Lenos
Lenos
San Pedro CA
23 registered members (Alan_nc), 162 guests, and 411 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,042 mail-order LSR
Topics68,853
Posts670,686
Members10,478
Lucas 18D2 distributor #47595
06/03/06 10:16 am
06/03/06 10:16 am
Halifax, Butt end of Europe
andrewinpopayan Offline OP
Has anyone ever pulled one of these down to the bones? The one on my 1959 350cc 3TA hack has a bit of side to side slop and I wondered what sort of bearings were inside, my guess is its a couple of p/bronze sleeves but I would like to find out for sure, so if anyone has had one apart or knows of drawings please let me know
Andrew
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47596
06/05/06 9:05 pm
06/05/06 9:05 pm
Jon W. Whitley Offline
andrewinpopayan
The bushing on the drive end of the shaft appears to be of the bronze type.
Re: Lucas 18D2 distributor #47597
06/06/06 4:57 pm
06/06/06 4:57 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Jon is correct. The bushing is a plain one, and after installation should be reamed to the shaft size plus .001". Assemble with motor oil. While you have it chucked up in your lathe, you can also cut a groove for an oil seal under the AAU.
:bigt:
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Lucas 18D2 distributor #47598
06/06/06 5:40 pm
06/06/06 5:40 pm
Is the original bush pegged or is it just a press fit?
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47599
06/06/06 5:59 pm
06/06/06 5:59 pm
florida
cycarmark Offline
cycarmark  Offline
florida
The one in the 18D2 dizzy on my '59 3TA was a press fit.
Re: Lucas 18D2 distributor #47600
06/06/06 6:13 pm
06/06/06 6:13 pm
Thanks cycarmark, so it a long-ish p/bronze sleeve, press fitted into the body. I assume that the roll pin comes out of the drive gear, the drive gear can then be pulled off the shaft and the shaft withdrawn out of the body. Is there a retaining circlip at the bottom end of the bearing? I havent pulled mine to pieces yet its still on the bike (which runs well enough) its a "to-do" in the future.
I have a new oil pump coming in the post because I don't know hold old/worn the original is, maybe its been running around on the same one for almost 50 years?
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47601
06/06/06 7:16 pm
06/06/06 7:16 pm
AHA! located one, described as "oilite" bush, 18D2 also fitted to dozens of different machines, price 2.95 ($5)
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47602
06/07/06 12:52 am
06/07/06 12:52 am
E
EWebster Offline
EWebster  Offline
E
Okay, I will ask. What is with the "sworn enemy" of Joseph Lucas thing?
Re: Lucas 18D2 distributor #47603
06/07/06 4:51 pm
06/07/06 4:51 pm
For the last 30+ years I have done battle with his devilish devices. Betweem themselves Mr Lucas, Darth Vader and "Brain" want to plunge the universe into eternal darkness.
My first battle was with one of his dynamo control boxes on my Panther, this was years before electronic controllers, anyway a bit of prodding around with my multimeter found the 0.3 ohm field resistor was open circuit (the black button looking thingy) rivetted to the main body, replaced it with a 10 watt wirewound---no further problems.
Second battle was an RM15 alternator on a C15, vibration had caused some coils to go short to the alternator chassis, so out came the silk covered enameled copper wire, 2 hours later a rewound better-than-new alternator, chucked his ?selenium? rectifier, fitted a butch silicon bridge rectifier and for good measure fitted a home-made voltage regulator and went 12 volt. I also fitted a sealed beam headlight unit of a "Mini", the 12 volt coil and a "Sparkrite" electronic ignition unit that still used the point, the coil was more like a Tesla coil smile .
Over the years I have worked on numerous brit bikes, almost always on the electrics.
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47604
06/07/06 4:55 pm
06/07/06 4:55 pm
Part number for the bush is 70-4190, I also ordered a new inlet camshaft nut because it has the peg that drives the oil pump part number 70-1463, barring other problems they should see it good for the next 50 years
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47605
06/07/06 5:01 pm
06/07/06 5:01 pm
florida
cycarmark Offline
cycarmark  Offline
florida
Actually I kinda like Lucas stuff. My first bike was a 165 Harley with a "crankshaft mounted, six pole, shunt wound generator" that made the Lucas stuff look easy! (that is until I got my 3TA with the combined lighting and ignition switch).
Re: Lucas 18D2 distributor #47606
06/07/06 5:46 pm
06/07/06 5:46 pm
My "Tronda" 3TA trophy trials was 12 volt when I got it, its using a 6 volt alternator wired as a 12 volt to a Boyer "powerbox" and I just fitted a 15000uF to even out the sparks at low revs with the lights on. Its still got the standard 18D2 with rotor arm, cap, copper cables and non supressed plugcaps. It all works well, IF I did ever get a distrib cap problem, I would probably fit a twin spark "foriegn" coil. I have cured all major oil leaks by fitting home-made gaskets, I bought some sheets of "alite" in different thickneses, made some copper washers and done various fine tune "tweaks". Is an around town hack, if I get chance I will post a foto. Next job is the seat, I am looking for some leopard/tiger skin colored "Rexine" and gonna carve a block of sponge with the wirecutter I use to make model aircraft wing cores.
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47607
06/07/06 5:54 pm
06/07/06 5:54 pm
florida
cycarmark Offline
cycarmark  Offline
florida
Mine is stock, except last year I fitted the Newtronic ignition system. It replaces the points with an optical sensor (keeps the old advance unit) and uses a dual output coil. It works great, and if I ever want to go back to points, I can. The original Lucas points lasted around 25,000 miles, but the reproduction points did not seem to last as long. I also fitted the MAP oil filter.
Re: Lucas 18D2 distributor #47608
06/07/06 6:14 pm
06/07/06 6:14 pm
[img] file:///home/andrewinpopayan/Desktop/imag0012.jpg [/img]
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47609
06/07/06 6:16 pm
06/07/06 6:16 pm
mad damn computer is in league with Lucas
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47610
06/07/06 6:23 pm
06/07/06 6:23 pm
shel Offline
shel  Offline
Andrew, you can't post photos from your computer, you have to upload to a photo host first like www.photobucket.com and then post them here using the [img] tags just as you've done or click the image icon below the reply box
Re: Lucas 18D2 distributor #47611
06/07/06 9:10 pm
06/07/06 9:10 pm
hmm, I'll leave that until later. Does your 3TA run hot, like can you fry eggs on it or have I forgotten how hot aircooled get?
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47612
06/07/06 9:15 pm
06/07/06 9:15 pm
I cleaned out the pressure release valve and fitted the new pump, the old one doesnt appear worn, no crud under the ball seats etc, wish it had a pressure guage tapping for a switch or guage so I can be sure the bearings are getting lubed. good squirt of oil coming back into the tank on fast tickover
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47613
06/07/06 9:25 pm
06/07/06 9:25 pm
That might do it
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47614
06/07/06 9:27 pm
06/07/06 9:27 pm
1959 3TA
BMW R1150 Oilhead
Re: Lucas 18D2 distributor #47615
06/11/06 4:42 pm
06/11/06 4:42 pm
Anyone that needs a bearing, the size to buy is 16mm O/D 12mm I/D and 25mm long, a reference to a supplier would be QM21-25 for an oilite bush, but you will need access to a small lathe to "adjust" to fit. Mine ended up as 15.88mm O/D 12.42mm I/D and 24mm long made from a "Glacier Oilite" blank and soaked in EP80 @100C for 3 hours. I got the body hot in the oven to "oilsmoke" teperature and fitted the bearing straight from the freezer @ -25C a reasonble tight press fit with a valve spring compressor and the shaft lapped to fit with "Brasso" polish, my lathe is too small to carry the distributor body
1959 3TA
BMW R1150 Oilhead
