ShearedCrank
ShearedCrank
New York
34 registered members (998John), 177 guests, and 64 spiders.
10381 Registered Users
Mori55 94
NickL 93
Stuart 86
DavidP 77
Triless 69
reverb 69
Rohan 65
688,662 mail-order LSR
Topics68,014
Posts661,628
Members10,381
Annealing head gaskets #342942
11/12/10 8:47 pm
11/12/10 8:47 pm
Folsom, CA
Y
yellow_cad Offline OP
Y
Folsom, CA
I have plenty of experience heat treating tool steel but virtually none when it comes to nonferous. If it is steel and it is to be annealed, it should be heated to its critical temperature and allowed to slow cool all the way down because if it is quenched it will not be dead soft. On head gaskets (and I'm using a thicker one to make up for missing head material) I have seen that lots of people say to quench the gasket in water after heating it to red. A good source (Rabers) just said to me that if I didn't quench the gasket, it would become hard again. Metal heat treatment is not a something where everything goes so it seems to me that the gasket should either be quenched or not. Anybody have any ideas on the process?
Jim
1970 Triumph Bonneville
1973 Commando Interstate
1971 OSSA MAR
Re: Annealing head gaskets [Re: yellow_cad] #342946
11/12/10 8:54 pm
11/12/10 8:54 pm
John Healy Offline
John Healy  Offline
The copper head gasket just needs to be heated until it is bright cherry red and left to cool. It doesn't need to be quenched, but if you do it clean it up and leave a nice clean finish.
Re: Annealing head gaskets [Re: yellow_cad] #342960
11/12/10 10:24 pm
11/12/10 10:24 pm
Corning N.Y.
choppadude Offline
choppadude  Offline
Corning N.Y.
I also have a bit of experience heat treating metals and alloys having done it for over a dozen years and it never made sense to me to quench a copper head gasket after annealing.
Once the copper gasket is evenly heated to a point where you can see a pattern of blue, green colors spreading across the surface,the molecules of the copper have become aligned. Quenching will only interrupt this process and in my opinion put you right back to where you began.
Re: Annealing head gaskets [Re: yellow_cad] #342962
11/12/10 10:45 pm
11/12/10 10:45 pm
John Healy Offline
John Healy  Offline
While I have done it both ways, I have been part of the quench school for nearly 50 years. I just like how the gasket looks when you do it. But I can attest, that for whatever reason, it doesn't re-harden the copper.
Re: Annealing head gaskets [Re: John Healy] #342971
11/12/10 11:23 pm
11/12/10 11:23 pm
Glendale AZ USA
Norri Robertson Offline
Glendale AZ USA
That's my experience too.
In my youth I was taught to quench so that's what I've always done, I don't know if cooling or quenching is better but quenching certainly results in a softened gasket.
Re: Annealing head gaskets [Re: yellow_cad] #342981
11/13/10 12:32 am
11/13/10 12:32 am
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
A lot of people will tell you that "you must quench copper" and even some factory manuals say that (and Rabers should know better) but copper does not need to be quenched although it does no harm if you do.
Re: Annealing head gaskets [Re: yellow_cad] #342998
11/13/10 3:30 am
11/13/10 3:30 am
JubeePrince Online content
JubeePrince  Online Content
I'm always in a hurry to get back on the road, so I quench!! Of course, I could have a cuppa and let the gasket cool....
And yes, the gasket does look nice after the scale is removed with a scotch-brite pad! bigt
Re: Annealing head gaskets [Re: yellow_cad] #343019
11/13/10 10:13 am
11/13/10 10:13 am
kommando Offline
kommando  Offline
Not only does copper not need to be quenched you do not need to heat it all to cherry red at the same time to anneal, you can do it in sections and as long as you do every section to cherry red it will all be annealled. Good to know if you are stuck with access only to a small torch.
Re: Annealing head gaskets [Re: kommando] #343022
11/13/10 11:49 am
11/13/10 11:49 am
Sunny South Carolina, (US)
T140V-Rich Offline
T140V-Rich  Offline
Which was a question I had about the process. So cherry red in sections still works to anneal, and then quench?
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: Annealing head gaskets [Re: yellow_cad] #343025
11/13/10 12:12 pm
11/13/10 12:12 pm
If you have a small torch, let the cherry red area under the flame travel over the surface of the gasket untill all area of the gasket has been red.
It does not matter that one part is still warming up from dark to red while another part is cooling down from red to dark.
Re: Annealing head gaskets [Re: yellow_cad] #343120
11/13/10 11:57 pm
11/13/10 11:57 pm
Westminster, MD, USA
J. Charles Smith Offline
Just put the gasket on an electric stove burner, turn it up to high, and when the burner and gasket turn red, turn the burner off and have a cuppa until it cools.
Re: Annealing head gaskets [Re: choppadude] #463269
11/14/12 3:21 pm
11/14/12 3:21 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Originally Posted By: choppadude
. . .Once the copper gasket is evenly heated to a point where you can see a pattern of blue, green colors spreading across the surface,the molecules of the copper have become aligned. Quenching will only interrupt this process and in my opinion put you right back to where you began.
So, the manual says "cherry red". Like choppadude, I heated a copper head gasket till I could see the blue, green colors, and could move them around the surface. When I annealed a smaller copper washer, it actually did flash cherry red. I'm wondering if I got the head gasket hot enough with my propane torch?
Re: Annealing head gaskets [Re: yellow_cad] #463273
11/14/12 3:54 pm
11/14/12 3:54 pm
kommando Offline
kommando  Offline
I have always worked to cherry red and it works even if you do it in sections, never tried just to do the phycedelic version. All refernces I have seen say Cherry Red.
Re: Annealing head gaskets [Re: kommando] #463291
11/14/12 6:32 pm
11/14/12 6:32 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Yep! I'm thinking you are correct. I'll go see my buddy with the oxy-acetylene torch and a rosebud tip. I'd like to get this right.
Re: Annealing head gaskets [Re: J. Charles Smith] #463297
11/14/12 7:10 pm
11/14/12 7:10 pm
UK and michigan
malla1962 Offline
malla1962  Offline
UK and michigan
works every time for me.
Re: Annealing head gaskets [Re: malla1962] #463368
11/15/12 5:16 am
11/15/12 5:16 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Thanks, Malla. I'll have a go at that first. It sounds easier.
Re: Annealing head gaskets [Re: malla1962] #463371
11/15/12 6:19 am
11/15/12 6:19 am
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
+1 for the electric stove method. I have been known to invert a large pot over the element/gasket to get the heat in. More recently I've acquired a LPG/propane type of torch so have been using that.
Re: Annealing head gaskets [Re: Excalibur] #463408
11/15/12 2:33 pm
11/15/12 2:33 pm
Okeechobee, FL
Tri74x Offline
Tri74x  Offline
Okeechobee, FL
Wife says -1 on stove... I use the gas grill outside. Cleans the grill at the same time!
Re: Annealing head gaskets [Re: Tri74x] #463421
11/15/12 4:23 pm
11/15/12 4:23 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
Well, yeah! But my wife has a gas stove, so I was planning to use my step-son's electric one. He's a bachelor -- should be no problemo.
Re: Annealing head gaskets [Re: yellow_cad] #463426
11/15/12 6:20 pm
11/15/12 6:20 pm
Nanaimo, B.C. Canada
W
Wilfred Offline
Wilfred  Offline
W
I just went to the local second hand store and got a single burner electric heater upper. Good for hot washing in detergent as well as annealing gaskets.....even heating water for tea or coffee and no -1 from the Mrs....now, if I could just find a little plug in oven for valve guides and bearings....Cheers, Wilf
"It's about the ride..."
It does not matter if you quench [Re: Wilfred] #463503
11/16/12 3:07 am
11/16/12 3:07 am
Georgia
TR5T_Mark Offline
TR5T_Mark  Offline
Georgia
Just adding my weight to the it-does-not-matter-if-you-quench copper as part of the annealing process or not. Captain Obvious says it is quicker if you do quench.
Mark
Re: Annealing head gaskets [Re: yellow_cad] #463541
11/16/12 1:29 pm
11/16/12 1:29 pm
This thread is like a wild fire. It was supposed to have stopped on november 14th 2010 but lights up again on the same day in 2012...
laughing
Re: Annealing head gaskets [Re: yellow_cad] #463559
11/16/12 4:22 pm
11/16/12 4:22 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I recently softened copper head seal rings (2x2x90mm) for a Pegasso ('56 Spanish DOHC V8). Heat the copper with a carbon flame and soot the surface then heat it with a neutral flame until the soot burns off and let air cool. Mind, as soon as you bend the copper it will harden.
