Matthew Manton
Matthew Manton
Toronto
186 registered members (79T140E), 2,086 guests, and 589 spiders.
koan58 90
NickL 86
505,667 mail-order LSR
Topics66,062
Posts639,403
71 forks to work on 65 frame? #45224
12/21/05 5:03 am
12/21/05 5:03 am
Clayton
odl777 Offline OP
odl777  Offline OP
Clayton
What can i do to get my 71 oif forks to work on my 65 or 67 bsa frame. any sugesstions thanks
Re: 71 forks to work on 65 frame? #45225
12/22/05 1:28 am
12/22/05 1:28 am
Winston-Salem N.C.
D.W.R. Offline
D.W.R.  Offline
Winston-Salem N.C.
Unless I'm missing something, I believe you can just slip your 71 legs into your earlier yokes. That's what I'm planing to do on my 66. Didn't use a micrometer or anything high tech, but the width looks the same with my tape measure. Tubes are the same diameter.
71 Rocket 3
72 B50 MX
66-71 A 65 Bitsa
96 Trident 900
Re: 71 forks to work on 65 frame? #45226
12/22/05 4:10 pm
12/22/05 4:10 pm
San Diego, CA
Will S. Offline
Sponsor Member
Will S.  Offline
Sponsor Member
San Diego, CA
I don't think that would work w/o mods, the pre OIF fork tubes have a taper at the top to snug into the top tripleclamp, while the OIF fork tubes are not tapered and held in place by a clamping action.
Will S.
BSAs: '66 & '69 Lightning
Triumphs: '68 TR6R, '68 Bonneville, '73 TR7, '55 6T
'71 Norton Commando
www.britironsd.com
Re: 71 forks to work on 65 frame? #45227
12/22/05 4:39 pm
12/22/05 4:39 pm
gavin eisler Online content
gavin eisler  Online Content
My OIF forks have a taper at the top.
Should fit, but they will probably be too long , unless you like a chopper look.
pod
Re: 71 forks to work on 65 frame? #45228
12/22/05 8:50 pm
12/22/05 8:50 pm
Winston-Salem N.C.
D.W.R. Offline
D.W.R.  Offline
Winston-Salem N.C.
Will/pod
It depends on the year of the OIF forks as to the top taper/ or clamp. The 71/72 had the taper, later ones like the T140 with a disc had the pinch bolts in the upper clamp. I plan on useing the stock tubes/lowers/wheel from my 71 Rocket 3 on a 66 Spitfire and everything measures out the same. As the R3 is getting a T140 disc front, I've looked all these pieces over pretty closely (yes I have the correct T150 lower yolk). The later disc fronts were held differently at the top and the spread was wider. Before anyone jumps, yes I'll have to use twin springs and dampers in the Spitfire as these differ from the triple parts.
71 Rocket 3
72 B50 MX
66-71 A 65 Bitsa
96 Trident 900
Page Time: 0.069s Queries: 14 (0.006s) Memory: 1.0148 MB (Peak: 1.1634 MB) Zlib disabled. Server Time: 2018-02-25 10:03:18 UTC
