Todd Porter
Todd Porter
Georgetown, Kentucky
20 registered members (BeezaBryan), 163 guests, and 459 spiders.
LandoLando, MikeA, Jay Gilling, scratchedtank, Magic Monkey
10253 Registered Users
Stuart 72
Lannis 68
L.A.B. 47
607,187 mail-order LSR
Topics67,088
Posts651,016
Members10,253
All alloy - factory twin carb - Pre Unit 500 TR5?? #486670
04/21/13 2:01 am
04/21/13 2:01 am
Texas
larry9595 Offline OP
Texas
Hi there, this is my first post. I've been riding Triumphs since the 70's but only just found you guys and I'm hoping some one can help. I know my way around unit 650s but I'm new to pre unit bikes. I've had a 1955 500 in my garage for a year or two - but it's got some unusual features. Twin carb delta head, dural valve caps, alloy tappet blocks, Tach drive, and what looks like a breather on the timing case? A K2FC competition magneto, close fin alloy cylinders... anyone got any ideas what this may be - it doesn't look much like the TR5 in the 1956 catalog - it's more like a road race motor. Engine number is TR5 61313.
/20130419021_zps990686da.jpg.html][/URL]
Re: strange Pre Unit 500 [Re: larry9595] #486680
04/21/13 2:56 am
04/21/13 2:56 am
Tridentman Offline
Tridentman  Offline
Looks like the DPO had shares in Red Hermetite!
Re: strange Pre Unit 500 [Re: larry9595] #486692
04/21/13 4:12 am
04/21/13 4:12 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I don't find the aluminium tappet blocks unusual in an aluminium barrel.
Someone has wanted it to go fast,and fitted the delta head and tacho drive.Looks like they did some work on the rocker arms.
The valve springs are much later or aftermarket,and it looks like the aluminium collars are there to get the spring load right.It could have been better to use standard top collars and the thicker bottom collars.
Aluminium collars are OK,until the collets pull right through.
It looks like the bike might have had another less exciting life after that,from the look of the handlebars.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486699
04/21/13 6:25 am
04/21/13 6:25 am
HawaiianTiger Offline
Oh, you don't want that old thing. Pack it up and ship it to me. I'll gladly take it off your hands.
grin
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486700
04/21/13 6:48 am
04/21/13 6:48 am
Christchurch NZ
R Moulding Online content
R Moulding  Online Content
Christchurch NZ
Nope, forget Bill, i'll take it. Looks like it's in the way anyhow.
I know nowt about pre unit bikes, but head appears to be 59 Bonnie?
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486702
04/21/13 7:49 am
04/21/13 7:49 am
melbourne, australia
7
76degree-triumph Offline
"I know nowt about pre unit bikes, but head appears to be 59 Bonnie?"
Sure does Red, but this head has been machined to suit the T100 spigot. I dont know much about the fitting of the delta head to the 63mm bore T100, but perhaps the combustion chamber is cast in the 500 pattern rather than the 650?
That would mean another casting pattern, the intrim (spelling?) splayed 59 bonnie head and another with the 500 combustion chamber. Would they have gone to the effort to cast a seperate head as by '59 they ran a unit T100?
So many questions!
Cheers, Chris.
1950 Speed Twin outfit
1951 Thunderbird outfit (76 degree racebike, or is it 90 deg now?)
1955 BSA D3 minibike outfit
Triumph solo's
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: 76degree-triumph] #486704
04/21/13 8:23 am
04/21/13 8:23 am
Vic. Australia
Vic. Australia
The splayed-port delta head was first used on race-kitted 500 cc engines,long before the Bonneville.It was original equipment on the 1957 T100RS.I sold one of those heads a few years ago.It had never been used.The exhaust spigots were 1.5" diameter,not 1.65" like a 650.
I'm sure they just used the same patterns to cast the early Bonneville head,and machined it a little differently.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486708
04/21/13 9:36 am
04/21/13 9:36 am
7
Hi Pete, were the inlet tracts splayed like the above pics with the original parallel ports? So perhaps a modified T110 casting?
Triumph solo's
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486709
04/21/13 9:39 am
04/21/13 9:39 am
7
Larry, a head pic taken from the front would help with a year.
Cheers, Chris.
Triumph solo's
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: 76degree-triumph] #486711
04/21/13 10:15 am
04/21/13 10:15 am
Vic. Australia
Vic. Australia
Same as above.You could see that it was derived from a single-carb head,and it had the lumps to prove it.It was a slightly different casting to the T110,like an early Bonneville head.
They were still making those heads during the '60s,to suit 500cc pre-units.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486712
04/21/13 10:19 am
04/21/13 10:19 am
England
British Ironwork Offline
England
I've got one of those heads, casting number E3663 I think. If it has the relieved combustion chamber it is a Delta Head, the date stamp cast in the rocker well will probably be '57. The remnants of the original inlet tracts is correct, the standard pattern seems to have been modified when these were originally cast
The number denotes it as 1955, which is too early to be a TR5R which had this build spec, somebody has upgraded a Trophy to the slightly later "R" spec. Never the less a lovely thing to own and I am turning some shade of green looking at what you have got there.
If you are looking to pass it on, then it is morally correct to get it back to England where it's family is waiting, I will gladly do that for you.
Any chance of PMing me a photo of the engine number, or part of it. I want to check the font used on the actual stamp set used in '55.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486716
04/21/13 11:06 am
04/21/13 11:06 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
BI,
I dont want to divert this thread, but have a look at this thread of mine recently. Might have what you need and save larry a bit of effort.
http://www.britbike.com/forums/ubbthread...4514#Post484514
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486718
04/21/13 11:30 am
04/21/13 11:30 am
England
England
Ray,
Cheers, not sure I liked what I saw though, I have a bottom end coming from the States, currently in the black hole known as customs.
On one hand the numbers look massive, yet on the other the casting below looks untouched. Replacement cases mayhap?????
Brian
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486786
04/21/13 7:46 pm
04/21/13 7:46 pm
That looks like re-stamped numbers to me. I can manage that sand-cast look quite easily with a hammer and some 60 grit sandpaper. However, there are many re-stamped cases out there and many of them are quite legitimate. I should restate that as there are may stamped replacement cases out there that are legitimate. Sorry.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: British Ironwork] #486819
04/22/13 1:00 am
04/22/13 1:00 am
Texas
Texas
This is what my 1955 case looks like:
The frame number matches but is a different font.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: 76degree-triumph] #486824
04/22/13 1:29 am
04/22/13 1:29 am
Texas
Texas
Here's a photo from the front
Also - next to a 1962 PU Delta head on the right, 500 on left:
The casting number in the Exhaust rocker box is 3548. Curiously there is no trace of a year-sundial marking on the inlet side, just plain sandcasting.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486831
04/22/13 2:10 am
04/22/13 2:10 am
Texas
Texas
...and thanks for all the input guys - I looked up TR5/R and found this:
http://tonupclassics.blogspot.com.au/2010/03/1956-triumph-tr5r-road-racer.html
looks very similar, but 1956, and the inlet tracts are parallel.
The only other reference I've found is this:
http://books.google.com/books?id=Hg5Y8yt...ead&f=false
- but the ports on my head are way too rough to be a real racer.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486876
04/22/13 1:59 pm
04/22/13 1:59 pm
John Healy Offline
John Healy  Offline
For those who wonder if I ever actually built a motorcycle the link above (books.google.com... is one of my 500's at Daytona.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: larry9595] #486890
04/22/13 3:14 pm
04/22/13 3:14 pm
Los Angeles
tonupjonnie Offline
tonupjonnie  Offline
Los Angeles
The 500cc Delta Head was not offered 'till late 1956. Buyers of the "104" 1956 TR5R machines were given 1st option on purchasing one of the new Splayed Heads. It was fitted standard on the few TR5R machines built for the 1957 season.
Re: All alloy - factory twin carb - Pre Unit 500 TR5?? [Re: HawaiianTiger] #486898
04/22/13 4:08 pm
04/22/13 4:08 pm
England
England
C'est la vie! cry
Too keen by half yet again, but WTF they're big bearing dynamo cases and that's what I'm after.
