Triless
Triless
OZ
28 registered members (AML), 198 guests, and 65 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,531 mail-order LSR
Topics68,028
Posts661,829
Members10,383
Page 2 of 2 1 2
Re: Champion vs NGK [Re: RF Whatley] #500204
08/02/13 11:37 am
08/02/13 11:37 am
Running from demons in WNY
Hillbilly bike Online content
I also think a 7 heat range is better for the way most Triumphs are ridden.But I have used 8's in some Triumphs and there were no complaints....
I use NGK B8EG in our LSR Triumph.I don't know if the fine wire G plug is the same exact heat range as a S plug...But plug reading said it was the perfect heat range for this 10.5 compression engine running wide open on 107 octane leaded racing fuel.
I ride dinosaurs....
Re: Champion vs NGK [Re: JBMorris] #502208
08/17/13 11:15 pm
08/17/13 11:15 pm
Farmington,Connecticut,USA
JBMorris Offline OP
JBMorris  Offline OP
Now , a year later, have been seeing a stumbling sputter that was intermittent but now is more pronounced at idle on up.
As it turns out, the sputtering was a sticking float needle in the left hand carb--Mikuni VM30's.
Bad gas or long spells sitting led to a glob of jelley in the float bowl bottom.
Mikuni floats have a dark coating and some of these flakes were floating around.
Quik spritz and cleanout spray brought the bike to smooth running and pulling strongly.
FWIW--HTH
1978 Bonneville T140V PX
Re: Champion vs NGK [Re: JBMorris] #502216
08/17/13 11:56 pm
08/17/13 11:56 pm
Originally Posted By: JBMorris
None of the local auto-stores had them but the nearest bike shop had plenty, NGK a bit cheaper than Champ's- he only had N3C for sale, all his own Triumph's had NGK fitted.
Local Guru
Nice Douglas your Guru has for sale!
Re: Champion vs NGK [Re: D.Bachtel] #502220
08/18/13 12:37 am
08/18/13 12:37 am
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
Nice thing about AMAL's is the drain plug.
Re: Champion vs NGK [Re: desco] #502334
08/18/13 9:02 pm
08/18/13 9:02 pm
JBMorris Offline OP
JBMorris  Offline OP
Originally Posted By: desco
Nice thing about Amal's is the drain plug.
The accessory toolkit from Sudco has a Mikuni float bowl drain plug wrench also...
The green wrench on the right side of the tool-tray is an original as supplied with the bike-- valve adjusting for setting the clearances.
Fits over the rockerboxes to make easy work ahead.
Got a few more original tools in there. . .
Re: Champion vs NGK [Re: JBMorris] #502443
08/19/13 11:43 am
08/19/13 11:43 am
Arlington, Massachusetts, USA
kurt fischer Offline
#irideslow
#irideslow
This has been answered before but I can't find it.
I need new plugs and Champion N3's are hard to find locally.
Crossover chart says NGK B8ES but memory says this is wrong.
Clarification please and thanks!
I go old school.
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: Champion vs NGK [Re: RF Whatley] #502485
08/19/13 5:09 pm
08/19/13 5:09 pm
Plymouth UK
doug748 Offline
doug748  Offline
Plymouth UK
I never worried a great deal about plugs but I just took the bike in for a re-bore and was shamed when the shop pointed out I had old, odd plugs; one was an offering by General Motors.
So I got two new NGK B7ES. Today I took the bike in for it's MOT test. Shamed again, when the examiner said it was running on one cylinder. Sure enough he was right, one of the new plugs had failed totally.
I thought plugs were simple things, what would cause one to fail? Could it be brought back to life (scientific interest only, its going in the bin) ?
Re: Champion vs NGK [Re: kurt fischer] #502494
08/19/13 6:20 pm
08/19/13 6:20 pm
JBMorris Offline OP
JBMorris  Offline OP
That young man was Kenelm Lee Guinness, of the brewing family, and he was, in his own words, "mad about racing". While studying at Cambridge University he had acted as mechanic to his older brother, Sir Algernon Guinness. Upon leaving Cambridge, Kenelm had taken up racing on his own account and found a home for his racing sable in some outbuildings at an old disused inn called The Bald Faced Stag at Putney Lane on the London to Portsmouth road.
Never heard of that brand before but a good story nonetheless.
Re: Champion vs NGK [Re: doug748] #502503
08/19/13 7:17 pm
08/19/13 7:17 pm
Bishop, Calif.
Bishop, Calif.
Doug,
Do you check for the correct gap before you put them in and do you use a socket specifically designed for spark plug installation?
The wrong gap or cracked porcelain will do them in.
If another new plug fails it's symptom of other problems.
Page 2 of 2 1 2
