MikesClassics
MikesClassics
Queensland, Australia
15 registered members (BrettF), 147 guests, and 57 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,908 mail-order LSR
Topics68,056
Posts662,200
Members10,389
B40 coil #4725
09/13/05 3:16 pm
09/13/05 3:16 pm
1
1965b40 Offline OP
1965b40  Offline OP
I have a 1965 B40 Enduro, someone in the past has put a Mighty Max on it an one of those big blue capicaters on it, My question is what else do I need except a coil? and what coil do I need, an AC coil off a ET, OR a 6 v or a 12 v regular coil?
Thank you in advance, Dave
Re: B40 coil #4726
09/13/05 4:09 pm
09/13/05 4:09 pm
Depends on what you're using to run the ignition. I assume that since the mity max is on there, the points are running of the alternator. A non-ET stator would certainly help in starting since the ET alto output is pretty meager. You will need a 12 Volt coil and a set of non-ET points.
Good luck, man. bigt
