Buckshot1
Buckshot1
Diamond Springs, Kalifornia
38 registered members (Al Eckstadt), 328 guests, and 362 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
Good?........Or Grenade? #474738
01/29/13 11:10 pm
01/29/13 11:10 pm
Nor. California
Deadstiffcatt Offline OP
Nor. California
Digging through the parts to put together a mild late 650 Triumph engine-1969. Will be used for daily rider, rare hot rodding, Will probably drop compression down to about 8.5 : 1.
I have this option for my crank, I like it because it's the heavier one, I don't like what the photos show, one side has got some serious pitting- it looks like metal fatigue. This is the only spot on the crank that has this pitting, the rest looks nice. Is this one gonna grenade on me with heat, use and time? (pretty sure I know the answer, confirmation would be greatly appreciated.) Thanks! Joe
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474744
01/29/13 11:59 pm
01/29/13 11:59 pm
Farmington,Connecticut,USA
JBMorris Offline
JBMorris  Offline
stress fracture?
1978 Bonneville T140V PX
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474746
01/30/13 12:03 am
01/30/13 12:03 am
John Healy Offline
John Healy  Offline
Casting flaw... You wouldn't want to magna-flux Triumph cranks, especially T140 ones, they are full of internal voids/cracks like these.
Re: Good?........Or Grenade? [Re: John Healy] #474756
01/30/13 12:46 am
01/30/13 12:46 am
DMiller Offline
DMiller  Offline
I'm about to show my lack of metallurgy knowledge, but I thought Truimph cranks were forged, not cast.
Re: Good?........Or Grenade? [Re: DMiller] #474764
01/30/13 1:29 am
01/30/13 1:29 am
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
That's from the making of the crank in my opinion. Use in a road bike for 'normal duty' and with the regular rev limit (or less).
All too often owners 'forgot' that these motors had a recommended max rpm. Is was common to see them revved till the rate of acceleration slowed, then change gear!
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474767
01/30/13 2:16 am
01/30/13 2:16 am
washington state
7
79T140E Offline
79T140E  Offline
washington state
Joe, if I was a gambling man, I would bet they were not the answers you were expecting. It appears to be passing the test of public opinion. What was your initial thought.
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474773
01/30/13 2:55 am
01/30/13 2:55 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
It's been like that since it was forged,and it was like that when it was new.
It's in a low-stress area.Any force on the counter-weight is almost purely centrifugal,and not much force is transmitted through these minor flaws.
If it was like that between the crankpin and mainshaft,or between the 2 crankpins,it might deserve some attention with grinding and polishing.
Re: Good?........Or Grenade? [Re: 79T140E] #474781
01/30/13 4:31 am
01/30/13 4:31 am
Nor. California
Nor. California
T140E, It is pretty apparent that this flaw was there from casting, I am a bit surprised anyone would say to use it. My initial thought was specifically a fear of metal crystalization: this is 50 years old, has been through heat and usage, and I have seen first hand...er, umm..wrecked... first hand the effects of crystalization as in losing the rear wheel when the axle snapped in a van (twice, by the way, two different vans!...) Although it is highly unlikely that a chunk will come flying off at speed, as this portion would be under centrifical force and not a so to speak load bearing force, when I looked at the cases it would go into later this afternoon, the nicely bored cylinders and pistons to go with it, all the time I will put into assembly, then held this crank in my hand and looked at it from multiple angles, it's pretty apparent to me now that for my own peace of mind, a different crank is in order. All it would take is for a tiny section to flake or break off; and I could kiss my effort and engine goodbye. I can always keep it handy for the day that I do blow up an engine playing road warrior, (and since that will be in a post apocalypstic world, we'll all be using cranks like this when we can find 'em!)
So for now, a different crank is in order.
Thanks to all for the input! Joe
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474795
01/30/13 6:53 am
01/30/13 6:53 am
Vic. Australia
Vic. Australia
If you ground that back and welded it to replace the metal ground off,you'd be replacing about 1/4 ounce of steel.
The centrifugal force trying to pull that 1/4 ounce of steel off the counterweight would be around 15 lbs at 4000 rpm,60 lbs at 8000 rpm.
The tensile strength of the weld would be around 15 tons;more than strong enough.
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474951
01/31/13 1:35 am
01/31/13 1:35 am
washington state
7
79T140E Offline
79T140E  Offline
washington state
What would happen if you just ground it off and left it.
Re: Good?........Or Grenade? [Re: Deadstiffcatt] #474962
01/31/13 2:54 am
01/31/13 2:54 am
Melbourne australia.
spook Offline
spook  Offline
I would presume that it would change the balance factor slightly. btw Pete, could clear your mail box please?
