MikesClassics
MikesClassics
Queensland, Australia
209 registered members (68 royalstar tony), 1,774 guests, and 586 spiders.
10032 Registered Users
Lannis 144
kommando 102
476,308 mail-order LSR
Topics65,711
Posts635,140
Members10,032
Page 3 of 3 1 2 3
Re: Triumph (Val Page) Girder Help [Re: mozez] #443233
07/05/12 2:32 am
07/05/12 2:32 am
San Rafael, Ca.
BikeVice Online content
BikeVice  Online Content
San Rafael, Ca.
Your spring has an unnatural amount of bow, are you sure your lower steering crown is oriented properly? Could it be 180 off? In this picture, you've assembled your forks with the lower link pivot to the rear of the steering head:
But you've installed them with the pivot to the front of the steering head:
Eric
1971 T120RV (R.I.P.)
1973 T140V/TR7
1993 Ducati 900 SS
Re: Triumph (Val Page) Girder Help [Re: BikeVice] #443237
07/05/12 2:52 am
07/05/12 2:52 am
Ottawa, Canada
gREgg-K Online content
gREgg-K  Online Content
Ottawa, Canada
Eric has made an excellent observation. Some Enfield girders were made the same way as these, so that the steering stem could be reversed through the headstock, making for less trail for side car work.
With the steering stem installed so that the lower links are behind the steering axis, you end up with a geometry more suitable for solo work.
The Enfield spring perch bolts onto the lower cross bridge of the girder, so that it can be moved "backward" to remove misalignment/distortion of the spring.
.. Gregg
magneto@spyder-it.com
Re: Triumph (Val Page) Girder Help [Re: mozez] #443241
07/05/12 3:49 am
07/05/12 3:49 am
New Zealand
Trevor Stapp Offline
New Zealand
Yes spring is under a lot of unatural pre tension.
I would be encouraged to strip them down and start again.
Reverse your links.
Make sure you have a nice 'interferance' tightness between your spindles and bushes.
Do everything up to just off tight.
You should be able to move the knurled washers with your fingers.
Should have mentioned my forks are fitted to a Triumph 49/50 5T/6T frame.
I have 19" front & rear. Rear is rigid hub.
Well set up and maintained girders are a pleasure to ride and makes me wonder sometimes why the motorcycling world went to hydraulic front forks.
Trev
66T100SR Cafe racer
59 T20 Cub
1938 - 53 5T Bitsa project, now a roller
Duplex frame under the bench
Re: Triumph (Val Page) Girder Help [Re: Trevor Stapp] #443246
07/05/12 4:35 am
07/05/12 4:35 am
San Rafael, Ca.
San Rafael, Ca.
Originally Posted By: Trevor Stapp
Reverse your links.
The links seem to be installed correctly, here's another picture of what appear to be the same forks on an early 1930's Triumph:
It looks like the upper links are shorter than the lower links and they definitely incorporate the friction dampers.
WWII ended and the companies making aircraft landing gear had to find another market for their technology?
Eric
1973 T140V/TR7
1993 Ducati 900 SS
Re: Triumph (Val Page) Girder Help [Re: mozez] #443390
07/06/12 1:13 am
07/06/12 1:13 am
Vancouver B.C
mozez Offline OP
mozez  Offline OP
Vancouver B.C
@ Trevor Stapp - Thanks for the input. As mentioned - the links with dampeners on this particular girder were fitted to the top yolk. Unique to this model.
Every Triumph 6/1 photo that I have dug up has the same girder setup. Ill do some hunting for the extract from Road Bike that you mentioned. - Thanks.
Any chance you could measure the length of your girder? From top / forward spindle to axle centre. Id like to see what difference there is in fork length...
Re: Triumph (Val Page) Girder Help [Re: mozez] #443392
07/06/12 1:26 am
07/06/12 1:26 am
Vancouver B.C
mozez Offline OP
mozez  Offline OP
Vancouver B.C
Gregg and Eric- THIS IS EXACTLY THE PROBLEM!!!!!
Makes me what to slap my forehead! I cannot believe that for as much as Ive stared at this girder. Ive made such an obvious oversight!
I reviewed an illustration from an extract of the Triumph 6/1 service manual and it indicates where the grease nipples should be.
CLEARLY I have the lower yolk reversed!!!
[/url]
[/url]
This arrangement would obviously set the lower links further back and therefore correct the steering geometry and also the the angle of the load on the spring!
I cant thank you guys enough. Ill switch the lower yolk around and take the old girl around the block this weekend. Im sure its going to be a whole different kind of ride!
Again - Thanks! - Report back soon!
Re: Triumph (Val Page) Girder Help [Re: mozez] #443393
07/06/12 1:27 am
07/06/12 1:27 am
Vancouver B.C
mozez Offline OP
mozez  Offline OP
Vancouver B.C
Re: Triumph (Val Page) Girder Help [Re: mozez] #443396
07/06/12 1:57 am
07/06/12 1:57 am
New Zealand
New Zealand
Mozez,
No probs on input, sorry about the bum steer.
Center op front spindle to axel center 680mm (2'-3/4")
Also a very quick measure shows I have about 30mm of positive trail.
Try dropping Rod Stockdale a note at Tiger 100 in the UK.
He is a bit of a pre war Triumph expert. Has a good website and may be able to help you.
http://www.tiger100.co.uk/framesforks.html
Back at work next week so if you like I will scan and email you the 6 pages.
just PM me your email.
Trev
66T100SR Cafe racer
59 T20 Cub
Re: Triumph (Val Page) Girder Help [Re: Trevor Stapp] #443403
07/06/12 3:47 am
07/06/12 3:47 am
Ottawa, Canada
Ottawa, Canada
Mozez,
... sorry about the bum steer.
Yep, that's exactly the problem Mozez had.
Glad you have it nailed now!
... Gregg
Re: Triumph (Val Page) Girder Help [Re: mozez] #443886
07/09/12 7:41 pm
07/09/12 7:41 pm
Vancouver B.C
mozez Offline OP
mozez  Offline OP
Vancouver B.C
Happy to report that the girder handles 1000 times better than it did.
Its still a different kind of ride to any front end ive ever experienced but Im confident in its handling now. Swapping around the lower yolk has straightened up the spring and changed the rake / trail drastically!
Ill post up some photos indicating how the change affected trail this week.
I might still swap out the sprung hub to see how that affects overall handling, but for now, Im happy to just go for a ride!
Turns out the problem is NOT bad engineering from the 30's - its bad Mechanics in the 2000's... Thanks again for all the input and ideas.
Back soon with photos.
Re: Triumph (Val Page) Girder Help [Re: mozez] #445920
07/24/12 6:26 am
07/24/12 6:26 am
Nor. California
Deadstiffcatt Offline
Nor. California
I've been following this thread with interest, although I have no experience with running or repairing a girder front end. I do have the following two pages that my cat somehow photographed from a circa 1951 or so manual, downloaded into the computer, then loaded at photobucket without any of my knowledge.....
Parts diagram for prewar Triumph, second photo is part numbers to correspond. I hope this is of use for the Triumph girder guys!
Re: Triumph (Val Page) Girder Help [Re: mozez] #446414
07/27/12 7:54 pm
07/27/12 7:54 pm
Vancouver B.C
mozez Offline OP
mozez  Offline OP
Vancouver B.C
Deadstiffcatt - please thank your cat from me. Thanks for the pics!
Re: Triumph (Val Page) Girder Help [Re: mozez] #464497
11/22/12 9:17 pm
11/22/12 9:17 pm
Southern Oregon
kodiakbill Offline
kodiakbill  Offline
Southern Oregon
WOW, sure glad I read this post. I ran out to the shop to look at my 1934 Model 2/1 and sure enough, I have the crown reversed!
I should have this project finished and on the road by Spring and am glad to have avoided above noted handling issues.
Thanks for everyone's input.
I'm using a standard 18" Triumph rear wheel and a B50T 20 incher on the front.
Kodiak Bill
Re: Triumph (Val Page) Girder Help [Re: kodiakbill] #464702
11/24/12 4:27 am
11/24/12 4:27 am
Southern Oregon
kodiakbill Offline
kodiakbill  Offline
Southern Oregon
Well, I spent all day in the shop taking girder apart and turning stem around 180 degrees. BTW, my girder looks very similar to the one on Mozez's bike. I'm wondering what else I've gotten bass-ackwards.
Wayne's Triumph Motorcycles has many detailed photos of a restored 1935 Model 2/1. Forks are similar but differ in details of links and spindles.
http://triumphmotorcycles.typepad.com/photos/1935_triumph_model_21/index.html
Page 3 of 3 1 2 3
