Mike Baker
Mike Baker
Asheville, NC
44 registered members (Adam M.), 232 guests, and 54 spiders.
10381 Registered Users
Mori55 98
NickL 91
Stuart 86
DavidP 78
Triless 71
reverb 70
Rohan 64
688,488 mail-order LSR
Topics68,011
Posts661,580
Members10,381
triumph 3ta swingarm #48569
08/08/06 8:19 am
08/08/06 8:19 am
england
steve.m Offline OP
steve.m  Offline OP
england
Hi, I am a newbie so please be gentle with me!!
I am trying to take the swingarm off my 1960 3ta, the manual says "use a soft drift " I have tried several drifts but i am having no luck , the bike has been stood for 15 years and there was alot of grease behind the end caps, i removed the grease nipple and looked into the hole and it looks nice and clean, but i just cannot budge it!!any ideas please, thanks, steve.
Re: triumph 3ta swingarm #48570
08/14/06 6:34 pm
08/14/06 6:34 pm
Jacco van D. Offline
Hi Steve,
Forget it with a drift and a hammer.
You really need a hydraulic press.
It is a very tight fit.
I also stumbled with a hammer on my 1966 3TA. A local engineering company with a press could help you.
You probably need new bushes and a spindle.
Bushes need to be slightly reamed after assembly.
Good luck, Jacco
Triumph T100T 1969
Triumph TR6R 1972
Triumph T25T 1971
BSA B25 Fleetstar 1968
Laverda 750SF 1971
TWN Boss 1954
Re: triumph 3ta swingarm #48571
10/03/06 4:54 pm
10/03/06 4:54 pm
Duncan Fairley Offline
There is a special Triumph tool for the job, which I improvised using a bit of good fine thread studding 3/8th (BSF I think). It's a bit hard to described, but basically, you have the studding about 300mm long. Put two nuts on one end, and screw then up tight together.
Push it through the hole in the spindle and swinging arm. Then, put a piece of 32mm pipe, approx 150mm long on the thread. Then a couple of thick penney washers, large enough not to dissappear up the pipe. You then have another nut on the end.
Put oil or grease between this last nut and the washers, and wind it all up. Keep winding and the stud should wind through the nut, pulling the other two nuts, with the spindle, into the piece of pipe.
If you need to replace the bushes, a similar method (or the triumph tool) may be used.
I haven't got the part number for the Triump made extractor, but the bush reamer (if you need it) is Z-126. The correct triumph tool for removing and rep[lacing the bushes on a T140, is 61-6117. This may do the trick, but I can't confirm.
In actual fact, I'm just about to do the exact same job on a T100SS frame and swinging arm. If you want, I'll work out exactly what you want and let you know. It may be a couple of weeks though.
Re: triumph 3ta swingarm #48572
10/03/06 4:56 pm
10/03/06 4:56 pm
It may also be worth contacting Len Craig for advice. He's very helpfull and been doing it for years. He may be able to provide the correct tools.
http://www.lencraigandsons.co.uk
Re: triumph 3ta swingarm #48573
10/03/06 5:06 pm
10/03/06 5:06 pm
I could send you a picture of what I meant with the tube and studding if you wish (I'm not sure how to get a picture up on here yet, sorry)
Re: triumph 3ta swingarm #48574
10/03/06 9:22 pm
10/03/06 9:22 pm
NSW Australia
BrianFromOz Offline
BrianFromOz  Offline
NSW Australia
bits......open a photobucket account,its free....then copy and paste the "IMG" link of the photo straight into your reply (make sure theres gaps between text and photo link).......in the uploading options(near the 'upload it' button)make the image message board size bigt
http://photobucket.com/register.php?link=topmenu
"What are you rebelling against?
What have you got?"
77 T140V
Is Your Bike Here?
MembersBikesBritBikeForum
http://s165.photobucket.com/albums/u51/MembersBikesBritBikeForum/
