dudley32
dudley32
45 registered members (Alan_nc), 342 guests, and 378 spiders.
10294 Registered Users
Stuart 97
Lannis 68
Mori55 67
639,834 mail-order LSR
Topics67,416
Posts654,602
Members10,294
T140 valve guides? #487665
04/27/13 7:01 pm
04/27/13 7:01 pm
Rugby,United Kingdom
Jel Offline OP
Jel  Offline OP
Hi..
would like a little advice on what to about my valve guides please.
T140V (1979) rebuilt a couple of years back, but have never got running just right. Takes a few kicks to get her started (especially when hot) and she will not tick over until at running temp (with or without choke)But when running she goes ok.Think she is a bit rich as the plugs are slightly black, more so on the left side. Now...I have got a guy who is going to take a look at her but can't do it until the start of June. This guy during conversation mentioned the valve guides which has got me thinking.... I never replaced the guides at the rebuild as I was told it would be more trouble than its worth and I reckoned they were ok anyway (not that I'm an expert!!!)
Now the thing is I'm wondering if I should have them replaced in the meantime anyway???
Bike has only done 21,000miles (but I believe they were not kind miles, poor servicing etc....)left side pipe smokes but not excessively. Tappet noise is quite excessive and there is a kind of 'clangy' rattle at between 2 to 3000 revs acelerating and throttling off, which I cannot ascertain from where, could just be something loose, but could it be the valves/guides???
any thoughts or advice would be greatly appreciated...
One thing I would like to know I guess is how long do the guides last generally anyhow????
Thanks.....
Jel
Re: T140 valve guides? [Re: Jel] #487735
04/28/13 9:34 am
04/28/13 9:34 am
Tampa, Florida
GTSRider Offline
GTSRider  Offline
Tampa, Florida
I also have 2 T140's...my main rider is a 81T14OES with
27,000 miles on her.
I recently did my top, and measured everything 3 times.
To my surprise guides were in factory spec, so I put in new
valve seals and left it. Bike runs strong with an occasional puff out the tail pipe.
If it were my bike I think I would enjoy the riding this season, and tear her down next winter.
Don't worry so much...just enjoy the ride !
Sounds like you need an enricher seal kit foe your cabs ...
common for the MK II 's
PM
Re: T140 valve guides? [Re: Jel] #487754
04/28/13 2:10 pm
04/28/13 2:10 pm
Sunny South Carolina, (US)
T140V-Rich Offline
T140V-Rich  Offline
Just thinking out loud here. The excessive tappet noise you're suspecting as worn valve guides? I would think should that be the case, she'd be smoking a bit.
Two simple things to check before getting into some serious fettling. The primary chain tension as well as the tappet clearances.
I had a particular rattle once. Checked all the mechanical movements, etc before realizing my drive chain was in need of a bit of attention. Tightened it up, noise gone. Point being, consider everything.
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: T140 valve guides? [Re: GTSRider] #487794
04/28/13 7:06 pm
04/28/13 7:06 pm
Jel Offline OP
Jel  Offline OP
thanks for the replies, yeah think I will take your advice and just ride her for now, just wish I could get her starting more reliably!!! got a guy looking at her in a few weeks so I will just see what he comes up with!!!!
Rich, good point about the chain, will check it out and I had the same thoughts about the guides if they were that bad I guess there would be a lot more evidence...smoke etc....
thanks again....
Re: T140 valve guides? [Re: Jel] #487797
04/28/13 7:15 pm
04/28/13 7:15 pm
John Healy Offline
John Healy  Offline
In a conversation with Brian Jones I once asked him what he thought of the valve guide specifications listed in the Workshop manual. He said, for years he never looked at one, but when he did he was aghast at what they had listed. He admitted that at those figures the guides were worn out.
Beside the ones already mentioned, a Triumph engine has many sources for noise. With no quieting ramps the valve train is always suspect. This is made worse because Triumph long ago stopped selectively fitting cam gears to remove back lash. It should be nil for cam gear to pinion and .001-.002in. for middle pinion to crankshaft pinion. While is was a normal part of production on non-unit engines, most unit T120 and T140s come no where near this standard.
Piston slap is always possible when T140 piston clearance exceeds .006in. This noise is present when the engine is cold and lessens, or goes away, as the engine reaches operating temperature.
Drive or timing side bearing failure can be the source of all sorts of noises.
WIth a little practice, using a stethoscope or long screw driver to your ear, one can go around the different areas of the crankcase and listen. Often this will give up the offending part or system that is making the noise.
For example piston slap is easily distinguished by holding the tip of the screw driver to the side of the cylinder between the fins. Failing bearings can be detected by listening the areas adjacent to the bearings, etc.. Takes a bit of practice to distinguish the uneven whirring sound of a failing bearing from the clacking sound of the cam gear teeth slapping back and forth as they are pushed one way, then the other by the valve springs.
Re: T140 valve guides? [Re: Jel] #487818
04/28/13 9:26 pm
04/28/13 9:26 pm
Another point from the first post: a cold engine should not tick over well.
Re: T140 valve guides? [Re: John Healy] #488273
05/01/13 7:01 pm
05/01/13 7:01 pm
Jel Offline OP
Jel  Offline OP
hmmmm!..lot to think about there John.Will have a 'listen' with a screwdriver as described, should'nt be a bearing prob, they were all re-newed at rebuild and only done 1000 miles since.Pretty much everything re-placed in fact (except valves/guides!!)Just a thought about the primary chain, manual gives freeplay spec, but how do you get it right by peering/feeling through the inspection hole??
thanks again for the replies....
Re: T140 valve guides? [Re: Jel] #488280
05/01/13 7:23 pm
05/01/13 7:23 pm
John Healy Offline
John Healy  Offline
There is a classic problem that we experience here in the North East (USA). It is a premature timing side ball bearing failure. It typically happens between 750 and 1,000 miles. It starts with the engine being stored in a place where there are constant changes in temperature that cause condensation. This could be in a heated garage where the garage door is opened a lot. The bike sitting adjacent to a South facing window. Or a classic, the bike sitting next to a furnace (central heater-UK). Anywhere that the temperature changes a lot and the air is damp. If you wear eye glasses you know the problem.
This bearing is typically quite dry of oil and condensation sits in the bottom of the bearing and eventually breaks through the oil layer leaving microscopic rust spots. These degrade rather rapidly, depending upon how badly the bearing rusted. So while it probably isn't your problem it warrants taking a good listen.
