BRIT-FE
BRIT-FE
Lorton, VA
187 registered members (79T140E), 2,139 guests, and 564 spiders.
koan58 90
Lannis 83
505,477 mail-order LSR
Topics66,060
Posts639,381
ATF in chaincase? #256515
05/31/09 3:36 pm
05/31/09 3:36 pm
Mankato, MN
theageofindustry Offline OP
Mankato, MN
I saw in another thread that people use ATF in there chaincase and didn't want to threadjack.
I haven't heard that before, is it safe for the clutch? I guess that's my only concern. That, and what kind are you using? dextron, mercron, etc... Brand of choice? Thoughts, opinions...
Re: ATF in chaincase? [Re: theageofindustry] #256523
05/31/09 4:17 pm
05/31/09 4:17 pm
The automatic transmission in your car is full of clutch packs that aren't much different than what's in your bike so atf is just fine for your clutch.
As to what to use,I don't think it really matters. If I were to do it I would use Dexron because that's what all my cars use and I already have some on hand.
What bike do you have?
Re: ATF in chaincase? [Re: theageofindustry] #256524
05/31/09 4:18 pm
05/31/09 4:18 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
i use ATF Ford type in my A65 with good results
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: ATF in chaincase? [Re: raf940] #256535
05/31/09 5:14 pm
05/31/09 5:14 pm
Orange Park Florida
JTsmks Offline
JTsmks  Offline
Orange Park Florida
AOI, what bike do you have? If I'm not mistaken most OIF models mixe the chaincase oil with it's engine oil so you do not want to put ATF in an OIF chaincase.
"All parts falling off this bike are of the finest British craftsmanship"
Re: ATF in chaincase? [Re: JTsmks] #256539
05/31/09 5:27 pm
05/31/09 5:27 pm
Mankato, MN
Mankato, MN
I have a 67 bonneville and a 68 bonneville,sorry.
Right now I am just using non-detergent 20 wt el-cheapo, but always looking for the hot tip.
My buddy has OIF, and yes, it uses engine oil.
Re: ATF in chaincase? [Re: theageofindustry] #256548
05/31/09 6:22 pm
05/31/09 6:22 pm
I don't see any advantage to switching from what you're already using. As long as there's something in there to lube the chain you're good to go.
Re: ATF in chaincase? [Re: theageofindustry] #256552
05/31/09 6:22 pm
05/31/09 6:22 pm
Manchester, Connecticut, USA
Tom D. 67 Bonny Offline
Any ATF works just fine in my '67 Bonny with Barnett friction disks. It is also the right viscosity for the front forks with my 220 lb. weight. (Is ATF 5 or 10 wt?)
Tom
Tom D. 1967 T120R Bonneville
Anyone know of a place that sells Loctite
by the quart?
Re: ATF in chaincase? [Re: Tom D. 67 Bonny] #256558
05/31/09 7:19 pm
05/31/09 7:19 pm
South East England
Graham Ham Offline
Private sponsor
Graham Ham  Offline
Private sponsor
South East England
A word of caution !
Although many folk do indeed use ATF, with, as far as I can tell, good results, you need to be sure that your bike's chaincase is a 'sealed' unit from the engine. Many models have unsealed mains, and indeed use the chaincase as part of the breathing system from the engine, and as such engine oil is blown, and indeed sucked between the two.
You don't wanna get ATF in yer engine oil !
G.
Good judgment comes from experience, but the most memorable experiences tend to come from bad judgment!
http://www.panther-publishing.co.uk/default.asp?contentID=18
Re: ATF in chaincase? [Re: Graham Ham] #256615
05/31/09 10:35 pm
05/31/09 10:35 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
You can try Mercon or any other modern ATF, but if you have any signs of clutch slipping convert to the older Type-F. As has been stated, ATF in the primary does NOT apply to any primary breather models. That's 1969 and prior years on the 650.
The advantage is less clutch sticking, less first gear grinding, and longer primary chain life.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: ATF in chaincase? [Re: RF Whatley] #257083
06/03/09 12:32 pm
06/03/09 12:32 pm
bromley uk
norton bob Offline
norton bob  Offline
bromley uk
ATF also helps you identify leaks (red) hypoy (green)gearbox and brown engine. some ATF,s can attack paint so fix the leak!
Re: ATF in chaincase? [Re: norton bob] #279548
10/17/09 10:49 pm
10/17/09 10:49 pm
NSW, Australia
NSW, Australia
My triumph workshop manual says capacity is 350cc for 69, 650 model or quote: "Alternatively, the correct level can be achieved using a measure of 350cc".
This isn't right, oil will pour out of the oil level plug at 150cc, another aftermarket manual a friend has says 150cc for 650 and 350cc for 750 machines, there must be a larger area in there to accomodate the triplex??
I've always used the plug and never measured out 350cc and dumped it in there but this time I did and got a big surprise on the floor! I wonder how many people dump 350cc without removing the oil level plug because that's what the TRIUMPH manual says to do?
Re: ATF in chaincase? [Re: ] #279994
10/20/09 10:08 pm
10/20/09 10:08 pm
Folsom, CA
Y
yellow_cad Offline
yellow_cad  Offline
Y
Folsom, CA
So, just to reiterate, it is OK to run ATF in an early 1970 Bonneville, correct?
Jim
1970 Triumph Bonneville
1973 Commando Interstate
1971 OSSA MAR
Re: ATF in chaincase? [Re: yellow_cad] #280026
10/20/09 10:42 pm
10/20/09 10:42 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
yellow cad, NO. Jack
Re: ATF in chaincase? [Re: yellow_cad] #280046
10/21/09 3:35 am
10/21/09 3:35 am
JubeePrince Online content
JubeePrince  Online Content
That would depend, perhaps. How early exactly? Early in the model year or early in the calendar year? The engine number should be the definitive answer.....
Re: ATF in chaincase? [Re: JubeePrince] #280214
10/22/09 2:28 am
10/22/09 2:28 am
Folsom, CA
Y
yellow_cad Offline
yellow_cad  Offline
Y
Folsom, CA
My engine number is AD37669. Please let me know what that says regarding the breather and what I can use in the chaincase. Thanks.
Jim
1971 OSSA MAR
Re: ATF in chaincase? [Re: yellow_cad] #280215
10/22/09 3:10 am
10/22/09 3:10 am
Bud Provin Offline
Bud Provin  Offline
Unless your engine has been modified it does not have a seal at the crankshaft and you should not use ATF.
ATF is an excellent solvent and if mixed withe oil would probably break loose all the sludge in the motor-including that in the crank's sludge trap.
Re: ATF in chaincase? [Re: ] #280296
10/22/09 4:48 pm
10/22/09 4:48 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
This isn't right, oil will pour out of the oil level plug at 150cc, another aftermarket manual a friend has says 150cc for 650 and 350cc for 750 machines, there must be a larger area in there to accommodate the triplex??
The correct way to tell the primary oil level for ANY primary case is that the bottom run of the primary chain should just skim the surface of the primary oil. You can check this with a strong lamp. In this way the chain picks up the oil and makes an oil mist that lubes everything in the case. Guys with primary strobe windows can testify as to the presence of the oil fog.
The oil level screws run into the cover will strip out on you if you're not really, really careful.
bigt
RF Whatley
Cornelia, GA
Re: ATF in chaincase? [Re: RF Whatley] #280412
10/23/09 5:36 am
10/23/09 5:36 am
NSW, Australia
NSW, Australia
Why thank you Richard, all the way from Georgia!
Little discrepancies or misunderstandings in the manual can be cleared up easily with the help of a good forum.
KK
Re: ATF in chaincase? [Re: theageofindustry] #381849
07/01/11 12:02 pm
07/01/11 12:02 pm
orange county ny
npw Offline
npw  Offline
orange county ny
How does one check the oil level in the chain and gear cases?
Re: ATF in chaincase? [Re: theageofindustry] #381850
07/01/11 12:08 pm
07/01/11 12:08 pm
orange county ny
npw Offline
npw  Offline
orange county ny
What about the level in the gearcase? How do you tell the level is correct and what oil is used?
Re: ATF in chaincase? [Re: npw] #381987
07/02/11 5:22 am
07/02/11 5:22 am
redondo beach, ca
Bob G Offline
Bob G  Offline
redondo beach, ca
Set your bike level. Find your gear box drain plug. There is a smaller bolt head located in the center of the drain plug.Remove this small bolt.
Fill your transmission until you see a little oil come out that hole. Wait until it stops until you put the plug back in.
Just about any cheapo auto differential oil in the 90w range works. There is some controversy regarding synthetics.
Bob Gregor
Re: ATF in chaincase? [Re: ] #382013
07/02/11 10:06 am
07/02/11 10:06 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
150cc is the correct "Initial fill" amount for all '70-on 650/750 twins as far as I'm aware?
The General data sections of both the '72 650 OIF and '73-'78 T140 factory manuals gives the primary chaincase capacity (initial fill only) as "5/8 pint - 350cc" which I believe is an error carried over from the earlier pre-OIF manuals for sealed chaincase models?
In the "Lubrication" section (Sec. A) of both manuals, the primary initial refill amount is given as "1/4 pint" (1/4 Imperial pint = approximately 150cc).
The 350cc error was apparently corrected in the later '79-on factory manual-as the initial fill amount is listed in the Capacities section as "150cc".
(300-350cc is the correct primary refill amount for BSA/Triumph triples)
Re: ATF in chaincase? [Re: yellow_cad] #382022
07/02/11 12:38 pm
07/02/11 12:38 pm
dave jones Offline
dave jones  Offline
Yellow Cad- A simple way to tell if your bike has the later breathing system is whether it has a large diameter breather pipe coming from the rear of the chaincase above the gearbox. If it is there then you can't use ATF.
Bikes that can use atf have the breather pipe coming from under the engine.
What I found on my 1967 bike is that if I empty the chaincase ready for an oil change not all the oil comes out. If I measure a new lot out and add it I end up with too much oil in the case which makes my clutch slip a little. I, therefore, use the level plug with the bike on its wheels and held vertical.
I have found that if my clutch is set up correctly it works equally well with 15W50 or thin oil although I haven't tried atf which is very thin. It is only about 5W(?)
Re: ATF in chaincase? [Re: theageofindustry] #498452
07/21/13 2:18 am
07/21/13 2:18 am
Australia
Adrian1 Offline
Adrian1  Offline
Australia
My bike has an engine breather coming from just below the rear of the cylinder barrels. Also has a breather pipe coming from midway in the chaincase. Motor is 6T circa 1962. Am I ok for ATF?
Re: ATF in chaincase? [Re: Adrian1] #498453
07/21/13 2:21 am
07/21/13 2:21 am
Jon W. Whitley Online content
I am going to say yes.
Page Time: 0.169s Queries: 15 (0.008s) Memory: 1.1916 MB (Peak: 1.5332 MB) Zlib disabled. Server Time: 2018-02-25 02:02:11 UTC
