Kenneth Million
Kenneth Million
Jonesborough, TN
19 registered members (76degree-triumph), 166 guests, and 116 spiders.
10174 Registered Users
Lannis 94
reverb 91
Stuart 70
koan58 67
L.A.B. 54
552,769 mail-order LSR
Topics66,586
Posts645,507
Members10,174
B31 Engine Oil #5012
09/27/05 11:56 pm
09/27/05 11:56 pm
Ipswich Qld Australia
Thommo Offline OP
Thommo  Offline OP
Hi all,
I've recently purchased a 51/52 Plunger B31. I don't know much about it or it's history, so I'd like to do a bit of a service on it. I don't know what grade of oil to use, so any advise as the what is required would be greatly appreciated.
I live in Queensland Australia, so things are going to be pretty warm here for the next 6 months, I expect that will influence my choice of oil.
Re: B31 Engine Oil #5013
09/28/05 7:11 pm
09/28/05 7:11 pm
If you can't find monograde 40, use 20W/50 multigrade.
These grades seem to be thick enough not to burn up into clouds of blue smoke in hot old engines.
Re: B31 Engine Oil #5014
09/28/05 10:54 pm
09/28/05 10:54 pm
Melbourne, Australia
Melbourne Metisse Offline
G'day Thommo,
I know that this will raise a few hackles but I wouldn't be putting mono grade oil in ant bike. Have you seen how long it takes to pour when cold? I shudder to think how long it would take to get through tiny oilways and the damage that will occur in the meantime...
I'm based in Victoria so although we don't get your heat extremes, it still gets quite toasty so I use Penrite HPR40. It's a 25W-70 oil that has no friction modifiers (good for clutches!) that is designed for Aussie conditions
Re: B31 Engine Oil #5015
09/29/05 12:02 am
09/29/05 12:02 am
Thommo Offline OP
Thommo  Offline OP
Thanks All for your feedback,
I spent my early years in Victoria and know how hot it gets down there - it's just a different kind of hot. I'll give the HPR40 a go.
Re: B31 Engine Oil #5016
09/29/05 6:02 pm
09/29/05 6:02 pm
There's no such thing as 25w-70 oil over here in UK, but if there was, I'd probably try it.
Re: B31 Engine Oil #5017
09/30/05 1:43 pm
09/30/05 1:43 pm
Duesseldorf/Germany
Phil in Germany Offline
Duesseldorf/Germany
TT;
there is such thing in the UK too. Penrite has a branch in the UK.
Check out their website.
Penrite Australia
You have to look for their product information and then HPR oils. Their Australian website has more information than the English one.
Hope this helps and best regards
Phil
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: B31 Engine Oil #5018
10/01/05 7:06 pm
10/01/05 7:06 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
The FIRST thing you want to do is disconnect the oil lines and put a high pressure hot water sprayer down in the tank. When this engine was first run there was nothing available but non-detergent oils. So there's about 3/4" of crud in the bottom of your oil tank. You have to get that out before running modern detergent engine oils, or they will circulate all that grit over and over until the whole thing is worn slap out.
Wouldn't be a bad idea to fit a small oil filter on the RETURN oil line if you have the money. One from a '75 Norton is easily had new from many Norton sources for under $40US.
On a tight engine a multi-grade oil would be best, but on one of unknown mileage I would tend to prefer a solid weight. Of course, with a solid weight you need to warm up the oil and be careful not to race the engine until you feel the tank start to warm. Also depends upon your driving habits and locale.
Drop by the local Harley shop and see what they use. Your engine oil needs would be much the same as a big H-D. Then go buy the equivilent at the local discount store!
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: B31 Engine Oil #5019
10/02/05 12:40 pm
10/02/05 12:40 pm
If you're going to clean the oil tank, make sure you do it right and get the inside completely spotless. Otherwise you'll do moe harm than good by disturbing the dirt.
Page Time: 1.825s Queries: 14 (0.007s) Memory: 1.0370 MB (Peak: 1.2053 MB) Zlib disabled. Server Time: 2018-04-25 08:49:25 UTC
