rick m.
rick m.
Victoria, Canada
21 registered members (Bob Buchanan), 217 guests, and 367 spiders.
blayde54, Davenz13, Sean65, Rerock, pkuzyk
10477 Registered Users
NickL 84
franko 75
Triless 63
747,753 mail-order LSR
Topics68,834
Posts670,434
Members10,477
Case sealant? Yes/no- which one? #48403
07/29/06 5:54 am
07/29/06 5:54 am
Central NJ
Vetterdog Offline OP
Central NJ
I am reassembling my A65 motor and was wondering which, if any case sealant is best. I have seen Three Bond stuff on the web, but not locally. Anyone with advice/knowledge who'd like to weigh in on the subject, I'd sure appreciate it.
Thanks, Dave
vdog
66 6T
67 A65L
72 T100R
Re: Case sealant? Yes/no- which one? #48404
07/29/06 6:21 am
07/29/06 6:21 am
I bought the Threebond stuff from some Harley type outfit online after I found out it was same as Yamabond which is frequently recommended by our experts. It is really good stuff.
Re: Case sealant? Yes/no- which one? #48405
07/29/06 11:10 am
07/29/06 11:10 am
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Check the mating surfaces for burrs and make sure they are cleaned of oil and any schmootz. I've used Indian Head Gasket Shellac for case sealing for over 20 years without any problem. Put on a thin coat. You can get it at any auto parts store for about $1.50. Stay far away from silicone red, blue sealers on any surface anywhere near an internal engine component.
,_o
_ -\_<,
NOPGS #2
Re: Case sealant? Yes/no- which one? #48406
07/29/06 12:14 pm
07/29/06 12:14 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
John is right. IMHO, 99% of engine sealing is in the prep work. I scrub my mating surfaces with fine Scotchbrite or other kitchen scouring pad and lacquer thinner. It's got to be flat, clean, and absolutely free of oil. Use lots of thinner and compressed air.
Given a choice, a light grey sealer will be invisible after the job is finished. A red or blue sealer sticks out like a sore thumb for years.
:bigt:
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Case sealant? Yes/no- which one? #48407
07/29/06 4:02 pm
07/29/06 4:02 pm
Central NJ
Central NJ
Once again, I am in your debt, the project continues. Look for pics of completed bike in.......uh,soon? [Linked Image]
vdog
66 6T
67 A65L
72 T100R
Re: Case sealant? Yes/no- which one? #48408
07/29/06 4:04 pm
07/29/06 4:04 pm
Central NJ
Central NJ
BTW John, where in Jersey are you? I'm in Somerset County.
vdog
66 6T
67 A65L
72 T100R
Re: Case sealant? Yes/no- which one? #48409
07/29/06 6:04 pm
07/29/06 6:04 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
V-Dog -
I see you ordered the A65 "kit". laughing
RF Whatley
Cornelia, GA
Re: Case sealant? Yes/no- which one? #48410
07/29/06 9:21 pm
07/29/06 9:21 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Was there yesterday at the balloon fest. I'm in Sussex county. My shop was in Morris county for 20 years. Now in Montague.
,_o
_ -\_<,
NOPGS #2
Re: Case sealant? Yes/no- which one? #48411
07/30/06 9:17 am
07/30/06 9:17 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Threebond is great but John RGS is correct, poor or dirty sealing surfaces are a recipe for failure.
The case joint is the first one you put togeather and if that leaks you strip all the rest to go back there.
1969 TR6R
Re: Case sealant? Yes/no- which one? #48412
08/03/06 2:24 am
08/03/06 2:24 am
Colonial Heights, VA
mike2937 Offline
mike2937  Offline
i use a product call mopar gasket maker,part number 4318083 its an anarobic sealer,works great never had an issue,use it sparingly, it little goes a long way,any dodge chryler jeep dealer should have it.i tube lasts for years.
Re: Case sealant? Yes/no- which one? #48413
08/03/06 4:20 am
08/03/06 4:20 am
Fort Worth
richardvarcoe Offline
Fort Worth
The secret to a good seal is to make sure that both halves of a casing are "Totally" flat. I actually used an engineers table and some engineers blue (a sort of paste) to flatten the crankcases on a B40. When I first put them on the table they actually wobbled?!!!
This was down to burrs around the holes where the fasteners fit, and poor casting technique?
The burrs can be removed using a large drill bit, and the procedure to flatten the cases takes alot of work, but is well worth it!
If you get it right then all you need is a thin smear of "Hylomar".
This stuff is available on the web, and endorsed by Rolls Royce.
I have even seen a set of Goldstar crankcases that were so 'true' after re-work that they only required a smear of vaseline to seal!!
Food for thought?!!
Re: Case sealant? Yes/no- which one? #48414
08/03/06 12:43 pm
08/03/06 12:43 pm
John Healy Offline
John Healy  Offline
I agree, good stuff!!!
john
Re: Case sealant? Yes/no- which one? #48415
08/03/06 8:45 pm
08/03/06 8:45 pm
Ron - in California R.I.P. Offline
OK, may as well add another idea.... Try the clear silicone adhesive sealant (like aquarium sealant). It resists oil, and won't show as it is clear. Yes it will be a bit harder to get the cases apart next time, but not that bad....
Cheers..!!
Ron
