Jean Des Rosiers
Jean Des Rosiers
Montreal, Quebec, Canada
32 registered members (Andy Higham), 276 guests, and 207 spiders.
10173 Registered Users
Lannis 93
reverb 84
NickL 68
koan58 60
550,853 mail-order LSR
Topics66,564
Posts645,300
Members10,173
conical hub front wheel on early forks #463219
11/14/12 7:58 am
11/14/12 7:58 am
lancashire united kingdom
run990 Offline OP
run990  Offline OP
ny 65 a65 has the feeble full width sls front brake ,i know the conventional tls is a straight bolt in job,however i have spotted a conical hub front wheel with good chrome right size rim & good tyre ,it seems to have been modified to having the backplate located via the slotted groove rather than by the usuall stud.its been years since i messed with swapping wheels on these bikes ,something is telling me the whole wheel is wider on the spindle or an i wrong.reason for fitting wheel is bike is a daily user & no front brake is becoming a bit of an issue plus the price is good less than half the cost of the earlier tls drum
Re: conical hub front wheel on early forks [Re: run990] #463231
11/14/12 10:21 am
11/14/12 10:21 am
derby england
wak Offline
wak  Offline
derby england
The spindle is about an inch longer, however with a bit of messin you still might get the hub in.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: conical hub front wheel on early forks [Re: run990] #463243
11/14/12 12:19 pm
11/14/12 12:19 pm
Stuart Offline
Stuart  Offline
Originally Posted By: run990
conical hub
Has "the slotted groove" been machined into the backplate, or has it been formed by adding material on either side of the groove's position? If the latter, can you be sure the extra material won't come off one time you apply the brake?
Re: conical hub front wheel on early forks [Re: Stuart] #463268
11/14/12 3:21 pm
11/14/12 3:21 pm
Jon W. Whitley Offline
Scary, hopefully it has been machined.
I imagine aside from the brake plate issue, he will have to use the existing '65 axle as doesn't it have the threaded axle and right side fork leg? Then there is the bearing issue, etc.etc.
Re: conical hub front wheel on early forks [Re: Jon W. Whitley] #463276
11/14/12 4:02 pm
11/14/12 4:02 pm
Stuart Offline
Stuart  Offline
Hi Jon,
According to this recent thread, some '65 BSA models had the Triumph-type spindle, clamps and full-width drum; I'm guessing that's what the o.p.'s bike has if he's considering using a comical hub? The '65 brake and forks also appear to be detailed in the '64 twins parts book on Kim's CD.
Re: conical hub front wheel on early forks [Re: Stuart] #463290
11/14/12 6:07 pm
11/14/12 6:07 pm
run990 Offline OP
run990  Offline OP
yes my bike has the forks with detachable caps not the older push thru type spindle ,the slot looks to be machined into a piece of alloy welded to the backplate it also passes over the bolt that is normally used.there looks to be some wear in the slot so brake has worked in the past for someone.my forks are like later a10 type forks with a full width hub.the 1 inch width diffrence seems to ring a bell from fitting a wheeel to a bike 20 years ago. thanks for the input ,i think i will try to improve the function of the current brake by increasing the leverage.its been ok since 1965 so i will just have to improve my grip ha ha
Page Time: 0.065s Queries: 15 (0.006s) Memory: 1.0221 MB (Peak: 1.1740 MB) Zlib disabled. Server Time: 2018-04-22 18:31:17 UTC
