Chris Pellett
Chris Pellett
Lewes, Sussex UK
199 registered members (1xfatboy), 2,188 guests, and 541 spiders.
koan58 89
Lannis 82
505,080 mail-order LSR
Topics66,047
Posts639,299
Triumph 750 left hand shift to right hand shift #501607
08/13/13 10:52 pm
08/13/13 10:52 pm
Corning N.Y.
choppadude Offline OP
Corning N.Y.
Did one of these years ago but cannot for the life of me remember exactly what I did.
I know I can press out the receiver for the crossover shaft from the gear change quadrant and press in an earlier right shifter shaft from an earlier 650/750. I think I either had a bushing made to receive the earlier and smaller diameter of the inside of the shaft or used one from an earlier inner tranny cover.
I am sure I am missing something.
The end result will be putting a 1976 750 Bonneville motor into a 1967 frame.
If anyone can help jar this old brain it would be very much appreciated
Re: Triumph 750 left hand shift to right hand shift [Re: choppadude] #501611
08/13/13 11:39 pm
08/13/13 11:39 pm
Jon W. Whitley Online content
Steve,
When I did this to my 1977 T140 engine, I used an earlier right side shift inner and outer cover set, complete and ready to bolt on. It also went into a '67 frame. bigt
Re: Triumph 750 left hand shift to right hand shift [Re: Jon W. Whitley] #501614
08/13/13 11:48 pm
08/13/13 11:48 pm
Corning N.Y.
Corning N.Y.
Originally Posted By: Jon W. Whitley
Steve,
Still need to change the gearshift quadrant ( pressing out the crossover shift shaft) as well as change the operating quadrant right?
Re: Triumph 750 left hand shift to right hand shift [Re: choppadude] #501616
08/14/13 12:18 am
08/14/13 12:18 am
Australia
downhere Offline
downhere  Offline
Australia
Then what do you do for a rear brake? Seems a lot of trouble?
Re: Triumph 750 left hand shift to right hand shift [Re: choppadude] #501618
08/14/13 12:26 am
08/14/13 12:26 am
He's using a 67 frame so the brake is already sorted.
Re: Triumph 750 left hand shift to right hand shift [Re: choppadude] #501627
08/14/13 12:55 am
08/14/13 12:55 am
wisconsin
jurbanec Offline
jurbanec  Offline
wisconsin
put a plug (i used a freeze plug) in the hole on the primary side where the shift lever came through the inside of the main casting. Otherwise engine vents back into gearbox. Been there, done that. I kept the original 750 inner cover and used an earlier outer if I remember. Make sure you swap the pawl assembly.
Re: Triumph 750 left hand shift to right hand shift [Re: choppadude] #501678
08/14/13 9:05 am
08/14/13 9:05 am
Yes, gear change quadrant and cam plate operating quadrant. I did this back in '94 or so but on second thought I I did use the T140 inner cover and only used the earlier outer cover to make the swap. Holes were plugged internally.
Steve,
Page Time: 0.059s Queries: 15 (0.006s) Memory: 1.0343 MB (Peak: 1.2001 MB) Zlib disabled. Server Time: 2018-02-24 12:04:52 UTC
