T100Mark
T100Mark
Southern California
40 registered members (21inGoldie), 211 guests, and 361 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,628 mail-order LSR
Topics68,845
Posts670,611
Members10,478
Pre-unit Transmission Gaskets #463201
11/14/12 3:05 am
11/14/12 3:05 am
Kansas City
RGSDave Offline OP
RGSDave  Offline OP
Kansas City
Can anyone tell me, do I use the inner and outer gaskets like I've seen on eBay, or do I just use sealer? I have 4 of these transmissions and none of them have gaskets. If I should use gaskets, then with sealer or no sealer on the gaskets?
Re: Pre-unit Transmission Gaskets [Re: RGSDave] #463236
11/14/12 11:26 am
11/14/12 11:26 am
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
Morn'n RGDave,as long as nothing binds,I don't use gaskets,just sealer.I have seen transmissions that needed an inner gasket for clearance. Dick
Re: Pre-unit Transmission Gaskets [Re: RGSDave] #463238
11/14/12 11:30 am
11/14/12 11:30 am
Asheville, NC
Mike Baker Offline
Mike Baker  Offline
Asheville, NC
Dave-
I've only worked on unit motors, but I don't think the PU gearbox is mechanically much different.
I've put them together both ways, and can't really say that one is preferable. I always thought that the extra end float, "slop", whatever you want to call it, when gaskets were used would affect the way it works, but haven't found that to be true. I use gaskets now because its less messy than 3bond.
Mike
Re: Pre-unit Transmission Gaskets [Re: RGSDave] #463436
11/15/12 6:54 pm
11/15/12 6:54 pm
HawaiianTiger Offline
No gaskets needed. You can machine a groove for an "o" ring for the shifter shaft, though, if you don't already have it. Somehow Triumph expected the rubber square sectioned do-dad on the kick start shaft to seal it there, but that was wishful thinking. A proper lipped seal can be used there with a little ingenuity.
Also, you can install a later and longer mainshaft bushing so that the leaks that normally come out of there while the bike is sitting on the side stand will drain into the primary.
Even with all that you can expect a drop oil gearbox oil here and there as normal.
Re: Pre-unit Transmission Gaskets [Re: RGSDave] #463445
11/15/12 8:28 pm
11/15/12 8:28 pm
triton thrasher Offline
If you're losing much oil through the kickstart shaft, gearchange shaft, or the sleeve gear bush, there's too much oil in there.
