Kenacu
Kenacu
RED BANK NJ
203 registered members (1xfatboy), 2,165 guests, and 544 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
Chart to convert inches to degrees #482214
03/21/13 2:04 am
03/21/13 2:04 am
Upstate NY
Red Lapierre Online content OP
Red Lapierre  Online Content OP
Upstate NY
Is the a chart to convert inches to degrees to set timimg
What does 3/8" BTDC = in Degrees BTDC
11/32"
5/16"
and so on.
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482218
03/21/13 2:32 am
03/21/13 2:32 am
Mark Z Online content
Mark Z  Online Content
Red, do you mean inches of piston travel, or inches around the circumference of the alternator rotor?
In the first case, it would depend on the stroke of the engine in question. Here you would want stroke divided by 180, times the number of degrees.
In the second case, the formula would be the circumference of the rotor, divided by 360, times the number of degrees.
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482220
03/21/13 2:34 am
03/21/13 2:34 am
Oops, no alternator rotor on a pre-unit twin. Info pertaining to piston travel still applies...
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482224
03/21/13 2:53 am
03/21/13 2:53 am
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
I do not have a chart but you can work it out from geometry. The rod angle is related to the crank angle by:
R*sin() = C*sin()
R is the rod length, C is half the crank stroke.
So = asin(C/R*sin())
or = asin(R/C*sin())
The drop of the piston is the rod and 1/2 crank stroke minus each length times the cosine of their respective angles.
Piston drop = R + C - [R*cos() + C*cos()]
Substitute the equation for from the above equation:
Piston drop = R + C - [R*cos(asin(C/R*sin())) + C*cos()]
Solve for given the rod length, 1/2 crank stroke and piston drop from TDC. You can drop that equation into a spread sheet and plot piston drop versus then put a trend line through it if you do not want to do the inversion.
Re: Chart to convert inches to degrees [Re: DMadigan] #482229
03/21/13 3:44 am
03/21/13 3:44 am
Oahu Hawaii USA
Roger Gulledge Offline
Oahu Hawaii USA
R*sin() = C*sin()
Say what????????? grin
That's above my pay grade
Roger G
70 Thunderbolt
Re: Chart to convert inches to degrees [Re: Roger Gulledge] #482233
03/21/13 4:15 am
03/21/13 4:15 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
The complication is that you know the angle of the crankpin from TDC (or from cylinder axis),but you would need to calculate the rod angle.
I do it a little differently to simplify arithmetic ,but the result is the same.
If R = rod length,
and C = crank radius (which is 1/2 stroke),
and B = crank angle (from TDC)
and H = height of gudgeon pin from crank centre
H = C(cos.B) + sq. rt.( R squared - [C(sin.B)]squared )
Height of gudgeon pin at TDC = R+C.
Distance from TDC = R+C-H
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482249
03/21/13 9:43 am
03/21/13 9:43 am
Upstate NY
Upstate NY
Wow!
May be I should of asked what degree would I set timing at for a BSA A10 SR 3/8" BTDC is what I need. I will drop a pin in spark plug and measure it. Hope that will be close enough.
Red
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482270
03/21/13 1:23 pm
03/21/13 1:23 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
11/32"
5/16"
and so on.
Here's a calculator http://www.dansmc.com/mc_software2.htm
To convert crank rotation into piston travel, you need to know the stroke and conrod length.
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482275
03/21/13 2:09 pm
03/21/13 2:09 pm
Upstate NY
Upstate NY
Thanks that make life simple.
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482386
03/22/13 3:29 am
03/22/13 3:29 am
Red, I don't understand why you're starting with inches. I would think that the timing spec for your bike, in DEGREES, would be a well known and published bit of information.
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482387
03/22/13 4:03 am
03/22/13 4:03 am
ca, us
ca, us
This might explain it better but the equation is the same:
You want H, the distance the piston drops from TDC at the timing angle. The distance A is the same for the crank throw and the rod. From trigonometry,
R^2 = RT^2 + A^2
and
S^2 = ST^2 + A^2
A can be calculated from the timing angle by
A = S*sin(timing angle)
From this you can calculate RT and ST, the projected vertical length of the rod and stroke.
The distance the piston is down from TDC at the timing angle is
H = R + S - RT - ST
Re: Chart to convert inches to degrees [Re: DMadigan] #482425
03/22/13 1:08 pm
03/22/13 1:08 pm
Germany
Pete C Offline
Pete C  Offline
Germany
This means that there if some 4 difference in the timing between a BSA M20 and M21.
M20 stroke 94mm, M21 112mm both with 8.25 inch rods (209.5mm.)
Using the calculator on line and 7/16 BTDC at full advance for both engines I get approx 32.8 BTDC for the M20 and 36.8 BTDC for M21. Is there really this much difference? Does it matter?
Pete
Pete
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482430
03/22/13 1:49 pm
03/22/13 1:49 pm
florida
LeonGustus Offline
LeonGustus  Offline
florida
Similar question: On my 70 A50R there is a raised portion on the alternator spinny-thingy onto which is inscribed a timing mark. The timing line is to indicate full advance and it lives in the middle of that raised pad. Anybody know how many degrees wide that raised pad is? Knowing that would make it easy to interpolate minor plus or minus timing variations. No, I don't have a degree wheel or a degree in trig for that matter. Thanks, Leon
October of 69-A50R
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482433
03/22/13 2:09 pm
03/22/13 2:09 pm
florida
LeonGustus Offline
LeonGustus  Offline
florida
But Allan, I did the radius-polish job on the pistons as per some guy on this forum and it's HARD to make it pink. wink wink nudge nudge
October of 69-A50R
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482480
03/22/13 6:55 pm
03/22/13 6:55 pm
Upstate NY
Upstate NY
My Haynes Workshop manual goes by inches BTDC not degrees.
I google it but found nothing that help.
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482497
03/22/13 8:05 pm
03/22/13 8:05 pm
The factory manuals for most preunit bikes gave timing in inches.
Re: Chart to convert inches to degrees [Re: Alex] #482532
03/23/13 12:57 am
03/23/13 12:57 am
I had no idea. What, I guess because there's no place to put a degree wheel on it?
Re: Chart to convert inches to degrees [Re: Mark Z] #482539
03/23/13 1:23 am
03/23/13 1:23 am
Magnetoman Online content
Magnetoman  Online Content
Along with a lot of other things in my toolkit, I carry a 1/2"-wide machinist's ruler with the timing specs of ~20 models of all the major British bikes in tiny print taped to the back of it. The ruler has a 'T'-bar/pocket clip that slides up/down when locating TDC. Because it's a lot easier to add mm than 1/32nds, that's how I have all the timing specs tabulated. I can get the timing to within 1/2mm with this ruler, which is within a degree. I can (and have) field strip someone's faulty magneto on the side of the road, fix it, reinstall, and reset the timing with this "calibrated" ruler. This would be essentially impossible to do any other way.
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482548
03/23/13 2:40 am
03/23/13 2:40 am
Not to take up any more of this thread for my education on pre-unit bikes, but, if this is the prescribed method for timing them, I'm wondering now why Red wants to convert the spec to degrees.
Red,?
Re: Chart to convert inches to degrees [Re: Mark Z] #482553
03/23/13 3:40 am
03/23/13 3:40 am
Vic. Australia
Vic. Australia
Have you ever tried to measure how far a piston is from TDC,while the head is on?
It would be easy enough if the spark plug hole was vertical and the piston top was flat.
It would still be easy enough with a domed piston,if the vertical spark plug hole was in the centre of the head.
With an angled spark plug hole and a domed piston,it becomes awkward to get an exact measurement.
I don't doubt that Magnetoman can get it right within one degree.Many others would find that difficult.
Re: Chart to convert inches to degrees [Re: Pete R - R.I.P.] #482557
03/23/13 4:22 am
03/23/13 4:22 am
I should have mentioned that the quality control of these rulers isn't great, so it was easy for me to find a few at a used machinery store that were a tiny bit narrower than 1/2" (maybe 0.01" narrower?). These insert vertically in the spark plug holes of everything I tried them on the the garage and that I faced on the road, i.e. BSA A10 and Gold Star, Matchless G12 and G80CS, Triumph T110, and a Velocette (maybe others, but I don't remember).
The following photo shows the ruler (Snap On brand) in a Matchless G12 engine that's on its side (sorry about the quality, but I just made a quick hand-held snapshot and there wasn't sufficient light to get a good depth of field):
As can be seen the ruler is vertical, so even with a high compression domed piston there wouldn't have been an issue (the steepest parts of the tops of most pistons are cutouts for the valves, which aren't directly under the spark plug hole).
The engine is rotated back and forth near TDC and the sliding clip is used to "lock in" the arbitrary height when the piston is at the top. The ruler is removed and the required height BTDC (say, 9.5 mm) is added to that height and the clip moved to that position. The ruler is replaced and the engine then rotated backwards and the ruler slides down until the clip stops from moving it any further. Again the engine is rocked back and forth to determine where it is just touching the ruler. That's where the points need to open. I can determine this position to ~1/2mm, which is equivalent to ~1 degree. Or, I've convinced myself I can determine it to that accuracy. In any case, trying to get the points to open precisely there is a feat in itself. But, all the engines I've done this with have run fine afterwards. Maybe not at max. hp, because I try to err on the side of having the timing too retarded if anything. Certainly they ran a lot better than had I not had my calibrated ruler with me to get the guys' bikes back on the road.
Also, I'm not recommending this for doing a proper job of timing, but it's great for getting things pretty close in the garage, as well as for checking/repairing things on the road. Even if it isn't as serious as a failed magneto condenser that needs repair on the road, if a bike won't start, is it because the timing slipped, or because of one of other possible problems? If a quick check with the ruler confirms the timing is OK, it removes that from the list of possible problems. For this purpose it's essential to have the timing specs on the ruler (or somewhere readily found), because in the stress of the moment not many riders remember how many inches BTDC their timing should be set at on their bike.
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482581
03/23/13 1:00 pm
03/23/13 1:00 pm
Upstate NY
Upstate NY
I drilled and tapped the end of crank on the engine sproket side to put degree wheel on. I have made several measuring devices to do the timing but have not try the ruler Magnetoman is showing.
Timing sometimes takes awhile so I figure a degree wheel might make it easier with head on.
Red
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482645
03/23/13 8:22 pm
03/23/13 8:22 pm
Ok I get it, and probably what I would try as well if I had one of those. Well you have the formulae now, but I'm still having a hard time believing that with all the A10s in our cyberspace, no one knows the timing spec in degrees. Does your service manual show different specs (in inches) for different A10 models?
Re: Chart to convert inches to degrees [Re: Red Lapierre] #482720
03/24/13 1:43 pm
03/24/13 1:43 pm
Upstate NY
Upstate NY
Yes
A7 Std 5/16
A7 ST & SS 3/8
A10 GF 11/32
A10 SF RR SR 3/8
all Full adv. BTDC
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: Chart to convert inches to degrees [Re: Stefen] #483906
04/01/13 7:54 am
04/01/13 7:54 am
Vancouver Island Canada
Salty Dog Offline
Salty Dog  Offline
FWIW
The following info is taken from SRM's web site under the Technical banner
I don't vouch for it's accuracy but here it is:
Timing Figures
All figures take into account the use of UNLEADED PETROL
BSA A7/A10
A7. Alloy Head: 35 degrees (5/16th) (btdc)
A10, Iron Head: 33 degrees (9/32) (btdc)
A10, Alloy Head: 35 degrees (5/16th) (btdc)
BSA A56 & A65 - 750cc
A65, 32 degrees (btdc)
A65-750cc, 32 degrees (btdc)
Triumph T140, T120
T140, 36 degrees (btdc)
T120, 36 degrees (btdc)
Keep It Greasy
Page Time: 0.099s Queries: 16 (0.007s) Memory: 1.2114 MB (Peak: 1.5623 MB) Zlib disabled. Server Time: 2018-02-24 14:10:20 UTC
