38 registered members (Al Eckstadt), 259 guests, and 75 spiders.
10381 Registered Users
Mori55 98
NickL 86
Stuart 83
DavidP 79
reverb 73
Triless 68
688,100 mail-order LSR
Topics68,001
Posts661,478
Members10,381
Poor idle on '73 750 Tiger #494689
06/19/13 6:40 pm
06/19/13 6:40 pm
TN/VA/FL USA
F
fried okra Offline OP
F
TN/VA/FL USA
I picked up a nice original single carb 750cc '73 Tiger today. The bike starts easily and runs great at all throttle openings but won't idle well. The bike runs ragged and uneven at idle. Idle speed is roughly 1000 rpm.
The 930 AMAL was replaced about 10 years ago and maybe has a couple thousand miles on it. It idles best with the mix screw turned out about one quarter (1/4) turn from seated.
Any thoughts on where to start looking??
thanks,
fried okra
Re: Poor idle on '73 750 Tiger [Re: fried okra] #494691
06/19/13 6:47 pm
06/19/13 6:47 pm
#78 drill through the pilot jet followed by a good spray of carb cleaner through the passageways making sure they are clear. Modern fuels do not like small jets and try to block them.
Re: Poor idle on '73 750 Tiger [Re: kommando] #494693
06/19/13 6:53 pm
06/19/13 6:53 pm
TN/VA/FL USA
F
F
TN/VA/FL USA
Thanks....I've got some #78 drill bits ordered, can hardly wait for them to get here in about a week!!!!!
fried okra
Re: Poor idle on '73 750 Tiger [Re: fried okra] #494732
06/20/13 12:33 am
06/20/13 12:33 am
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
With needing to be 1/4turn from seated for best idle, it sounds like blockage to me too. Turning the mixture screw inward cuts the air supply off to the idle circuit, so either the fuel is restricted or there's an air leak elsewhere (manifold, etc).
I hear the US gasoline has an alcohol content. That won't be good news for carburetors, especially zinc based ones. I speculate that even the small amount of alcohol in the fuel will be attracting moisture. I run alky in the dragbike so I see the damage it can do. The carbs get drained EVERY time on that bike.
So I just wonder how the Amals are they holding up to the US fuel?
Re: Poor idle on '73 750 Tiger [Re: Excalibur] #494740
06/20/13 1:21 am
06/20/13 1:21 am
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
@ Excalibur
They are holding up just fine. Bored and sleeved to correct wear problems, an annual PROPER cleaning and a bit of spring time general maintenance works miracles. I have access to aviation gas and I quit using it as it plugged up the idle jet all the time. I don't know how planes run on it.
PS Bless you for keeping Triumph in the records book.
