YankeeJerry
YankeeJerry
Connecticut
38 registered members (Al Eckstadt), 262 guests, and 407 spiders.
10416 Registered Users
btour 84
Rohan 79
Triless 77
reverb 75
Stuart 70
707,857 mail-order LSR
Topics68,285
Posts664,779
Members10,416
wont stay at steady idle t140 #486733
04/21/13 2:41 pm
04/21/13 2:41 pm
united kingdom
brian begg Offline OP
united kingdom
set the idle on my t140 its okay then as soon as i rev it up the tickover rises up .the cable seem okay carbs cleaned out in ultra sonic tank .what is the correct revs for the tickover. maybe i am going to low. no rev counter on my bike but can get a lend of a digital one to set it. all standard jets, needle set in the second groove AMAL 900 carbs on it with bell mouths cheers for any help
Re: wont stay at steady idle t140 [Re: brian begg] #486734
04/21/13 3:02 pm
04/21/13 3:02 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
What ignition system?
Re: wont stay at steady idle t140 [Re: brian begg] #486737
04/21/13 3:08 pm
04/21/13 3:08 pm
united kingdom
united kingdom
new pazon set up no battery all new parts ,done the same with the Boyer that was fitted before
Re: wont stay at steady idle t140 [Re: brian begg] #486762
04/21/13 3:56 pm
04/21/13 3:56 pm
Sunny South Carolina, (US)
T140V-Rich Offline
T140V-Rich  Offline
Just a reminder, probably preaching to the choir, but the tickover was set whilst the engine was warm? Ridden 5-10 miles first?
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: wont stay at steady idle t140 [Re: brian begg] #486763
04/21/13 3:56 pm
04/21/13 3:56 pm
JubeePrince Offline
JubeePrince  Offline
Hi Brian,
You may want to start checking the manifold(s)for air leaks.....can we assume you set up and synced the cables correctly?
Re: wont stay at steady idle t140 [Re: JubeePrince] #486772
04/21/13 4:21 pm
04/21/13 4:21 pm
united kingdom
united kingdom
yes set it all up going by bushmans carb set up
Re: wont stay at steady idle t140 [Re: brian begg] #486795
04/21/13 9:04 pm
04/21/13 9:04 pm
JubeePrince Offline
JubeePrince  Offline
Hi Brian,
Not sure if Bushmans still advocates syncing with WOT, but here's a small blurb about syncing from John Healy:
In my youth I figured it was best to start throttle cable adjustment at full throttle just like Bushman recommends. My logic, driven by what have been a youthful bursts of testosterone, demanded it. Often we were fresh from the pages of Irving's "Tuning for Speed" and wanted all from our engines.
Then one day watching a competitor at the track adjust his cables it hit me: It was all about "percentage of error," and you wanted the error where it made the least difference.
If there is going to be any error in how the cables lift the slide you want it where it has the least effect. That is at wide open throttle. Bushman's system insures that if there is a problem it will be where it will have the greatest effect upon the percentage of error (POE), and thus effect upon how the carburetor operates: Low throttle openings.
Any error in slide movement, or height, will have the greatest effect upon carburetor performance at low throttle openings. So it is better to start from the bottom, and let any error be at or near full throttle where any slight difference in height will have the least effect upon the POE.
1. Unscrew the throttle stops so they allow the slide to hit the bottom of the carburetor body.
2. Using the two cable adjusters get both slides to lift off the bottom of the bottom of the body at exactly the same time when you open the throttle. When you let go of the throttle you should here a single click. Not click, click!!
3. Place a finger on the side of the slide through the venturi and turn the throttle stop until you JUST feel it lifting the slide. Then turn the throttle stop screw in 3/4's of a turn. Do the same to the other carburetor.
4. Double check that both cables have a bit of free play so that the throttle turns a bit before it starts to lift the slides (important!!).
5. Set the pilot air screw at 1 1/2 turns out.
6. Make final adjustments making small (1/8 turn) adjustments EQUALLY to each throttle stop. When you open the throttle and let the slides drop you should only hear a single click... again not click,click.
7. While the throttle stop adjustments should end up even, there can be slight variations in the final setting of the pilot air screws.
And when both sides of the motor are pulling equally at low to medium throttle openings it will seem to vibrate less!
Now you have adjusted out any variations at low throttle openings and moved any variations in cable routing or number of bends in each cable to larger throttle openings where any variant will be a much smaller POE. And at WFO the slides are out of the venturi and have no effect on all this.
Or you could use a 2 into 1 cable arrangement and have fewer problems!
Re: wont stay at steady idle t140 [Re: brian begg] #486797
04/21/13 9:29 pm
04/21/13 9:29 pm
Vic. Australia
Vic. Australia
Check the keyways in the slide bores,for any steps where the slide could catch.
Make sure the throttle springs aren't twisting the slide,and the carb tops go on without twisting the spring.
Re: wont stay at steady idle t140 [Re: Pete R - R.I.P.] #486899
04/22/13 4:10 pm
04/22/13 4:10 pm
united kingdom
united kingdom
cheers for all the ideas will try them most apreciated
Re: wont stay at steady idle t140 [Re: brian begg] #487065
04/23/13 3:07 pm
04/23/13 3:07 pm
united kingdom
united kingdom
what should the revs be at tick over still getting the same problem ,maybe i am going to low . also my rear discbrake does not feel rite should there be a lot of travel on the pedal or should you just have to dab the pedal cheers again for any help
Re: wont stay at steady idle t140 [Re: brian begg] #487075
04/23/13 3:43 pm
04/23/13 3:43 pm
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
These things don't need to idle like a Harley, 1000-1100 is where I usually shoot for when engine is fully warmed up.
Probably need to partially withdraw the axle bolt so the rear caliper hangs down with the bleed nipple in the highest possible position. Then bleed brake. Will need to remove left muffler to get axle out.
IMHO the t140 rear brake system is one of the most f'd up designs in motorcycle history. I'm struggling with mine right now. I'm going to have to do a large paint touch up from spilled brake fluid.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2004 XL 1200R Sportster
Re: wont stay at steady idle t140 [Re: brian begg] #487076
04/23/13 3:52 pm
04/23/13 3:52 pm
JubeePrince Offline
JubeePrince  Offline
http://classicbike.biz/Triumph/Maintenan...umph_Norton.pdf
Re: wont stay at steady idle t140 [Re: brian begg] #487252
04/24/13 4:27 pm
04/24/13 4:27 pm
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
I know on Nortons the typical problem with inconsisten idle is worn slides. Does the same occur on Triumphs?
I know last year I replaced ALL my old worn AMAL slides with the new hard anodized slides. It definatly improved my Norton and the action is smoother on my Trophy. Could not tell a difference on the tiger though.
Any air leak around a worn slide will give wonky idle. tell tale sign is to just barely take up the slack on the throttle and you can actually detect an idle dip before it will start to pick up.
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
