T100Mark
T100Mark
Southern California
50 registered members (Adam M.), 221 guests, and 373 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,659 mail-order LSR
Topics68,846
Posts670,617
Members10,478
Question about Dunlop #463841
11/18/12 3:59 pm
11/18/12 3:59 pm
Gothenburg/Stockholm, Sweden
Simonofsweden Offline OP
Could anyone help me out as to which sizes of Dunlop K81 and K70 that will fit between the forklegs of a late 60:s Bonneville? And give room for a fender fitting as well.
Would hate to by online to find out that it is too wide http://www.dexon.se/landsvag/veteran-c-156-1.aspx But on the other hand I want as fat tyres as possible.
I have a Metzeler Block C for a front tyre at the moment which is strangely wide in places not needed. It actually carves on to the fork gaiters when "suspending".
I know this is a lovely topic of endless debate but any suggestions on good and goodlooking retrotyres for 19xVM2 and 18xVM3 would be much appreciated.
regards,
simon
I make misstakes on a daily basis!
Behold a selection of my different means of transportation (very poorly updated these days...) http://www.flickr.com/photos/bohuslan/sets/
Re: Question about Dunlop [Re: Simonofsweden] #463860
11/18/12 5:48 pm
11/18/12 5:48 pm
Jon W. Whitley Offline
For Dunlop K70's, the most common set-up for the north America market on big twin Triumphs was and still is:
Front- 3.25x19
Rear - 4.00x18
You could fit a 3.50x19 up front as well but I have gathered from the endless debates that 3.25 is best for handling concerning street riding. If you're just motoring about and not laying into the curves I don't see why 3.50 won't work for you since you did say you want the fattest tire possible up front.
As for K81:
Front - 4.10x19
Rear - 4.10x18
Re: Question about Dunlop [Re: Jon W. Whitley] #463863
11/18/12 6:00 pm
11/18/12 6:00 pm
Thanx!
I bit surprised about the recommendations for K81 though. Would have expected something along the lines of
Front - 3.50x19
Rear - 4.25x18 (or 4.10 as you indeed recommend)
How ever, thank you very much!
My new rear hub will be arriving shortly and a rim is on the way. So I will spend the winter making a new rear wheel. And perhaps replace front spokes with stainless while I am at it. To make them match the new rear wheel I mean.
/s
Re: Question about Dunlop [Re: Simonofsweden] #463872
11/18/12 7:10 pm
11/18/12 7:10 pm
Stuart Offline
Stuart  Offline
Originally Posted by Jon W. Whitley
As for K81:
Front - 4.10x19
Dubious, ime.
Rear - 4.10x18
Mmmm ...
A 4.10 will fit between '69 or '70 fork legs - i.e. after Meriden increased the centre-to-centre distance to 6-3/4" - but it's a faff to get the wheel in and out, you either have to deflate the tyre or remove the fender and brackets. frown
At the rear, 4.10 is both narrower overall and has a smaller overall diameter than 4.00.
Be careful what you wish for ... whistle While it's only one factor, in the late 1960's, when Triumph, BSA, Dunlop, Avon and probably other tyre companies still did a lot of testing, only the front tyre width on the triples was increased - from 3.25 to 4.10 - not the twins; the triples are approximately 70 lb. (35 kg.) heavier than the twins. When the twins were fitted with K81's, the front was 3.60x19 (90/90x19 closest equivalent) although the overall diameter is smaller than 3.25x19.
At the rear, the 4.25/85x18 is a tiny bit wider overall than 4.00x18 but, again, the overall diameter is smaller; it might not be a problem on a twin but, on a triple, you do notice the loss of cornering clearance. frown
Front - 3.50x19
No such tyre as a 3.50x19 K81 - 4.10x19 is pretty much the same overall diameter but wider overall.
4.25(/85)x18 is both wider overall and a larger overall diameter than 4.10x18.
Avon Roadriders - 3.25x19 and 4.00x18 are available.
Re: Question about Dunlop [Re: Stuart] #463879
11/18/12 8:07 pm
11/18/12 8:07 pm
Do doubt since he wants a fatter tire out back. I considered posting the 4.25/85x18 but took a look at the specs for a 1979 T140 and since it listed it as 4.10x18 decided to leave it at that, not being overly familiar with the K81 rear of any size.
After reading this, I realized that I just posted the sizes that the late T140's came with according to the book when fitted with K81's but gave it no thought to him fitting them to a late '60's twin.
I personally favor the K70's and usually go with the 4.00x18 rear and 3.25x19 front. Same with the Avon SM Mk.II series. Although I have been thinking of a 3.50x19 front for one of the bikes.
So, I think if he goes with that combo using K70's he'll be good to go.
Originally Posted by Stuart
Dubious, ime.
Rear - 4.10x18
Mmmm ...
Re: Question about Dunlop [Re: Stuart] #463883
11/18/12 8:21 pm
11/18/12 8:21 pm
Sorry, I ment 3.60x19 K81
Stuart, Do I understand you correctly that the K81 3.60x19 is equal to the 3.25x19 only with a smaller diameter?
Tricky numbers to get a grip of this I tell you! When higher number not automatically equals larger...
To bee honest I was mostly thinking of looks when I said that I wanted fat tyres. I think that might be a slightly different approach to setting up the bike then some of the people on the board. BUT on the other hand I do enjoy riding and I do ride rather aggressively so I might go for the roadworthy compromise after all...
I do like the look of the K81 the best I must say.
Thanks for all the great advice so far!
/simon
Re: Question about Dunlop [Re: Simonofsweden] #463911
11/18/12 11:36 pm
11/18/12 11:36 pm
Irish Swede Offline
Irish Swede  Offline
Why the Hell would you want to put a K-70 on the front, other than for a 1968-on restoration?
K-70 tires ("Tyres," for you Brits) were designed for the REAR of bikes. The wear pattern of "cupping" which the K-70 displays
after a thousand miles of operation should be a clue that something is wrong, and they ALL do it. They were designed
to be "pulled" on the rear end, not "pushed" on the front.
My '72 Daytona never handled better than when I replaced the K-70 with a Dunlop "rib" front tire.
Re: Question about Dunlop [Re: Irish Swede] #463988
11/19/12 12:26 pm
11/19/12 12:26 pm
Dunlop specifies them as suitable for rear AND front use http://www.dunlopmotorcycle.com/tire-catalog/road/vintage/k70/
I do however thank you for valuable info on poor handling whatever dunlop specifies.
regards,
simon
Re: Question about Dunlop [Re: Simonofsweden] #464004
11/19/12 2:30 pm
11/19/12 2:30 pm
derby england
wak Offline
wak  Offline
derby england
All my bsa and triumph wear k70 fronts 3.50 x 19,look great and handle.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: Question about Dunlop [Re: wak] #464005
11/19/12 2:47 pm
11/19/12 2:47 pm
Yep! That does look pretty good to me. What do you use for the rear?
/s
Re: Question about Dunlop [Re: Simonofsweden] #464007
11/19/12 2:50 pm
11/19/12 2:50 pm
derby england
wak Offline
wak  Offline
derby england
4.00 x 18 K70 Rear
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: Question about Dunlop [Re: Simonofsweden] #464009
11/19/12 2:56 pm
11/19/12 2:56 pm
derby england
wak Offline
wak  Offline
derby england
more K70 madness
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: Question about Dunlop [Re: Simonofsweden] #464019
11/19/12 3:58 pm
11/19/12 3:58 pm
triton thrasher Offline
I don't put K70 tyres on the back wheel, because they wear so fast.
Re: Question about Dunlop [Re: Simonofsweden] #464112
11/20/12 2:24 am
11/20/12 2:24 am
Stuart Offline
Stuart  Offline
You've reminded me that the Co-op did eventually go 4.25/85x18 on the back, and a couple of times I've posted the apocryphal story about the Service Department quietly changing them to 4.10 on any bike whose owner complained of 'funny handling' ... whistle However, with the 4.00x18, twins did have a wider rear than 4.10 for many years without problems, so possibly one factor was that the corresponding front was the narrower 3.25 while the Co-op paired the 4.25 with the wider 4.10 front ...?
The K70 web page URL has been published already but I use this one - Dunlop "Vintage" tyres - to access both K70 and K81 specs.
Yes. You can get an idea for yourself from the aforementioned Avon Roadriders web page - 3.25x19 has a very similar overall width to a 90/90x19 (very close equivalent to a 3.60x19) but the overall diameter of the 3.25x19 is much closer to the 100/90x19 (modern equivalent to a 4.10x19 but a slightly larger o.d.).
It's hard to be sure given tyres will or won't work for a given rider - different rider weights, different riding positions, different rider perceptions, different maintenance standards, even on things only slightly connected to the tyres ...
But, just because you can get "a Dunlop "rib" front tire" in the US, how do know Simon can get one in Sweden? Even if he could, afaict Dunlop don't appear to list any ""rib" front tire" officially, so what guarantee have you got that some part of Dunlop actually made the tyre, with some decent qa?
This is precisely why I can't see the point of searching out 30-, 40- 50-year-old tyre designs. Triumph (in this case) fitted their bikes with some of the best tyres available when the bikes were built. At least one tyre maker has invested millions bringing modern tyre design to our old clunkers. So I simply don't understand the logic of using tyres to a 40- or 50-year-old design probably knocked up in a shonky low-wage Far Eastern economy and possibly moulded in shonky old moulds. When the tyres are our sole connection to a world otherwise filled with multi-pot disc brakes, ABS, power-steering and more attention-grabbing gadgets than a space shuttle. confused
Is there anything for classic bikes (aka "old clunkers") that doesn't "wear so fast"? frown
Re: Question about Dunlop [Re: Simonofsweden] #464129
11/20/12 4:33 am
11/20/12 4:33 am
Irish Swede Offline
Irish Swede  Offline
Stuart, my Dunlop rib tire is a genuine, UK-made Dunlop that I bought some years ago when the second K-70 wore out.
The rib pattern was standard on Triumph road models up to and
including 1967. I had a '67 Bonnie and enjoyed how it handled.
I noticed a difference for the worse when I bought my '72 Daytona
with its K-70 front tire as soon as I rode it home.
You pays your money and you takes your choice. My choice is the
Dunlop (or any) rib tire for the front of my Triumph road model
twins.
Re: Question about Dunlop [Re: Stuart] #464157
11/20/12 9:34 am
11/20/12 9:34 am
Yes. TT100, Roadrunner, Roadrider and SM MkII tyres all lasted longer than K70.
Re: Question about Dunlop [Re: Stuart] #464193
11/20/12 3:39 pm
11/20/12 3:39 pm
This is great! I thank you all for lots of great input. Tomorrow my new rear hub arrives in the mail, later this week I'll get the new rim and as soon as I get a hold of some spokes I will start lacing up a new rear wheel. Probably replace the spokes on front wheel as well. Nothing wrong with them but they will look like crap compared to the new ones in the rear.
I might come back to this thread and post some pictures whenever it is all done.
/simon
p.s.
As a rule of thumb we can get just about everything here that you can get in the states. With a few exceptions like turkey-ice cream (which a friend of mine actually ate once in New York city).
Re: Question about Dunlop [Re: triton thrasher] #464337
11/21/12 3:08 pm
11/21/12 3:08 pm
TripleTown Offline
TripleTown  Offline
Agreed. I've always preferred a ribbed front on my Triumphs.
Re: Question about Dunlop [Re: Simonofsweden] #464385
11/22/12 1:31 am
11/22/12 1:31 am
Simon,
Just finished installing these Dunlop K70's on my 1971 Triumph TR6R. 4.00x18 rear and 3.25x19 front.
Took it for a ride today and it handles well. Mind you, I don't have my knee on the pavement in the twisties wink
Re: Question about Dunlop [Re: Simonofsweden] #464403
11/22/12 6:22 am
11/22/12 6:22 am
Simon,
My '71 A65 had a 4.25/85x18 K81 on the rear when I bought it, pretty much as fat a tire as will fit.
I just replaced that with a 100/90x18 Road Rider.
It depends on your riding style. The fat tire is a bit more stable on the highway, but I prefer the handling of the 100/90.
I've never tried a 3.50 K70 on the front of any bike. But, I did have a 4.10 K81 on the front of a '71 Bonnie. It worked until I mounted the fender. Unless the wheel is absolutely true, there was not enough clearance to make me feel safe.
Re: Question about Dunlop [Re: DavidP] #482247
03/21/13 8:09 am
03/21/13 8:09 am
Started this thread some time ago and here's how the new rear wheel turned out
IMG_3315 by Bohuslän i mitt hjärta, on Flickr
Fixing to take on lacing the front wheel next. Thanx for all the advice!
/s
Re: Question about Dunlop [Re: Simonofsweden] #482281
03/21/13 3:00 pm
03/21/13 3:00 pm
It looks very nice...K70's coupled with the beauty of a Triumph spoked wheel is a recipe for perfection.
