08/30/13 9:11 pm
08/30/13 9:11 pm
I perused the shim assortment page at McMaster Carr. A very useful resource there, thanks Tom. (Wish I had known about them years ago!)
I'll check out the spacer at the other end of the layshaft, although neither of these gear clusters have been disassembled, and the '66 tranny has been in use in the '66 crankcase for about 10 years with no issues.
Looks like I have more measuring and figuring to do. I brought home a dial indicator from work. One thing I should try is to put the '66 gear cluster back into the '66 crankcase, and measure the end-play there.
I'll get back with conclusions or at least real numbers.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #504034
08/31/13 3:10 am
08/31/13 3:10 am
Forfar, Scotland
JER.Hill Offline
JER.Hill  Offline
Forfar, Scotland
Hi Mark
Install the assembly and get a figure to compare against what you had originally. After that I think you should strip the assembly and built it up with only the lay shaft which will give a true figure for the lay shaft, which then can't in any way be influenced by the main shaft gears or selector system.
Depending on your findings, your probably going to have to strip the assembly to balance the shims, as its unlikely that you'll only have to add shims at the output end.
just may take on it.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #504066
08/31/13 10:58 am
08/31/13 10:58 am
Altoona, Florida
Mike Carter R.I.P. Offline
Altoona, Florida
Mark I have a ton of new old stock torrington needle bearings for the shaft. it is the one without cap they are both the same but the one in housing has a built in cap on back side..I the same bearing and fab a press in cap with silicone as there is not pressure..works fine let me know if you need a couple..The shimming process is not that difficult for us as we have a surface grinder and can make any size we need...
Mike Carter
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #504148
08/31/13 10:00 pm
08/31/13 10:00 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Mark,
What you are doing is what was never really done well at the factory in addition to the fact you are swapping gear clusters. The factory had tolerance limits on both the cases and the gearbox components. The used an assortment of spaces to get in the ball park. You can make nice improvements by fitting things and checking engagements. It is sorta like shimming for endfloat on the roller crank. You have do do it a couple of times to get it just right.
Re: Mixing and matching A65 trannys - layshaft end-pla [Re: Mark Z] #504462
09/02/13 10:26 pm
09/02/13 10:26 pm
Well first let me say that I've wasted some time (yours and mine) by not tightening down the gear cluster end plate before measuring. I wouldn't have guessed that it would make that much difference, but with the plate nuts snugged down lightly, I'm now getting .011" end-play on the layshaft. Perhaps acceptable, at least in the ball park.
I posted the photo because I'm kind of proud of my quick-and-dirty dial indicator mount - just an outer timing cover screw and a nut at either end to make it all rigid.
