Kenacu
Kenacu
RED BANK NJ
202 registered members (1xfatboy), 2,157 guests, and 545 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
69' T150 big bore #450641
08/23/12 9:35 pm
08/23/12 9:35 pm
NYC
djg42 Offline OP
djg42  Offline OP
NYC
Hello,
Came cross a great deal on a. 830 kit , with thd head pistons and rings. Tempted to buy it, but was wondering if anyone here has done it? Will I need a special base/head gasket? Will it need any modifications to the head? Thanks for any advice,
Dennis
Re: 69' T150 big bore [Re: djg42] #450647
08/23/12 10:08 pm
08/23/12 10:08 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Which particular "830" kit is it?
A suitable head gasket (usually copper) will be required, however they are not particularly difficult to obtain.
Re: 69' T150 big bore [Re: L.A.B.] #450655
08/23/12 10:27 pm
08/23/12 10:27 pm
NYC
djg42 Offline OP
djg42  Offline OP
NYC
The seller isn't sure which kit was used?
Re: 69' T150 big bore [Re: djg42] #450728
08/24/12 8:01 am
08/24/12 8:01 am
Stuart Offline
Stuart  Offline
Hi Dennis,
There are good and ... uh ... not so good ... triple big-bore kits.
Good are ones from P&M and Neil Beadling in GB; in the US, guys like TripleTecs might be able to help.
Hyde barrels are easy to tell - they have fewer fins and a wider spacing than standard ones. They can be good, but they can also be a pita - expect to have to helicoil/Timesert all the threads in an old one. frown
'Least good' whistle of the not-so-good are probably the ones marketed by Wassell in GB, although John Healy says Wassell didn't actually make them. These are simply standard barrels bored out; because the casting then doesn't support the liners, they go oval, leading to much smoking. General consensus is that these'll last about 10,000 miles - sort-of ok if you do 500 to 1000 miles a year, less good if you do more.
Worst would be 'Wassell' barrels that've done the 10,000 miles already ... sick
Re: 69' T150 big bore [Re: djg42] #450740
08/24/12 10:20 am
08/24/12 10:20 am
Greece
kostas Offline
kostas  Offline
Greece
Hi djg,I will send you some informations only to help you,I have a big bore kit from NOVA CLASSICS NEIL BEADLING,I PAID FOR THEM 1500 STERLING POUNDS PLUS THE PRICE OF THE OMEGA FORGED PISTONS.Well,when I had on my hands I was very happy, very good castings,many big fins etc but when I measured with cylinder bore gauge tool to see if the piston clearance was ok,I found that was something wrong with them,.004" on the top .003" in the bottom.I found also that they were not std size, the pistons were 71.5mm not 71mm and the liners were over the top of the face of the barrels they needed skimmed.Finally I spent 400 euros for new liners and rebore service here in Greece.I couldn't find him on the phone and didn't responded to emails.Very bad comments I heard for MR HYDE ESPECIALLY FOR HIS TRIPLE LONGSTROKE CRANKS.The only serious company is P&M AND if you find a billet alloy big bore kit there is the best of all,another great company who had big bore triple kits is MAP.The best pistons for them are the forged omega and Arias and in the 70's venolia pistons was great for big bore triples.I hope to help you and please be careful out there!!!!!Cheers Kostas.
Re: 69' T150 big bore [Re: djg42] #450783
08/24/12 3:43 pm
08/24/12 3:43 pm
Mark Parker Online content
Mark Parker  Online Content
I used routt 867 big bore liners in a std cyl and they worked fine. You can just use a file or powered hand tools,(a rotary burr or die grinder,)to adjust the bore on a std copper head gasket. Don't use a base gasket, use 3bond supersealer or similar, if you use solid copper rockerbox gaskets as well you will hardly ever need to adjust tappets.
Triples are really nice with a big bore kit.
Kostas "the liners were over the top of the face of the barrels they needed skimmed." Don't the Hyde liners have a spigot at the top to go through the gasket?
I'm pretty sure when we fitted liners in my cyl we left them a little above the surface to get a better seal.
Re: 69' T150 big bore [Re: djg42] #450803
08/24/12 7:05 pm
08/24/12 7:05 pm
Greece
kostas Offline
kostas  Offline
Greece
Hi Mark,the Hyde big bore triple barrels doesn't have the last fin on the top to check easy for leaks.I make my barrels absolutely flat on the top and with a Victor Reinz head gasket I resolve all the problems.With P&M AND NOVA big bore kits you can also to torque the cylinder head at 20lb/ft without problems.Regards Kostas.
Re: 69' T150 big bore [Re: kostas] #451326
08/27/12 11:31 pm
08/27/12 11:31 pm
NYC
djg42 Offline OP
djg42  Offline OP
NYC
Thanks for the info! This will be my 1st time ith this kind of thing, wil my stock wrist pins work with the oversized pistons, or is that something I will hae to find?
Re: 69' T150 big bore [Re: djg42] #451334
08/28/12 12:35 am
08/28/12 12:35 am
Every piston I've ever bought has come with wrist pins, circlips and rings.
Re: 69' T150 big bore [Re: djg42] #451366
08/28/12 8:48 am
08/28/12 8:48 am
Peter R Offline
Peter R  Offline
According to Mr Kostas, the linings ofthe Hyde big bore cilinder were over the head. This is correct, and done on purpose.
The reason for this is to reduce the pressure on the head gasket.
Re: 69' T150 big bore [Re: djg42] #451696
08/30/12 10:22 am
08/30/12 10:22 am
Greece
kostas Offline
kostas  Offline
Greece
Hi Peter,from Mark's posts you can understand that he has a great experience on these bikes and always helps me and the same many other members,I just sent my opinion and the experience what it works on my bikes.And I wouldn't to speak for Hyde's "special parts"cheers Kostas.
Re: 69' T150 big bore [Re: djg42] #451972
09/01/12 1:26 am
09/01/12 1:26 am
NYC
djg42 Offline OP
djg42  Offline OP
NYC
I got the cylinders and pistons , but they didn't have the wrist pins. What should i do? Can u just order new stick ones or will I have to find ones made special for these pistons?
Re: 69' T150 big bore [Re: djg42] #452480
09/03/12 11:40 am
09/03/12 11:40 am
Charlotte NC
RHall-HCV Offline
RHall-HCV  Offline
Charlotte NC
Hi, Is it true that the STD 650 piston is the one used for the 867 kit?? Heard that somewhere.?? Thanks
ROB HALL
HCV MOTORSPORTS
Re: 69' T150 big bore [Re: djg42] #452517
09/03/12 2:03 pm
09/03/12 2:03 pm
John Healy Online content
John Healy  Online Content
Hyde, and other early kits, were based upon modified 650 pistons. The skirts have to be cut to clear the flywheel.
To quote triple specialist Phil Pick, "The sleeve arrangement of the Hyde kit, coming through the head gasket, is its only redeeming feature."
Re: 69' T150 big bore [Re: RHall-HCV] #452663
09/03/12 11:35 pm
09/03/12 11:35 pm
Stuart Offline
Stuart  Offline
Hi Rob,
If it's simply a big-bore - standard 70mm triple stroke - no; 867 requires 72.5mm and, as you know, "the STD 650 piston" is 71mm, which gives 831.
Btw, in a recent TOL post by Pat Brown of Triples Rule (whom I forgot in my previous post - sorry Pat blush ), he admitted he'd made a mistake calculating his big-bore kit as 867; his uses 72mm pistons so is 855.
Finally, one of the options certainly with the Nova (Neil Beadling) kit - and possibly with the P&M kit - is 71.5mm Omega pistons, giving 843.
Re: 69' T150 big bore [Re: djg42] #452757
09/04/12 8:12 am
09/04/12 8:12 am
djg42, can you take some photos and put them up? And we maybe can tell what pistons you have. See if the piston in machined for a square section circlip or round.
Re: 69' T150 big bore [Re: djg42] #452923
09/05/12 1:11 am
09/05/12 1:11 am
NYC
djg42 Offline OP
djg42  Offline OP
NYC
Thanks! Here are some pics, any advice is greatly appreciated,
Page Time: 0.088s Queries: 15 (0.011s) Memory: 1.1194 MB (Peak: 1.3733 MB) Zlib disabled. Server Time: 2018-02-24 14:22:02 UTC
