Huntmaster
Huntmaster
Ottawa, Canada
40 registered members (Alan_nc), 244 guests, and 472 spiders.
10257 Registered Users
Lannis 60
TBolt72 46
609,192 mail-order LSR
Topics67,120
Posts651,371
Members10,257
bsa c15 carb questions #457791
10/07/12 11:52 pm
10/07/12 11:52 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
hi any have a Monobloc 375 /34 carb on my 1966 bsa c15
i have been building. am having trouble getting fuel
into cylinder engine not firing, if i pour petrol direct
into barrel engine fires up until this is used up/,
spark plug seems dry when trying to start in normal way.
have cleaned out carb all jets etc. float ok, filling ok
understand that on start up carb runs on pilot system
small holes these are clear. have set throttle control
screw at 1 1/2 turns.if i unscrew more turns will this
increase flow on start up. valves and ignition timing are
set up correctly.also there is a lot of blow back of fuel
from carb inlet. no filter fitted,. can any one help with
question. also need to buy air filter pancake type.
there is limited room from carb inlet to tinware,
the carb is a AMAL 375.any suggestions on suppliers in uk
thks the slug
Re: bsa c15 carb questions [Re: slug] #457801
10/08/12 3:03 am
10/08/12 3:03 am
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Are you using a new viton tipped float needle? I find that these are sticking and not dropping thus not letting fuel fill the float bowl enough. I have better luck with the nylon (plastic?) float needles. When you tickle the carb can you make it over flow out of the tickler? If not then you are not getting fuel into the carb. There are all sorts of other things that might make it not start but I'd start checking this function.
Peter
Re: bsa c15 carb questions [Re: Peter Quick] #457807
10/08/12 5:33 am
10/08/12 5:33 am
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
thks pete for answer.have changed shut off valve it is
the rubber tipped type . had just the nylon type before.
found this was sticking closed, so changed, new type
seems to function ok. fuel does come out the top of ticker.
still cant work out why its not running,
thks the slug.
Re: bsa c15 carb questions [Re: slug] #457820
10/08/12 8:07 am
10/08/12 8:07 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
set up correctly.
The mixture screw (the horizontal one near the flange),controls air.If you screw it in,less air makes the mixture richer.
A good starting point for the throttle stop (angled beside the slide) is 3/4 turn in from where it first contacts a closed slide.
The fuel level in the bowl should be 1/2 way up the bowl.There might be a raised dot on the float bowl cover centre.If you take the cap nut off the pilot jet,you can connect a hose to the jet to check the fuel level.
Re: bsa c15 carb questions [Re: Pete R - R.I.P.] #457825
10/08/12 9:29 am
10/08/12 9:29 am
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
thks pete for advice will try those
two things great,.
Re: bsa c15 carb questions [Re: slug] #458016
10/09/12 2:28 pm
10/09/12 2:28 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
hi all still not starting. have set and checked float
in bowl. level correct to dot. tried different locations
with air and throttle screws.
have tried duct tape on inlet with small hole to try
to choke carb. still not firing spark plug not getting
fuel very dry. am running out of ideas,.
cheers.
Re: bsa c15 carb questions [Re: slug] #458024
10/09/12 3:22 pm
10/09/12 3:22 pm
Double check your pilot circuit including the jet, if its marked as a 25 run a 16 thou #78 drill through it as it can look clean but deposits/corrosion have undersized it. The pilot circuit is what the bike starts on so a dry plug says its clogged or you are not tickling enough.
Re: bsa c15 carb questions [Re: kommando] #458052
10/09/12 6:46 pm
10/09/12 6:46 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
thks kommando will look at that sounds
like good advice.
any one got advice about an air filter
cheers
Re: bsa c15 carb questions [Re: slug] #458273
10/11/12 4:25 am
10/11/12 4:25 am
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
hi as kommando said, i checked pilot jet and cleaned
out small carb ways.found the pilot jet was only a 20.
have ordered a 25 the manual says this is the correct
jet to use,found the 20 jet was partly clogged cleaned
out jet seems to narrow to cone shape at end and narrows.
tried with 20 jet in still dry plug. am waiting for new
25 pilot jet to arrive to try that,
would just having the wrong size pilot jet effect the
starting,
cheers the slug
Re: bsa c15 carb questions [Re: slug] #458297
10/11/12 9:45 am
10/11/12 9:45 am
Not sure if a 20 would badly affect starting but a 25 does not take much crud to stop it working.
Re: bsa c15 carb questions [Re: slug] #458299
10/11/12 9:58 am
10/11/12 9:58 am
derby england
wak Offline
wak  Offline
derby england
it should fire up what ever the jets are doing by the fact you are flooding the carb, try squirting some gas in the plug hole or into the carb intake. iv started engines with no carb on them just by chucking gas in them.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: bsa c15 carb questions [Re: slug] #458301
10/11/12 10:39 am
10/11/12 10:39 am
Vic. Australia
Vic. Australia
I would have thought it would still start,now that the pilot jet is clean.
A good tickle should richen it up enough to start,even though it might not run well after it starts.
Could the idle discharge holes near the front of the slide be blocked too?
Re: bsa c15 carb questions [Re: Pete R - R.I.P.] #458323
10/11/12 3:48 pm
10/11/12 3:48 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
great thks kommando, wak and pete.yhks for trying you help me.
yes have checked fuel ways in carb are clear.
some places are hard to get too, have sprayed carb
cleaner down ways and seems to come out ok at other ends.
have put fuel direct into barrel via spark plug holes
and engine fires until it burns off.have tried to start with
20 pilot jet but thnk it may be slightly clogged at jet end.
small dia wire does not go all the way to end,should it be the same all way down.
like you say should still get fuel through. will try again
when new 25 jet arrives and let you know how i get on.
what the diff between 20 jet and 25 is it .5 thuos
timing valves have all been done engine has been rebuilt.
must be carb problem with dry plug all the time
cheers lads tne slug.
Re: bsa c15 carb questions [Re: slug] #459321
10/18/12 4:05 pm
10/18/12 4:05 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
:blushhi everyone thks for help with my carb question.
fitted the 25 pilot jet in place of 20. checked all the
small carb chambers all clear.now know my way round the AMAL
Monobloc carb..fuel was blowing instead of sucking. after rechecking valve timing found it was
timed miles out.bike starting great now, maybe i think first time in 20 or 30 years. another one lives again.
with the air filter problem obtained a small 30mm cone shaped
air filter. fitted to end of stock rubber hose from end of carb.air filter sits within tin ware behind battery box,.
thks to all the help from the bsa guys trying to help me..
cheers the slug..
Re: bsa c15 carb questions [Re: slug] #459331
10/18/12 5:17 pm
10/18/12 5:17 pm
As far as the air filter goes, I use a K&N RU-2450 (marked F018G4 on base) on my B40. I had to open the hole in the shroud a little to run a piece of radiator hose for connecting it, though with the smaller inlet diameter of your 275, you may be able to use a reducer and smaller hose that clears.
Re: bsa c15 carb questions [Re: Alex] #459334
10/18/12 5:25 pm
10/18/12 5:25 pm
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
great thks alex photo very informative.
thats what my set up will look like have
a reducer for pipe.
is that a made up feed pipe on top of carb with 90degree bend. lot better than normal supply straight out . . cheers the slug
Re: bsa c15 carb questions [Re: slug] #459366
10/18/12 9:47 pm
10/18/12 9:47 pm
Slug, that fuel feed pipe came stock on Monoblocs but was made of plastic so many are gone. I have not found a source of new ones (AMAL doesn't list them) so autojumbles are your best bet.
Cheers.
Re: bsa c15 carb questions [Re: Alex] #459419
10/19/12 5:30 am
10/19/12 5:30 am
hereford uk
slug Offline OP
slug  Offline OP
hereford uk
thanks for info alex. maybe get an old brass type.
shorten and solder an elbow and short bit of copper pipe on
all the best.
