29 registered members (Alan_nc), 209 guests, and 459 spiders.
10257 Registered Users
Stuart 77
Lannis 56
610,291 mail-order LSR
Topics67,138
Posts651,518
Members10,257
1939 BSA M22: Will a Triumph 4 spring clutch fit? #378463
06/12/11 10:07 am
06/12/11 10:07 am
Gothenburg, Sweden
Morgan aka Admin Offline OP
Ride safe today!
Ride safe today!
Gothenburg, Sweden
I am going to buy a 1939 BSA M22 (KM22) in original look.
It has a 6 spring BSA clutch and I wonder it's possible to buy and fit a 4 spring triumph clutch with BSA adaptor?
Would it fit right on? anyone out there having knowledge or experience with this?
BSAing you
Morgan Johansson
BritBike.com.
____________________
Morgan on Facebook | BritBike on Facebook | Twitter | Skype: "britbike.com" |
Join our BritBike MotorCycle Forum on Facebook
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378471
06/12/11 11:14 am
06/12/11 11:14 am
BSA_WM20 Online content
BSA_WM20  Online Content
Mainshafts all have the same taper so the Trumpet conversion will work the same as it would on any other BSA.
Because the primary is tin & not aluminum you will need to adjust the position of the engine sprocket to get proper alignment of the primary chain which is done by altering the spacer behind the sprocket.
I use old ball race outers ground down to whatever size is needed.
Occasionally some clutch drums will sit out too far and foul on the case in which case a thicker primary gasket ( or 2 ) will sort it out short term.
Not all clutch centers are the same.
The tapered holes are different sizes ( taper is the same ) which alter the position on the main shaft so it might be worth while getting a few old ones.
When I was buggering around with the clutch conversion on the WM 20 there was better than 1/2" difference in position on the main shaft between the 1/2 dozen or so had I had in the " clutch parts box " so I will have to sort that one out a bit later.
If you are going that far you may as well do the alloy pressure plate conversion as well. It is well worth while.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378482
06/12/11 12:31 pm
06/12/11 12:31 pm
Gothenburg, Sweden
Ride safe today!
Ride safe today!
Gothenburg, Sweden
Thanks for the input, I heard somewhere that there are two different adaptors but have not had it verified so your input is of great interest.
At first i want to assemble the 6 spring clutch and start the bike and test it.
You see this winter he had done some work on it but missed to mount the primary chain link clip so when I started it the chain broke and damaged several teeth on front and clutch sprocket. So i had to in my office clothes remove the hole primary
fix it and reassemble again. Well I couldn't finish the job as i didn't have a chain split link and i also noticed that the front sprocket was out of alignment.
The sprocket was to far out and I couldn't refit the sprocket nut as the spring was to heavy to push in so far.
I'm ready to go back tomorrow with a new spacer The old was 19,6 mm or more than 3/4". My eyes said that i could reduce spacer to at least 5/8".
Allan: Nope do not want to modernize tha bike that much fitting a newer G-box.
I could have use of engine sprocket parts. the sleeve anyway.
Step 1, fix the primary so I can test it properly
step 2, buy it and then buy a complete 4 spring clutch
If more tips are available please keep em coming..
Nice bike eh..
BSAing you
Morgan Johansson
BritBike.com.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: ] #378632
06/13/11 9:54 am
06/13/11 9:54 am
Muriwai,New Zealand
Llewelyn Offline
Llewelyn  Offline
Muriwai,New Zealand
Originally Posted By: 1968BSA
out of curiosity, could you fit a later pre-unit A10 type gearbox? into something like the M20/ 22 etc
Here is an image of a cool rigid b31 fitted with a swingarm box.Doing the same thing myself just have to cut some front engine plates to mount motor then pattern rear plates to suit different g/b mounts.M20 should have a little more room than the b series and i have seen a s/a box mounted on its side in a 1930's bsa v twin
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378634
06/13/11 10:57 am
06/13/11 10:57 am
Somerset UK
Offshore Dave Offline
Somerset UK
Hi Morgan, I would be interested how the clutch mod goes. I have a 1936 model Q8, empire star, which has the single spring clutch, it would be good to fit the later clutch. The Q8 gearbox/clutch was basically later used on the early M20's, so I am thinking it might just be possible to go the clutch route you are looking at. Having said that the primary chain case is all alloy and (I believe ) specific to the Q8, so not sure there is room for the later design of clutch.
Rgds Dave
1967 Rickman Metisse 8 valve road race.
1970 T120R.
1974 TR7 + Squire sidecar.
1976 T140V
1936 BSA Q8 Empire Star
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378649
06/13/11 1:59 pm
06/13/11 1:59 pm
Yea, Morgan, I'd be very interested to find out how you do with this since I'm still undecided as to whether to use the original six-spring or upgrade as you are on my M23.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378724
06/13/11 8:13 pm
06/13/11 8:13 pm
Gothenburg, Sweden
Ride safe today!
Ride safe today!
Gothenburg, Sweden
Went today and worked with the M22, mounted the primary but left the outer cover. The six spring clutch was really saggy and I had trouble getting it to work properly. However the main thing was to start and run the bike and so I did. Conclusion is i will get a trailer, buy and fetch it tomorrow. big smile grin
I can tell you it will look good in BritBike Museum
Ps i will probably buy a complete 4 spring and five friction plate clutch from SRM with that nice new adapter. Fit that onto my touring goldie. Then i will take the present 4 spring clutch from my Goldie which has 4 friction plates and use that on the old M22 which does not have that much POWER.. wink
Beware this might take several months before it's been done
BSAing you
Morgan Johansson
BritBike.com.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378728
06/13/11 8:53 pm
06/13/11 8:53 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
Morgan , I have no experience with your situation but I have fit the 4 spring to an A-10 and a couple things I haven't seen mentioned are the adaptors.There were some made in the past that were wrong taper , I ended up with one and it gave me fits trying to make it work , Rabers in CA. stock the correct pieces.With my setup I was able to use a 3 spring center hub with the cush drive giving me more options with the engine sprocket/compensator/alignment.Also the alloy 3 spring plate is far easier to come by.One last thought , I have what I thought was the standard 4 spring chainwheel in good very shape but when I got it home I found it is nearly 3/8" sallower than standard .Since you may require fewer plates if you run into clearance issues with the chaincase cover this might work for you ,I'd be happy to pass it along.
FWIW-BONZO
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378743
06/13/11 9:40 pm
06/13/11 9:40 pm
Gothenburg, Sweden
Ride safe today!
Ride safe today!
Gothenburg, Sweden
Thank you Bonzo for your offer however i have found it bad to get parts from different suppliers when it comes to the clutch.
I will get me a complete clutch where i know everything will work together.
The 3 spring option is of course interesting but i'll stick with the 4 spring non cushion hub.
BSAing you
Morgan Johansson
BritBike.com.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #378919
06/14/11 9:12 pm
06/14/11 9:12 pm
Gothenburg, Sweden
Ride safe today!
Ride safe today!
Gothenburg, Sweden
here is the bike in BritBike Museum. Our newest family member!!!
lookin good eh!
BSAing you
Morgan Johansson
BritBike.com.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #379402
06/17/11 12:57 pm
06/17/11 12:57 pm
Rich B Offline
Rich B  Offline
Looking good Morgan, the M22 will look even better next year as I ride it to the rally in Sweden bigt laughing
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #379601
06/18/11 5:07 pm
06/18/11 5:07 pm
holland
theo Offline
theo  Offline
holland
The pre war M OHV looks verry good and ride fantastic the bikes i make have the M20 one spring clutch and works well only my M23 1940 have a 6 spring clutch
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #500975
08/09/13 11:34 am
08/09/13 11:34 am
Rotherham, UK
Ian Clifton Offline
Ian Clifton  Offline
Rotherham, UK
Hi Morgan,
I know I'm dredging up the past with this, but would like to know how things went?
I'm having 6 spring clutch woes on my M33!! Would like to get it working better, but the Triumph 4 spring sounds like a better option!!
Also, I will need to obtain a BSA single spring clutch for my WM20 project if anyone could help?? or I may have to go down the Triumph route again.. crazy
Just a few Beezers.. ☺
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Ian Clifton] #500980
08/09/13 12:10 pm
08/09/13 12:10 pm
Death row next in line norfolk
Tribsauk Online content
Tribsauk  Online Content
I fitted a new TRIUMPH 3 spring clutch to a 1937 BSA HM21 also have a 4 spring TRIUMPH clutch fitted to my 1949 B33 & 1950 ZM20 much superior clutch than the six spring BSA!! a case of fit and forget.Thinking of doing same on my WM20 as I use the prop stand a lot and oil is getting into clutch resulting in a badly slipping clutch..Dave
1941 BSA WM20
1958 TRI-BSA 750 PRE UNIT
1957 THUNDERBIRD
1932 R E MODEL GS SPECIAL
1947 BSA YM21
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Tribsauk] #500983
08/09/13 12:21 pm
08/09/13 12:21 pm
Rotherham, UK
Ian Clifton Offline
Ian Clifton  Offline
Rotherham, UK
Sounds like I'm half way there now Dave.. bigt Why though, am I being told the hub adapter will only fit the swinging arm boxes? Is there any fettling involved?
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Ian Clifton] #500990
08/09/13 1:00 pm
08/09/13 1:00 pm
Germany
Pete C Offline
Pete C  Offline
Germany
I have a 4 spring on my M21 and I believe the adaptor is different to that used on the standard swinging arm box. Kiddiminster motorcycles apparantly have the modified adaptors for the plunger/rigid variants.
Pete
Pete
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Pete C] #500992
08/09/13 1:05 pm
08/09/13 1:05 pm
Rotherham, UK
Ian Clifton Offline
Ian Clifton  Offline
Rotherham, UK
Cheers Pete.. I'll give them a ring.. bigt Just rung them and ordered the full kit.. 6 spring clutch woes no more!!! grin
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Morgan aka Admin] #501043
08/09/13 9:29 pm
08/09/13 9:29 pm
Missouri
BSA Nut Offline
BSA Nut  Offline
Missouri
I'm in process of adapting a 6 spring set up to an early pre-war hand change 3 speed. You guys have a wealth of information between you. I may have to alter the output shaft length, it seems very long with the cone type pressure plate. Havent taken any measurements, yet. I will keep watching this post for pointers.
Re: 1939 BSA M22: Will a Triumph 4 spring clutch fit? [Re: Ian Clifton] #501430
08/12/13 8:26 pm
08/12/13 8:26 pm
Just spent Saturday stripping out WM20 single spring clutch to find it soaked in oil again!! done less than 1000 miles since I last did it.All cleaned up with new o ring seals fitted new gaskets will also use rear stand as its definately gearbox oil seaping into clutch thru output shaft.The original cork main seal is worn so I shortened it a bit then fitted a O ring either end .Last chance then its TRIUMPH clutch time!!!!!!!
1941 BSA WM20
1957 THUNDERBIRD
1947 BSA YM21
